Question about Maxtor 80gb 7200rpm ATA 133 IDE HDD p/n MX6L080J4 Hard Drive
Harddrive monitor error
I have 2 maxtor drives both are giving me HD error. I have placed 1 at a time in and still getting the same error. What could be the problem?
Thank for your help
In Desperate Need
  • JB Oct 17, 2007
    1 is a Maxtor are 200gb and the other is a Maxtor 80gb
    Novelist:
    Champion:
  • 382 Answers
Placed them IN a computer or enclosure?
Posted on Oct 22, 2007
SOURCE:
Can't read HD-- I/O error
"Joecolvette" has probably got it right, I've seen this before. The HDD enclosure circuit board has a fault. Can be resolved by replacing the enclosure. Plenty on ebay, just ensure you buy one with the correct HDD interface (Sata or IDE).
Alternatively, if you have a tower with a spare port, you could take the HDD out of the caddy, install it in the tower as a "Slave" (check jumper settings) ensuring the system drive is set to "Master". Then you can check whether the HDD itself is at fault.
Apr 28, 2012 | Maxtor Computers & Internet
Maxtor 3200 Won't back up any longer. Says error, cannot backup
It may be corrupt with bad sectors if so go to mycomputer right click the maxtor drive goto properties then tools and select check drive for errors.
Maxtor are awfull, do your self a favour and replace it with a weston digital. If a harddrive starts getting errors its just a matter of time before it gives up completely
Nov 13, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
The Maxtor harddrive was moved and the plug got jiggled so it wasn't showing on my pc...I fixed the issue, then kept getting an error message "checking dish one touch" with 2...
Open My Computer
Note the drive-letter assigned to the Maxtor
Close My Computer
Click Start
Click Run
Type CMD
Press Enter
If the drive-letter was 'E:', type 'E:'
Press Enter
Type ATTRIB -H -R -S *
Press Enter
Open My Computer
Double-click the icon for the Maxtor
Does it still show "zero" files/folders?
Does it show a 'FOUND' folder?
What file(s) are in that folder?
Nov 02, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Can`t install a O S on a new hard disk
you will need to run fdisk. to create a partition on the HD .
then format the drive c:
you can use any partition creator software
May 14, 2010 | Acer X193W LCD Monitor
Cannot get external hard drive to work
- Make sure that the hard drive (HD) is properly connected to the computer.
- Try connecting it to a different computer to make sure that the HD is the problem.
- Check the Disk Management in your computer to see if the HD could still be detected. Once detected, reformat the HD and it should work again.
To check the Disk Management:
NOTE: Make sure that the external HD is connected and turned ON.
1. Right-click "My Computer" (XP) or "Computer" icon (Vista)
2. Select Manage and click on "Disk Management".
3. From the Disk Management, you will see a drive letters
4. Write down all the drive letters and then disconnect the Maxtor HD from the computer.
5. If there's a drive letter that disappears, then that is your Maxtor HD.
6. Reconnect the Maxtor HD and reformat it. You may right-click the drive letter and there's an option to format the HD.
If you're hearing a clicking sound while the HD is turned on, mostly, it's already defective.
Have a great day!
Oct 17, 2009 | Maxtor Hard Drive
Vista is not picking up my maxtor harddriver but wheni had xp was .
Check the disk management MMC - it's likely that you have another drive letter that is conflicting with the Maxtor.
1. Right Click on the Computer Icon (or in the menu),
2. click on Managment,
3. look for Disk Management(on the left side) and click on that.
4. This will show you all the installed HD's that you have.
Your main HD is probably called Disk 0. IF there are any other HD's listed they will probably be labled "removeable", if it doesn't have a drive letter assigned to it do the following:
1. Right click on the Disk (X) that does not have a drive letter. (it should be a "Removable Drive")
2. Select Change drive letter and Paths.
3. Choose a drive letter from the list that is not used, I suggest W or Z just to be sure.
4. After you do that it should come up in My Computer as an available drive.
IF the External Drive is not listed then you need to change the USB port or try it on another PC to see if it works there.
May 30, 2009 | Maxtor OneTouch 4 Plus 500GB External USB...
Maxtor 80GB External HD
1. I need to know the brand name , model number , or motherboard you have
2. I need to know what operating system you are using
and when you say open , in what manor do you mean open , in what way are you attempting to open the drive and with what program , so far it looks like you may need to reinstall the computers operating system from scratch , because something is dead wrong , and it looks like a file system error , as if your computer operating system is no longer able to access files properly.
I consider your situation unresolved at this time untill you can give me more information.
I'm trying to reach guru status here in order to help people like you in a far more proper manor.
together we can solve it.
shalom
Aug 05, 2008 | Maxtor Hard Drive
Did a system recovery on pc now can't find my harddrive
Hi Shannon,
yes, you could - and should - connect the external harddrive directly to your pc in case it throws errors. You will need to do this in any case to figure out, what is wrong with the drive.
Connect the USB cable to your PC and check whether the drive is recognized by your Operating System. If it fails to be detected get back to us and we will try to help you.
Jun 30, 2017 | Maxtor OneTouch III Mini Edition (R01E100)...
Maxtor One Touch
The harddrive itself has gone bad, only solution would be to replace the HDD inside the enclosure :-( sorry.
Sep 15, 2007 | Maxtor OneTouch II Hard Drive
Reg: User creation and folder creation problem,
Possible solutions.
1- Reset your harddrive using a pin through a little hole behind the drive.
2- Update the hard drive bios
3- download the lattest drivers.
Aug 17, 2007 | Maxtor Shared Storage II (S01R320) Hard...
Computers & Internet Logo
80 people viewed this question
Top Maxtor Computers & Internet Experts
Phil Whisenant
Phil Whisenant
Alun Cox
Norman Al-Anbar
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
