Question about Furniture
Braxton 7 piece dining set - Furniture
5 piece counter height dining set - cherry: can you buy replacement chairs/stools anywhere? One of ours got knocked over and basically broke
many home improvement stores sell replacement stools /chairs . only you can go to them and see what they have .
Jan 26, 2017 | Furniture
One of my nook dining set boxes was missing the hardware for the bench. Who do I contact to get it replaced?
Hello
Best way to get support is to contact the place from where you bought it. They might have extra parts or they will give you a replacement. If you bought it off from someone then you need to find from the other part like a screw and go to to a hardware shop and ask them to get you similar part.
Apr 10, 2014 | TMS Furniture Furniture
Where can I see a good example of how to set up a floor vase in my kitchen?
I love these. This picture inspired me to add floor vases to my dining room.
http://www.houzz.com/photos/881231/Modern-Dining-Room-modern-dining-room-toronto
Feb 27, 2013 | Home
I want to build my own set of dining room chairs. Can someone recommend a good site to use with design templates?
I found you a site with designs for both standard dining room chairs and chairs with arm rests. Hope this helps you out.
http://www.freeww.com/diningchair.html
Aug 09, 2012 | Furniture
No sound to remote speakers in dining & deck areas.
Incoming from WHAT? Ampifiers accept inputs via RCA connections and send amplified audio to the speakers via the + and - OUTPUT terminals.
I'm guessing your colored wires are from your speakers and that there is a piece of this puzzle we do not see - how the speakers on the deck and in the dining area are wired.
You say, "was working ok previously"... previous to WHAT? Something changed.
You can probably troubleshoot and resolve this yourself.
Set the amp to a medium output level.
If the wires are simply leading to either or both pairs of speakers you could select any two of them and connect them to one side of the amp. Only a pair going to the same speaker(s) will produce sound. Once you identify one pair, the other pair probably goes to the other speakers. Connect them to the other channel output.
The last piece would be to establish correct phasing between the speakers. Bass response will suffer if they're not IN-phase. Play something with substantial bass. Listen closely, then reverse the wires on one side only. Test again. If it IMPROVES you have it right. If it losses bass, put the wires back the way they were.
Apr 27, 2010 | Rotel RMB-1095 Power Amplifier
Furniture Logo
89 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
