Question about Intermatic Grasslin KM2ST-2D Timer, 2 Gang 24 Hour Timer with Decora Switch
Grasslin steckotimer PROFI
How to set 24 hour timer
  • 52 Answers
SOURCE: need timer trippers for model 3405 24 hour
Replacement parts at electricalexpeditors.com
Posted on Dec 30, 2009
SOURCE: I need instructions on how
Open following links for analog timer instructions:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM
FM1STUZH-120 is 120Volt 24 hour timer with manual override button.
Each tripper-or-pin on timer dial represents 15 minutes.
The timer can be set for several different purposes.
Since the timer has manual override and NO NC terminals, the best way to proceed is to wire your timer, turn power ON, move 10 trippers-or-pins outward, leave rest of pins inward, then manually rotate dial to watch when load turns on-off. Then move override switch to each of 3 positions and repeat same test.
These actions will reveal correct wiring and switch setting for your purpose.
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jun 05, 2011
SOURCE: grasslin timer doesn't display and it ticks
Grasslin Tactic timers have reset button as last step troubleshoot.
http://waterheatertimer.org/pdf/Grasslin-Tactic-371.pdf
Replacement timer is Tactic 771 Plus
http://waterheatertimer.org/pdf/Grasslin-Tactic_371_Plus_X20.pdf
Posted on Jun 12, 2011
SOURCE: grasslin pin timer how to
Open following links for setting analog timers including Intermatic FM1 series
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM1
Posted on Jul 09, 2011
SOURCE: For a church HVAC ysem, we need detailed
Open following link to identify timer module:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#GM40AVE
Link for FMD 2-channel Intermatic timer
http://waterheatertimer.org/pdf/fmd-50-setpoint-programming-guide.pdf
1-channel FMD Intermatic timer
http://waterheatertimer.org/pdf/GM40AVE-digital-timer-programming.pdf
FMD timers are complex to program, and if timer does not program correctly, then check voltage and polarity of circuit. These timers typically have 1 year limited warranty and can be affected by power surge.
If you have 2-channel timer, then each contact on relay will turn on-and-off at different schedules.
Make sure you don't wire both legs of a 240Volt circuit to to different relays, or the circuit will not turn on-off as expected. To control 240V, just turn off one leg using one of the relays.
If your exact timer does not show, add a comment and describe everything about the timer buttons and appearance, and I will search my files for possible manual.
Grasslin timers were made by GE for many years, and now Intermatic owns the product line.
Posted on Jul 12, 2011
How do I set the timer on my betacom 24c
Copy following link for setting analog timers by experimenting with features:
2) Betacom timer is ordinary 24-hour grasslin analog timer, with moveable trippers located around outer edge of dial, and 3-position switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 24, 2013 | Hardware & Accessories
How do i set a ariston timer 999599
1) Ariston 999599 is ordinary 24-hour FM1 analog timer from Grasslin.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#FM1
2) The timer dial rotates around each 24 hours, and pins are pushed outward or inward to set on-off times, and are dependent on wiring and position of override switch located on front tof timer dial.
Copy following link for setting analog timers.
3) After opening links above, add comment and attach photo of your timer.
Feb 18, 2013 | Hardware & Accessories
L have a Grasslin T35/16 without thr manual want to know how to programm it or use it
Grasslin T35 appears to be ordinary 24-hour analog timer.
Copy following link for instructions by experimenting with timer features
Aug 30, 2012 | Hardware & Accessories
How to set my grasslin pool time trying to understand to let it run in day and shut off at nite about 6pm so i need to set it that way with the pin
Open following link for setting Intermatic/Grasslin FM1 timer setting instructions:
To set the 24-hour analog timer, you need to move 4 consecutive tripper pins for each hour of run time.
So for 6 am to 6 pm, 48 trippers pins will be moved outward and 48 inward.
http://waterheatertimer.org/pdf/How-to-set-Intermatic-FM1-timers.pdf
Open following link for Intermatic FM1 series and PB series modular timers with wiring, manuals, model numbers and instructions for setting.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
Upvote the help.
Jun 08, 2011 | Intermatic FM1STUZH-120U - 24 Hour...
How to set the time and which is on out or in
pins IN = timer ON
pins OUT = timer OFF
Slide-switch must be pushed to right for timer to work
If dial is not rotating, wiring is incorrect (see below for wiring)
__________________________________________
Grasslin and Paragon both offer multiple-gang timers.
Grasslin manual says:
" For example, to turn lights ON at 5:00pm and OFF at
11:00pm, leave inward the 18 trippers between 5 and
11 on the "pm" side of the dial.
Link to Grasslin manual
Wiring timer:
Timer black goes to Hot wire
Timer red (or blue) goes to Load
Timer white goes to Neutral (if no neutral, then connect to bare ground)
If timer dial does not rotate, black and red wires are reversed
Oct 08, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Intermatic Grasslin KM2ST-2D Timer, 2 Gang 24 Hour Timer with Decora Switch Logo
146 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
