Question about Hudson Reed Traditional 6 piece bathroom accessory pack
Leak from tap
Leak from top of tap, its single pillar mono mixer tap(tilt and turn for hot/cold), unscrewed the round handle in the middle and removed the grub screw, but cannot remove the top of tap which sits on the swivel ball.
Dont really know the make or model.
Any advice please.
2 Suggested Answers
  • 659 Answers
SOURCE: My Hudson Reed lift and turn mono block tap leak
There should be a retaining ring right under the handle when removed. The stem of the ball runs up through the middle. Tighten this retaining ring and it should stop the leak.
Posted on Mar 21, 2009
How do i put the o rings and springs in my old leaking 2 handle faucet
Make sure the water to the tap set is turned off. Remove the hot plug button, use a small knife to pry it out of the top of handle. Remove the screw inside the handle that holds the handle to the cartridge. Use an adjustable wrench to unscrew the tap handle from the base. Once removed, separate the cartridge from the shell (the unscrew from each other). Use the appropriate size and type of screw driver to remove the screw holding in the flat washer. Using a small dull needle or flat screwdriver remove the "O" ring from the valve stem Replace the o ring by just slipping it on. Make sure you clean all areas of the stem and the stem cartridge of old grease and dirt etc. Use new clean valve stem grease on the O ring before re installing into the cartridge. Insert the new washer onto bottom of valve stem, Screw on. While you have it apart look down inside the tap to inspect the valve seat. If its chipped, broken, rusted etc you MUST replace it, if you do not any new parts will sot stop the leak. Valve seat MUST be nice and flat and clean. To remove the seats most taps will require a 3/8" Allan wrench. Push the wrench into the slot of the seat, turn C-Cw to remove, CW to replace. These parts are cheap. If you need to replace the seat, take it with you to H Depot so they can give you the correct one. NOTE: Its best to do the cold at the same time, saves you the trouble of doing it again later. Same applies to the cartridges. You can replace the entire cartridge instead of rebuilding them at only a few bucks each, its much faster and easier.
Aug 10, 2014 | American Standard Plumbing
I have a new Bradford white 40 gallon gas hot water heater. There are no single handle faucets. The hot water fluctuates between hot and cold. When I close both inlet and outlet shut off for the hot water...
Sounds like water leak.
For example, broken pipe... or water running out of TP valve.
That would explain variable hot-and-cold water at tap.
Turn off all taps, and observe if water meter is registering water usage.
Jun 15, 2014 | Water Heaters
Leaking sink tap base
If I understand this correctly, you will need to remove the tap handle, the surround which sits against the sink, then the tap body, then unscrew the spindle till it comes free, and replace the o-ring on the spindle.
If the leak is under the sink, or if it is a mixer tap, please clarify that.
Jan 10, 2014 | Home
Excess Hit Water Bill from Solar/electric Hot Water System
10-30-12
Cost calculations for recirculation system vary widely.
These systems cost more, and they cause higher operation cost of water heater.
1) When pump is OFF, then hot water is no longer leaving the tank.
Most recirculation systems have choice of timer for setting specific times of operation, or thermostatic operation that activates pump when sensor detects temperature less than 90 degrees
BUT...
2) Condition of plumbing is suspect here because you are not receiving fully 90 degree hot water from the recirculation system.?.
Bad single-handle faucet cartridge, or bad recirculation check valve, are causes of crossover. Clean recirculation check valve with white vinegar. Replace worn faucet cartridge.
Test for crossover.
http://waterheatertimer.org/Crossover.html
3) There are other suspects, such as water leak.
Drips, broken pipe, bad TP valve.
Turn off all taps and put ear against pipe to listen for running water.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
4) High costs: Lifting single-handle faucet in middle will immediately cause cold water to enter tank. Even if no hot arrives at tap, because the cartridge is drawing both hot and cold in equal amounts when handle is lifted in middle.
Today it is more efficient to install dual-handle faucets so tank is not receiving constant dose of cold water when single-handle faucet is not used correctly or tediously.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Oct 29, 2012 | Water Heaters
Slow leak old delta
The brass cap unscrews and yes there are replacements. You can find them at any home improvement store.
Sep 14, 2009 | Delta & Single Handle Shower Faucet
Kitchen taps drip and leak.I do not want to replace with new but would like to sort these problems.
dependent on the type of faucet, you need to replace (a) the washers, (b.) the spring and seals or (c.) the gasket. They all serve the same purpose. 1. turn off the water supply to the faucet. 2. double handle? (a)remove the center cap (b) then remove the screw holding the handle down (c)next unscrew the valve stem retaining nut (normally it is the one right above the faucet body). (d) pull the valve stem out, if there is a small rubber piece held down by screw remove the screw, replace the washer. if there is a rubber gasket wrapped around the stem, remove and replace it, if nothing is on the stem look into the faucet body you should see 1 or 2 small rubber pieces these are the seals the springs are right below the seals. Remove and replace springs and seals. 3. single handle? remove the handle retaining screw, normally covered by hot/cold indicator symbol, unscrew valve stem retaining nut, pull the valve stem and replace either the gasket or springs and seals.
Aug 28, 2009 | Home
Mar 21, 2009 | Hudson Reed Traditional 6 piece bathroom...
Shower handle leak
turn off main water in home . turn on tap some where in home to release presser take shower handle off (screw under cap) unscrew the tap with a wrench unscrew on insides you pull out replace washer put all back togethere
Feb 11, 2009 | American Standard 3275.505.099 Colony Soft...
Leaking single lever kitchen tap
on most of the single handle faucets there is an erasure like button ( may have a hot and cold blue and red indicator or be silver ) usually located right under the faucet arm on the manifold chrome sleeve or back behind the arm or it could have a large ring nut over the doam of the lever take your hand and feel the area that covers the area where the spout arm swivels and feel for the button or take your fingers and fel the to of the lever doam
if you find the button just take a sharp screw driver( be sure to plug the drain holes and turn hot and cold water off under sink) pry the button off and use a hex wrench and loosten
if no button then there has to be a large nut on top you may seee two grooves oppsoite each other wheich would mean a special tool
use an adjustable wrench (put cloth ofer chrome to protect and turn counter clock wise( the ring nut will not be very thick
after removing you should be able to replace the cartridge
good luck
Dec 30, 2008 | Danze D403412 Melrose Single Handle...
Hudson Reed Traditional 6 piece bathroom accessory pack Logo
131 people viewed this question
Top Hudson Reed Home Experts
ray gallant
Jay Plesset
Donni Steen
Are you a Hudson Reed Home Expert? Answer questions, earn points and help others
