Question about CASO Germany Caso Microwave Oven - Stainless-steel
Where is the ventilation opening - CASO Germany Caso Microwave Oven - Stainless-steel
GH8155XMQ0
Should be on the back or side of the unit. It is the open part with the vents on it.
May 18, 2014 | Microwave Ovens
Fan Ventilation panel on my GE Profile Spacesaver doesn't operate or close now.
For help with louver operation, see the owner's manual and for further help ask here.
Sep 04, 2012 | Microwave Ovens
What is the cu ft, wattage, size, conventional oven yes or no, all the specs ect of the Kenmore mircorwave model #721.80833500
From the factory manual here:
SPECIFICATIONS
Rated Power Consumption ..............1700W maximum (Microwave oven+Cook top lamps+Ventilation fan)
Microwave Output ...........1100W (IEC60705)
Frequency ....2,450 MHz ±50 MHz
Power Supply .................120 VAC, 60 Hz
Rated Current ................14.5 Amp. (Microwave oven+Cook top lamps+Ventilation fan)
Magnetron Cooling .........Forced Air Cooling
Rectification .Rectification Voltage Double Half-Wave
Door Sealing ..................Choke System
Safety Devices ...............Magnetron Thermostat: Open at 145 °C ±5 °C
Close at 60 °C ±5 °C .....................Oven Thermostat: Open at 110 °C ±5 °C
Close at 0 °C ±5 °C ......................Fuse(20A)
Magnetron ......................2M282J (Toshiba)
Cook top Lamp ...............130 V, 35 W (Halogen)
Cavity Lamp ...................130 V, 35 W (Halogen)
Timer ..............................Digital,up to 99 min.(in each cooking stage)
Tray ..............Tempered Safety Glass
Overall Dimensions ........2915/16"(W)x167/16"(H)x153/8"(D)
Oven Cavity Size ...........231/2"(W)x10"(H)x141/2"(D)
Effective Capacity of Oven Cavity ....2.0 Cu.ft.
Accessories ..Owner 's Manual &Cooking Guide, Installation Manual,
Exhaust Adapter, Exhaust Damper, Mounting Kit and Filter,
Rotating Ring Assembly, Glass Tray, Metal Rack, Guide Tray.
Jul 09, 2011 | Kenmore 80809 Microwave Oven
We purchased a home with the built in model mc0153sf serial # DJ07X01113. we do not have a operators manual. the microwave shuts down when we do a ...
Yes! if the microwave does not have proper ventilation it will go into shutdown, causing it to over heat. The thermal fuse will open if to much heat is detected and can take 30 minutes or more to reset before you can use it again.
Mar 18, 2011 | Microwave Ovens
MICROWAVE IS DEAD. IT CAME ON FOR 3 SECONDS AND THEN WENT DEAD. NO LIGHTS NO CLOCK NO NOTHING. IT IS BUILT IN OVER THE OVEN. IT WAS MANUFACTURED IN 1998.
sounds like you may have a blown fuse. . remove the 2 screws at the hop thats holding the ventillation grill. remove screw holding control panel. push control panel up slightly and lift out. . there should be another metal sheet covering the opening. remove and your fuse should be right behind that.
Feb 04, 2011 | GE JE1640WA/GA Microwave Oven
How do I get the old manual switch out of the Viking VWH3010SS?
To read the manual in your browser, click the respective links:
1. Use and Care Manual
2. Installation Guide
3. Specification
4. Ventilation Guides
In case you wish to download them, open this link (Click Here), scroll down to the bottom of the page, locate these:
And click the "Specs" or "Installation Instructions" or "Use and Care Manual" or Ventilation Guide" to download them. If they automatically open up on your browser, right-click the respective icon names and select "Save as..." from the drop down lists.
You'll need a pdf reader to open the file on your computer, click here to download Adobe Reader.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Dec 09, 2010 | Viking Microwave Ovens
R.kerr
Fan some times makes ratteling noise when it is old and dusty. If you know how to open it remove the fan put some oil in the bearing of fan give external supply to fan and run it for 5 mins. clean the ventilation behind fan if noise goes by oil it is good or replace the fan.
Nov 12, 2009 | Microwave Ovens
I have a friend who has a OTR JVM1850 and does not want to use it for ventilation. Can he use it within a cabinet opening without turning fan on and with ample space for the microwave to breath?
The owner's manual and installation instructions will tell you how much free space must be around the oven for proper internal cooling.
Oct 29, 2009 | GE JVM1850 1000 Watts Microwave Oven
Opening mmv5165ba to clean filters
Unless your Microwave is older, you have a problem. The newer electronic ovens require a lot of ventilation to keep their circuits from overheating. Further, I know of no microwave recipes that produce grease. You may want to get back to me on this.
Ray
Nov 15, 2008 | Maytag MMV1153A Microwave Oven
CASO Germany Caso Microwave Oven - Stainless-steel Logo
12 people viewed this question
Top CASO Germany Microwave Ovens Experts
William Miller
William Miller
Are you a CASO Germany Microwave Oven Expert? Answer questions, earn points and help others
