Question about Toshiba Satellite P30 P35 Series Notebook
Harddrive malfunction and white lines on screen about 1 inch wide 3 lines also some light coloured lines
Did you get a solution for this? I would be interested in hearing from you, I have the same display problem. rayfuss[at-nospam]gmail-dotcom
Posted on Jan 18, 2010
Toshiba satellite pro p100 screen problem
The LCD can be replaced. The part is around $50-$75 I believe. It can be tricky to replace, but if you take your time, you can save money by doing it yourself. The screen sounds cracked or broken, and black & white will not work either.
good luck
Mar 19, 2013 | Toshiba Satellite P100 Series / Satellite...
I have a nec lavie lap top the has no hard drive i would like to buy one but dont know how to find the model number
This is one example,
http://www.priorityelectronics.com/product/NEC/Lavie_S/LS700J_OR_36DT3/MK3021GAS/
A Harddrive's physical size is rated from it's Width. How wide across is it.
A Notebook PC harddrive is 2.5 inches across in width. (2 and a half inches)
A Desktop PC harddrive is 3.5 inches across in width.
1) You need a 2.5 harddrive.
There are two types of Harddrive technology used;
The older IDE (PATA), and the newer SATA.
The NEC LaVie S Notebook PC uses a Harddrive with the IDE (PATA) technology.
2) You need a 2.5 IDE (PATA) harddrive.
[ IDE (PATA),
http://en.wikipedia.org/wiki/Parallel_ATA#IDE_and_ATA-1
SATA,
http://en.wikipedia.org/wiki/Serial_ATA ]
The original harddrive amount size in GigaByte's was 20GB.
{Giga = Approximately 1 Billion
A Byte is considered to be 8 characters. Whether the characters are Numbers, Letters, or Symbols}
Do I know what the largest harddrive in GB's is that can be installed?
No.
I need the Exact model number from the bottom of the laptop.
NEC = Manufacturer
LaVie = Model Line
S = Model Series
The exact specific model number is on the bottom of the laptop. Usually in a white sticker.
This page denotes a few model numbers, I'll use them as examples,
Scroll down to the bold NEC Lavie S heading, and look at the model number examples.
With this information I can look to see what hardware is used, and possibly harddrive size limit.
Post back in a Comment.
Regards,
joecoolvette
Sep 30, 2011 | NEC LaVie S LS900/8E Notebook
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Print is missing along a one inch width patch for the entire lengh of mdocument
try a new toner cartridge
if it doesn't fix your problem then you willneed a new fuser
it is probably delaminated
Dec 22, 2007 | HP LaserJet 3055 All-In-One Printer
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
Toshiba Satellite P30 P35 Series Notebook Logo
131 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
