Question about T-Mobile BlackBerry 7105t Cellular Phone
7105t White screen of death
EBay KM-Electronics - brand new 7105t
Charged battery - device remain on white screen forever
Disconnect / re-connect battery - same problem
Is there a way out?
  • 1 more comment
  • alan_gen Nov 18, 2007
    After putting the battery back in the device, the white initialization screen appears with an hour glass. After that, the home screen menu is expected, however, it only shows a white screen. However, if I use the track wheel, the home menu appears for milliseconds only to be replaced again by the white screen. i have changed done a firmware upgrade to 4.2 but the error remains. Done Alt+Del+Num key sequence for a hard reset - no difference.
    Left the battery & device out overnight - no difference.
    Used a hair dryer to remove remaining moisture after 10 days of this error - no difference. It seems to be a software error but i can't seem to get rid of it.
  • Anonymous May 08, 2008
    My cell screen is white.
  • cj147 Jul 08, 2008
    I have a similar problem except mine just has a white screen (no hourglass).Interestingly enough, if i leave the white screen there, the alarm will go off.
    Tried battery removal, no help. It had been this way for a month
Why won't my HP F340 all-in-one printer print photos in color, only B&W. The test page does print in color however
Make sure you are selecting color. Mine will do either way. There should be a selection on how you want it.
Jan 10, 2015 | HP Deskjet F340 All-In-One Printer
All i have is white screen
No, replacing the battery will have no effect. Even if the battery was dead and even removed from the unit, plugging the unit into a charger or wall adapter effectively bypasses the battery. You will see that the problem will remain. A white screen can be caused by several things:
1. A defective LCD display.
2. A boot-up issue.
3. A partially disconnected LCD display where the backlight is still connected, lighting up just the background.
Please see this site for more info on LCD & boot-up issues.
SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Mar 09, 2014 | Garmin Nuvi 40
Firmware for sanyo e1292
I purchased (used) the exact same camcorder from eBay. It arrived. Same deal as you described - turn "ON" and white screen appears. SO, I went out and got a new battery. Charging it now, so I will let you know the result after charging. This is my LAST go around with this. Normally, I would never buy a camera from eBay, but I've bought so much other stuff I have not had an issue with (including new & used electronics.) Will keep you posted.
Feb 10, 2012 | Sanyo Xacti VPC-HD2000 High Definition...
The screen comes on but doesnt show anything, just becomes white. Its a brand new Archos 4 GB MP3/MP4 visual player, purchased from the States. When i connect the player on the PC, it shows everything, but...
Screen being white sounds like a bad connection on the display panel on the device unfortunately. I suggest contacting the manufacturer for a warranty repair if it is new.
Jun 05, 2011 | Archos Vision A14VG Digital Media Player
LCD ACER LAPTOP. YOU CAN SEE ONLY WHITE SCREEN. LCD FOR REPLACEMENT. WHERE TO BUY CHEAP PARTS. TH
> only white screen
It may possibly be a loose connection of the ribbon-cable between the motherboard and the LCD.
Check both ends of that ribbon-cable, before spending $100 for a "pre-owned" screen, or $250 for a brand-new screen.
Inexpensive parts, if you really need them, can be found on eBay's web-site.
Jun 01, 2011 | Computers & Internet
I dropped my samsung in my sink and i picked it up and took out the battery and let it dry and about 30 mins after i put the battery back in and up comes a blank white screen and it keeps vibrating how can...
Once a phone has been water damaged it will never work properly again. Water - even fresh water - contains salt. And, salt is an excellent conductor of electricity. When the water evaporates, salt deposits still remain. This causes the phone's electronics to short circuit causing a variety of problems.
The cost to repair the phone will far outweigh the cost to replace it. Repairing it does not mean that it will continue to work properly.
My advice is to sell the phone on eBay for parts. Let the buyer know it has suffered water damage. And, replace it with a new phone. You'll be much happier in the long run.
Feb 16, 2011 | Samsung SCH-U450 Cell Phone
I have a Sony HD2000 camcorder. When using it the other day the screen went white. On and off buttons still work but all I can see is white.
Jan 31, 2011 | Sanyo Xacti VPC-HD2000 High Definition...
Insignia 26 inch TV/DVD Combo produces strange odor when on.
You should never have an acrid or burning smell coming from electronics. I'd return the unit, if that is still an option, as it is about to fail.
Feb 13, 2010 | Insignia IS-LCDTV32 32 in. Television
Cracked touch screen on TomTom
Your best option is Ebay
Prices are pretty good and there are a lot of reputable dealers with BRAND NEW parts.
Replacing them is also pretty simple to do yourself but if you feel uncomfortable I am sure a local electronics repair shop could do it quickly and cheaply.
Aug 31, 2009 | Tomtom GO 300 GPS Receiver
Blackberry Bold 9000 white screen
Have you used it successfully yet (you said it was brand new).
It may take a while to run in the first time you use it, but you might also have a bad firmware update, suggest downloading a fresh copy of both DM and device firmware and start again.
Aug 03, 2009 | RIM BlackBerry Bold 9000 Smartphone
T-Mobile BlackBerry 7105t Cellular Phone Logo
149 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
