Question about Averatec 6200H Notebook
Averatech computer problems
My Avaratech 6220 notebook will not start my windows xp.  I tried the recovery cds that they included, but while my computer is loading them, it automatically shuts off.  This is the third time this has happened and I have had the computer for less than a year and a half?  What can I do?
    Sergeant:
  • 457 Answers
Do you have the windowsxp cd for installation not the recovery one the install one?.
If you have the disk allow windows to boot up from that disk allow it also  to go through the motion of installing windows till it can go no further.  PRESS "R" for Console then go to the dos prompt...  type         chkdsk /p
Allow windows to fix up things then remove the disk and try starting.
Posted on Oct 17, 2007
Hi I have an acer mininotebook and it have the msg: "ntldr is missing" it doesn't run. I already trfied the Acer e recovery but it stops on 73% with the following message: "restore failed! Reason:...
Solution for NTLDR is missing in windows XP and in Vista
If you are usiing WindowsXP, follow below steps
Using Windows recovery console.
The Windows 2000 and Windows XP CDs supplied by Microsoft has a tool called the Recovery Console which can be used to repair errors that prevent Windows XP from starting using the command line. OEM versions of Windows XP, including computers that were supplied with Windows XP preinstalled, may not have this utility.
This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged:
Ntldr
Ntdetect.com
Boot.ini
Check your drives for floppy,USB storage devices,CDs and any other bootable media.Because sometmes these things makes problems.Then go to BIOS and do the BIOS settings to boot from the source where the OS is installed.
1: Insert the Windows XP bootable CD into the computer.
2: When prompted to press any key to boot from the CD, press any key.
3: Once in the Windows XP setup menu press the "R" key to repair Windows.
4: Log into your Windows installation by pressing the "1" key(most of the cases it will be "1" only) and pressing enter.
5: You will then be prompted for your administrator password, enter that password.
6: From the command prompt, copy NTLDR and NTDETECT.COM from the i386 folder of the CD to the root folder of the hard drive. In the example commands given below, C: is the hard drive and D: is the CD-ROM drive. You will need to change the drive letters if appropriate:
COPY D:I386NTLDR C:
COPY D:I386NTDETECT.COM C:
Once both of these files have been successfully copied, remove the CD from the computer and reboot.
If you are using Windows Vista, follow below steps
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec.exe, and then press ENTER.
You can use bootrec /fixmbr or bootrec /fixboot or bootrec /rebuildbcd according to your situations, for more info about bootrec.exe,see below link
Jun 16, 2010 | Acer Aspire One Netbook 8.9" Notebook
Tip
How to solve NTLDR is missing issue in windows XP
Ntldr
Ntdetect.com
Boot.ini
COPY D:I386NTLDR C:
on Mar 03, 2010 | Microsoft Windows XP Professional
Stop c0000218 registry failure
This will sometimes happen with a Windows XP installation when either the hardware in not compatible with the operating system...or the hard drive is damaged.
Use the recovery console to confirm that the hard disk or file system Is not damaged loadTOCNode(2, 'resolution'); Important We recommend that only advanced users or administrators use the Recovery Console.
Note Only the Administrator account can access the Recovery Console.
  1. Start your computer from the Windows XP CD drive. If prompted, select any options that you must select to start from the CD drive.
    Note To start your computer from the Windows XP CD drive, your CD drive or DVD drive must be configured to do this. For information about how to configure your computer to start from the CD drive or DVD drive, see the documentation that is included with your computer or contact the computer manufacturer.
  2. When you are prompted to select Repair or Recover, press R. This starts the Microsoft Recovery Console.
    Note You may have to enter the number to specify the Windows XP installation in the hard disk.
  3. When you are prompted, type the Administrator password. If the Administrator password is blank, just press ENTER.
  4. Use the chkdsk command-line tool to examine the hard disks. At the command prompt, type chkdsk /r, and then press ENTER.
  5. Read the results, and then take any steps that you must take to complete the process. For example, you may be prompted to run chkdsk /f to fix certain problems.
  6. Restart the computer, and then try to run Setup again.
May 23, 2010 | Dell Latitude D600 Notebook
Ntldr is appearing on start up screen where it then asks me 2 ctrl alt del 2 restart
NTLDR is missing in windows XP and in Vista WindowsXP Using Windows recovery console. The Windows 2000 and Windows XP CDs supplied by Microsoft has a tool called the Recovery Console which can be used to repair errors that prevent Windows XP from starting using the command line. OEM versions of Windows XP, including computers that were supplied with Windows XP preinstalled, may not have this utility. This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged: Ntldr
Ntdetect.com
Boot.ini
Check your drives for floppy,USB storage devices,CDs and any other bootable media.Because sometmes these things makes problems.Then go to BIOS and do the BIOS settings to boot from the source where the OS is installed. 1: Insert the Windows XP bootable CD into the computer. 2: When prompted to press any key to boot from the CD, press any key.
5: You will then be prompted for your administrator password, enter that password. 6: From the command prompt, copy NTLDR and NTDETECT.COM from the i386 folder of the CD to the root folder of the hard drive. In the example commands given below, C: is the hard drive and D: is the CD-ROM drive. You will need to change the drive letters if appropriate:
COPY D:I386NTLDR C:
Once both of these files have been successfully copied, remove the CD from the computer and reboot. Windows Vista 1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
7. Type Bootrec.exe, and then press ENTER. You can use bootrec /fixmbr or bootrec /fixboot or bootrec /rebuildbcd according to your situations,
http://www.soluzia.net/ntldr-is-missing.php
Mar 19, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer 5000 will not start up properly
A Windows system file is corrupt.
The best thing to do is reinstalling the system.
This can be done either using original recovery CD, or using Windows setup disk.
To preserve your data you will need to chose partial recovery or upgrade setup.
Windows XP CDs has also a tool called Recovery Console that can be used to repair this kind of problem.
Here the procedure to fix the problem using Windows Recovery Console:
  • Insert Windows Setup CD, then start the computer.
  • When Welcome to Setup screen appears, press R.
  • When asked, chose the Windows installation you wish to repair (eg 1) , then press Enter.
  • When prompted, enter the administrator password .
  • When command prompt (DOS screen) starts, enter the following commands./ (if C: is not your Windows system drive, then change the drive letter)
    ATTRIB -H -R -S C:\BOOT.INI
    DEL C:\BOOT.INI
    BOOTCFG /REBUILD FIXBOOT
  • Remove the Windows CD from drive and restart computer.
Sep 10, 2009 | Acer Aspire 5000 Notebook
How to install windows xp in hp pavilion dv4-1125nr series???
You should install Windows XP that came with your computer with the recovery program that is built-in with an HP computer. The Windows that comes with your computer includes all the drivers and software needed specifically for an HP Laptop.
Here's a link to HP's website outlining all the ways to Recover your Laptop and reinstall your Windows XP Operating System back to factory default including how to create a set of your own Recovery Disks:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00608578&cc=us&lc=en&dlc=en
Feb 01, 2009 | HP Pavilion dv4000 Notebook
Recovery disks aren't Windows XP
Have you tried booting the laptop with the recovery disk already in the CD drive. If the disk doesnt register and start to spin press F12. Should give you option to boot from CD
Mar 07, 2008 | Toshiba Satellite 1135-S125 Notebook
Problem starting windows
Does the recovery CD give you the option to format your C drive? If not, you can try to get hold of a windows XP disk to do this.
Otherwise you might need to swap your hard drive
Mar 06, 2008 | Acer Ferrari 4002WLMi Notebook
Start-up problems
From the sounds of it, you have a problem with Windows or your HD. If it doesnt start in safemode, I'd suggest these things in this order (and each step being more severe, so try your pc after each): take out your battery and unplug the power supply then hold down the power button for about 2 min, resetting your bios to defaults, a HD self test, and then reinstalling your OS via recovery cds or partition. There is a lot of information on how to do all of that on HPs techsupport site. If you dont have a partition, you never received cds, and you didnt make recovery cds, then your going to have to order them from HP for about 20$-40$ Good luck
Sep 20, 2007 | HP NX9010 Notebook
System recovery cds
I think the peoblem is that you need to set the cdrom as first boot device, go into bios (F2 or Del on boot up) and enter advanced cmos settings and you will find that the HDD (Hard disk) is set as first boot device, change this with up/down keys or + - keys to cdrom as first boot device. save settings and exit for a restart with cd in drive.
Aug 29, 2007 | Toshiba Satellite 2415-S205 Notebook
Averatec 6200H Notebook Logo
59 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
