Question about Toshiba Satellite M45-S2692 Notebook
Toshiba M45, no display, no boot, display button lights up about 3 seconds.
Toshiba Satellite M45 Laptop. When I press the start button It lights up for about 3 seconds and then goes out. No display, no bios display. I can press any key but the light around the start button goes out again and that is it. I pulled the mother board out but there is no visible problem. I tested the hard disk in another computer and it works ok. Have not tested the ram chip. The power supply is also OK. I also put in a boot CD but it does not boot. Any clues? Thanks, Rainer Luppa, helu1@iprimus.com.au
I have same problem with L30/L35 mainboard
did u find solution for your problem?
/o\
Posted on Nov 02, 2012
Laptop boots up but after nothing.
Hard drive is shot. replace and then re install operating system
Jul 05, 2009 | Toshiba Satellite M45-S265 Notebook
Satellite M45-S169 - will not POST or power on. Power light comes ON for a few seconds then goes OFF. Power ight cycles ON/OFF six times then stops.
Hi rich caller i had this problem also with my laptop toshiba satellite M45-S169 and i find solution for this problem..
Just replaced ram memory and now my laptop works fine hope yours will work too
please respond if my msg helped you..
regards
Bess
Apr 03, 2009 | Toshiba Satellite M45-S169 Notebook
Try booting into safe mode
Press F5 on the keyboard every few seconds when your start the computer.
Go into the Device Manager and remove the Display Adapter ( Video Card)
Restart the computer normally.
Let me know what happens.
Mar 03, 2009 | Toshiba Satellite M45-S169 Notebook
Toshiba Satellite M45-S265 PC Notebook power on button
when did this start
maybe you just need to clean around power button
built up dust and dirt can cause this to happen
Feb 14, 2009 | Toshiba Satellite M45-S265 Notebook
Toshiba m50-mx2 powers up okay but no display
when you have the memory in and you boot up does it look like the hard drive LED is flashing? If so then its booting up into windows and that would mean a bad Display. If nothing happens then try a different stick of good RAM and see if it boots up then, if still nothing then it sounds like a bad motherboard.
Feb 02, 2009 | Toshiba Satellite M45-S265 Notebook
Laptop wont boot
am sorry to say that laptops are more delicate falling from your laps could course alot of damage on the motherboard please visit your nearest service center for help
Dec 15, 2008 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite M45 S331 PSM40U-01R001 will not power on
No.. the problem has nothing to do with your battery....
Yes Quite Possibly the motherboard is fried...
Nov 18, 2008 | Toshiba Satellite M45-S331 Notebook
My Toshiba Satellite M45 laptop
im gussing your computer has ben over heated before and now the fan has ben damaged.
I had the same problem with my computer i took it to the repair man and he replaced the fan and filter and it was now running alot better.
Nov 09, 2008 | Toshiba Satellite M45-S165 Notebook
Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Aug 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Keyboard
Hi this Tony my lap top toshiba M45-s265 is making crazy things,when I prees shift key ,everthing changes .the letter go to caps lock size and the numbers changes to works only the symbols, and when this happens also ,if you go to select any folder in my documents on windows you chooice one folder ,with mouse and set all the folders ,what could be happens
Mar 28, 2008 | Toshiba Satellite M45-S265 Notebook
Open Questions:
BSOD when trying to install Win XP, or boot Win XP from hard drive BSOD screen is as follows: A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: The BIOS in this system is not fully ACPI compliant. Please contact your system vendor or visit http://www.hardware-update.com for an updated BIOS. If you are unable to obtain an updated BIOS or the latest BIOS supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable the ACPI and allow you to continue your installation. Technical information: *** STOP: 0x000000A5 (0x00000011, 0x00000006, 0x00000000, 0x00000000) Every BSOD I received was this exact code. I ran a RAM test with memtest86+, it showed 0 errors. I tried reinstalling BIOS v 1.1 (supplied by Toshiba) and the first time it did let me boot into the XP Home installed on the system, after which it worked fine. While in xp, I checked device manager to see if the system was ACPI, and it was. I've also tried BIOS v 1.2, the last one supplied by Toshiba, to no avail. I did try pressing F7 during one of the installation attempts, and it hung at "setup is starting windows", I tried pressing F5 during an attempt, and there was only one option besides "other", the typical i486, which I selected, after which it hung at "setup is starting windows". I've flashed BIOS with v 1.2 a few times now, with same BSOD during both xp install attempts and boot attempts. What baffles me is the errors did not show up until I tried to install xp for the first time. Before that the computer booted every time. I've never heard of xp effecting BIOS during install. I have been to the microsoft support page for this BSOD. There are two articles on this specific code that I found, one for a "wake from hibernation" error, and the other for an xp installation error, seems as though the latter applies here. URL below. http://support.microsoft.com/kb/314830 I'm fixing this for a friend. I fix computers all the time. This one is getting up there with DELL's laptops. The screen is broken, so I'm using an external monitor. He doesn't want the monitor fixed, so I'm only doing a fresh install + Backup for him. Thank god I already backed up the data. Thank you in advance for your time. (I just got the error again. Gonna try windows 7.)
Jan 21, 2013 | Toshiba Satellite M45-S2692 Notebook
Toshiba Satellite M45-S2692 Notebook Logo
468 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
