Question about Braun Tassimo Espresso Machine/Coffee Maker
The 4 lights continue to blink and never stop.
I've unplugged for overnight hoping to reset it but nothing changes.
Hello Margaret , Dont panic i got my machine yesterday and used twice and this happened, I just read about circuit boards ect and thought oh great but i turned machine off at wall and then turned back on pressed the one button and let it flash red without touching it walked off for a couple of minutes when got back it had turned green .... I am now sitting writing this with a lovely cuppa . I think i am going to try not turning it off at the wall just keep it on all the time and see how that goes . I hope this helps x
Posted on Dec 27, 2013
Steady blinking green light on Mitsubishi LCD model LT 55164
I also have a Mitsubishi LT 55164 with blinking green status light...does nothing else...reset does no good, also tried to reload software with no difference. Replaced power and inverter boards button stop the same. No obvious bad components on boards. Help! Anyone ever actually fix one of these?
Aug 29, 2015 | Mitsubishi LT55164 55 in LCD TV
There is a blinking red light next to power button.Panasonic tv will not turn on.
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Hopefully it eventually stops blinking after unplugging set from the outlet, otherwise claim your Nobel Prize for wireless energy transmission.
Oct 17, 2014 | Panasonic Viera TH-50PZ80U Plasma TV
My at&t Motorola 3360 has every light blinking but is still working. The Power and DSL are continuously blinking red and the ethernet, internet and activity are all blinking green.
Here's the thing...if the modem is unplugged, and you press the "Reset" button, or any button, nothing will happen because the modem is UNPLUGGED.
When you plug it in again, there is usually a few minutes or so during which time the lights will blink. Eventually, when the DSL connection is established, the blinking should decrease. But, there will always be some blinking going on to indicate that data is being transmitted.
If the "Ethernet" light is blinking, then a computer that is plugged into the router is transmitting/receiving data. If the "Wireless" light is blinking, then a computer that using a wireless connection to the router is transmitting/receiving data.
If a red light blinks, then that usually means the DSL connection has been broken. When that happens, for whatever reason, the modem will automatically begin its initialization routine and will continue to do so until connection has been established. During that time, LEAVE IT ALONE.
If you uplug the device, or if you press ANY button while the device is attempting to correct itself, you can cause permanent damage.
So, you are correct. It's not a problem. I'm sure you've heard the phrase "If it's not broken, then don't fix it." There's a lot of truth to that.
I hope this helps.
Randy
Dec 01, 2012 | Arris 3360 AT&T DSL Modem - -
How do i reset a Mitsubishi WD-73737 73 in.
The green light blinking is the set trying to boot up especially if power lost---70 seconds and should stop. Here is a link to a question I answered that might be helpful:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Aug 28, 2012 | Mitsubishi WD-73737 73 in. HD-Ready TV
Green timer light won't stop flashing on mitsubishi ws 73711.
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
SD TECH
May 06, 2012 | Mitsubishi WS-73711 73" Rear Projection...
The program light won't stop blinking
Same here. I'm dead in the water. This started happening a few weeks ago and with patience and luck and different combos of buttons I'd get it to stop and I was able to brew. Today it just stopped completely. The program light either blinks constantly or stays lit constantly, but I cannot brew coffee. I see lots of people online with this problem, but have yet to see a solution.
Dec 08, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Green (power on) light continuously blinking/set won't turn on
This set was designed in such a way that when it is unplugged and plugged back in the LED will blink for around 90 seconds and then stop. During that time you cannot turn the set on. This is the amount of time it takes for the Digital Module to boot up. These units have a problem with some capacitors going bad in the Digital Module and when that happens the LED never stops blinking. You need to contact a qualified repair shop to get it repaired. I have repaired many and the cost is around $250 to $350 depending on where you live. That set is well worth the repair cost.
Jun 02, 2009 | Mitsubishi WS-65613 65" Rear Projection...
The stand by timer blinks continuously
Unpluggnig the set will reset some things, but not an error code. The 4 blinks usually means a lack of vertical deflection. If you can solder, you should be able to fix this yourself. Be warned however that there are dangerous high voltages inside the set even when unplugged.
That being said, try locating the vertical IC which will be a small flat IC attached to a heatsink that will be marked LA7837 or something similar. Try resoldering the pins on that IC first. If that failes to resolve the problem, replace the IC and post your results here. There may be other components that need to be replaced, but they will show up as other symptoms once the IC is replaced.
Dan
Jan 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Braun Tassimo Espresso Machine/Coffee Maker Logo
89 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
