Question about Car Audio & Video
Wiring sony cdx2800 - Car Audio & Video
Iam upgrading my 98 corolla stereo to sony. My stereo says ground wire is brown and aftermarket sony stereo say is black what should i do
Black or black with a white stripe has always been ground. I would check the brown wire with a volt ohm meter. Set it on lowest ohms, Probe the brown wire to any metal part(you may have to scratch the metal. The meter will show numbers. If it reads OL. then it not a ground. Brown wires are always for interior lighting. to include radio. But i have to say, I have never done a 98 toyota.
Apr 07, 2016 | Cars & Trucks
Sony cdx m600 wiring diagram
See the wiring diagram on the final page of this installation manual: http://www.docs.sony.com/release/CDXM600install.pdf
Sep 24, 2013 | Sony CDX-M600 CD Changer
I need wiring diagram for CDX 4000X
Here is a link to Sony for your CDX-4000X wiring pin outs with color code.
http://www.docs.sony.com/release/specs/CDX-4000X_Spec_Sheet.pdf
Dec 06, 2009 | Sony CDX-4000X CD Player
How do I install the Sony MEX-BT2500 wires?
http://www.docs.sony.com/release/MEXBT2500_install_EN_ES_FR.pdf
Here is a link to Sony installation wiring for your MEX-BT2500. You didn't say what car that you're installing in.
Oct 17, 2009 | Sony MEX-BT2500 CD Player
Yellow wirs has come out wiring block which pin
There are two different wiring harnesses possibile for Sony head units. One has 9 pin connector and the other has 16 pin connector. Here are both respectfully.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C285614
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C217600
Oct 17, 2009 | Sony CDX-4000X CD Player
Wiring diagram for a Sony XR-C210 car stero
SONY XR-C210, XR-C214
1-GND
10-+12 VOLT BATTERY WIRE
16-Speaker RF-
5-Speaker RR+
11-+12 VOLT IGNITION WIRE
17-Speaker LF+
6-Speaker RR-
12-Power Antenna Turn On
18-Speaker LF-
8-Speaker LR+
13-TEL MUTE
9-Speaker LR-
15-Speaker RF+
Sep 13, 2009 | Sony Car Audio & Video
Sony mdr v150 wiring plug adaptor 4 wires green,
The green wires go to the left channel (Plug tip). The red wires go to the right channel (plug ring 2 band from tip) and the brass wires go to the ground (sleeve plug base).
May 05, 2009 | Sony MDR-V150 Professional Headphones
Wiring harness for the sony
I would contact Sony, though I am not sure if they will supply this or not, as a missing wire harness is indicative of a stolen radio. You can always try.
Mar 17, 2009 | Sony Car Audio & Video
Wiring Diagram For Sony Disc Player
how do i install a cdx-s2210 to my 92 camry..what wires do i connect?
Jan 02, 2009 | Sony CDX-S2210 CD Player
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
