Question about Acer Aspire 3680 Laptop
After factory reset blue box showing can't get rid off!!
Have performed factory reset on acer laptop now shows solid blue box tring to install e recovery
  • nut-1 May 18, 2009
    Hi
    Thanks for your assistance with my Acer problem
    I shall try your suggestions
    Jen
Lgl40g straight talk phone will turn on but only loads up to the tracfone blue screen and will not operate at all once it's at that point. Won't power off basically useless completely
try this Recovery
Solution
Factory data
reset
How do I perform a
Factory data reset?
Resetting the phone does not erase
any system software updates you have
downloaded or any files on your microSD
card or internal memory, such as music
or photos. And so, if you want to erase
all the data on the internal memory while
resetting the phone, select the check box
of Erase internal memory.
Recovery
Solution
Hard Reset
(Factory Reset)
How can I perform a
factory reset if I can't
access the phone's
setting menu?
How to perform a Hard Reset (Factory Reset):
1. Turn the power off.
2. When the phone is switched off, press and
hold the Volume down key + Home key
with your left hand. Then press the Power
key while pressing Volume down key +
Home key.
3. LG logo would be displayed in 1~2
seconds then the phone would re-boot
showing android robot animation. Finally
the factory reset would be processed.
Attention:
If a factory reset is performed, all
installed applications and user data will
be erased. Please remember to back up
any important data before performing a
factory reset.
Sep 21, 2014 | Straight Talk LG L40G Cell Phone
How to reboot acer chromebook C710
Follow these steps to reset your Chromebook to its original factory state:
Click the status area in the lower-right corner, where your account picture appears.
Select Settings and click Show advanced settings at the bottom of the page.
Find the "Powerwash" section and click Reset.
In the dialogue box that opens, select Restart.
WARNING: All data stored on your Chromebook such as downloaded files, photos, owner permissions, and saved networks, will be deleted for all accounts when performing a factory reset.
Feb 07, 2014 | Computers & Internet
Unable to conenct to laptop
Performing a system reset might take care of the problem. Reset instructions: Plug in the AC charger and hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset.
Below is a link to the Backbeat 903 User's Guide for more information.
Plantronics Backbeat 903 User's Guide
Good luck from Headsets Direct!
Aug 02, 2011 | Plantronics Backbeat 903 Bluetooth...
I wnt to know how to reset the computer
Assuming the netbook is working normally, and it has the original hard drive that was in it from new, there should be a recovery partition present on the hard drive.
When you switch the machine on, press and hold the Alt button and F10 while the Acer logo is showing. This should give you access to the Acer Recovery centre. Alternatively, boot to Windows, click the start button, All Programs, Acer and Acer eRecovery Management.
Please note that factory recovery usually completely wipes any user data, so back up any important files before performing the recovery. Recovery will restore the machine to the factory installation, so you will also lose any third party software that has been installed since the machine came out of its box.
Jul 24, 2011 | Acer Aspire One D255 Netbook
How do i reset my laptop back to factory settings
The disc that you should have received with the laptop should give you this option. Just put it in and reboot and it will bring you to a menu with a few different recovery options to choose from.
Feb 28, 2011 | Acer Aspire 5500 5570-2609 Laptop
Screen problems
I reset my acer to factory default now the screen is black and showing "starting set-up but never clearing screen
Jan 22, 2011 | Acer Aspire One 10.1" Netbook Computer -...
I was trying to recover an Acer Aspire one Zg5 laptop (with Win XP Home Edition) to its factory state usin Alt + F10 since the eRovery program wasn’t working. It finished the process but when it was...
Hi, As per the description of the issue that you have provided ;even after performing a complete factory restore you are unable to get to load Windows and you get a blue screen to flash for a few seconds.This is an issue possibly related with the Hard drive or motherboard in the laptop.So i would suggest that if the laptop is covered under warranty please contact ACER so that the repair could done under the warranty.In case the warranty has expired I would suggest that you contact a local technician at your place who would be able to assist you with the replacement. Thank you for your time and best wishes for your effort.
Jan 06, 2011 | Acer Computers & Internet
How to restore factory recovery system
If you still can boot it in windows, follow this:
Step 1: Click “Start” menu.
Step 2: Click “Programs.”
Step 3: Click “Acer Recovery Management.”
Step 4: Click the “Restore” button on the bottom of the dialog box that opens.
Step 5: Click “Restore System to Factory Default.”
Step 6: Click “Yes” in the warning dialog box which asks if you wish to continue the recovery process.
Step 7: Click “Start” to restore the computer to the default factory settings.
If you can not boot to windows, follow this:
1. Restart the laptop
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to enter the recovery process.
3. Follow the on-screen instructions to perform system recovery
May 10, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer pd100d does not receive signal from pc or laptop, changed cables too. only shows white screen with acer logo and no signal, worked until yesterday, buttons dont respond and cannot reset the unit to...
acer pd100d does not receive signal from pc or laptop, changed cables too. only shows white screen with acer logo and no signal, worked until yesterday, buttons dont respond and cannot reset the unit to factory defaults. please help
Dec 24, 2009 | Acer PD100 Multimedia Projector
Acer Aspire 3680 Laptop Logo
76 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
