Question about Movado Watch, Mens Metio Stainless Steel Bracelet 0606203
I have Movado metio watches model#0606203 and i need link.
Model #0606203 Movado Metio watches.How can find links.
  • 21 Answers
SOURCE: size a movado valor 0604409 smaller to fit my wrist.. Anyone??
xxxxxx
Posted on Jul 23, 2009
SOURCE: Movado Cronograph - Can't remove pin!
you need to push it thru wit a ling "needle type" toolin order to get it out. it has to be strong enough so that it doesn't bend also because it's quite stuck in there pretty good. thats part of the quality you get from a movado.
Posted on Jul 24, 2009
escapement
  • 2334 Answers
SOURCE: How do I remove links on a Movado elliptica?
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jan 09, 2010
mcdevito75
  • 1970 Answers
SOURCE: remove links on Movado Rondiro #605499 to make the
mcdevito75 here, By the time you recieve the special tool needed to reove the links you can have a small watch repair shop in your area do the job.
Posted on Jul 01, 2010
SOURCE: how do i get extra links for a concord veneto
Go to watchbands.com, enter your model number and bracelet size and problem solved!
Posted on Nov 26, 2010
Does the Movado ladies watch serial number 74259821 836092 have a solid 14K wrist band?
The 74259821 is definitely a 14k solid gold watch. I have one, too, and need an extra link for it if anyone out there has one. 267465b2-5058-4a86-99d3-8e2eb936415b.jpg 83ef6643-49bf-4f76-97f1-639d71b4c025.jpg
Sep 15, 2014 | Movado Museum Watches
Were do i get links for the Movado Lumeti #0690996?
Go to http://www.movado.com/customer-service/parts-and-service/ and scroll down to "can I order spare links..."
You are luck, not many makers who offer such a service, in spite of the obvious need for extra links.
Feb 09, 2011 | Movado Lumeti 0690996 Watch for Women
How do I remove a steel link from a Movado wristband 800 series?
mcdevito75 here, Special tools neede to remove links, Best Bet look for a small watch repair shop in your area, and hold onto those links once removed as you may need them again in the future.
Oct 16, 2010 | Movado 800 Performance watch
I have a movado watch the serial number is 84 e7 1850 I want 2 know if its real
As with luxury bags, luxury watch brands such as Movado are copied and sold illegally. Movado watches are popular among both men and women, but sellers of replica watches hurt the brand by providing the buyer with poor craftsmanship. Dealers know what genuine Movado watches look like, and they are familiar with the watch model names and numbering system. While you can take your watch to a dealer to closely inspect its authenticity, you, too, can learn how to tell if your Movado watch is fake by noting a few details.
Check the material the watch is made of. Replica watches are made of aluminum, and they don't have the same heavy weight of an authentic Movado. Movado watches should feel like quality, solid pieces. True Movado watches are made of stainless steel.Observe the movement of the watch. The movement of the second hand should not be erratic or shaky. It should look smooth as it travels across the face of the watch.
Look closely for scratches on the glass face. Movado watches are scratch resistant, so any imperfection on the face is a telling sign that it's fake. Hold the face to the light and observe if it gleams like a genuine watch. If it's dull or cloudy, it's not authentic. Also, look for the inscription "Swiss Movado Made" to make sure it's authentic.
Feel the links and the clasp on the watch. Clasps should feel solid, and the links should be joined together by screws. Gently pull on the clasps and check for any loose pins. If the clasps feel fragile, it's probably fake.
Jul 16, 2010 | Watches
Remove links on Movado Rondiro #605499 to make the bracelet smaller
Jul 01, 2010 | Movado Rondiro 605964 Wrist Watch for...
How do i get extra links for a concord veneto
Feb 10, 2010 | Movado Concord Saratoga Chronograph Watch...
How do I adjust the watch band on a Movado luna model
If you check my tips here, you will find out how to remove or add links.
Feb 04, 2010 | Movado Luno 0605635 Watch
I NEED TO ADD 2 LINKS TO MOVADO WATCHBAND .THE CASEBACK # ON WATCH IS 88.E2.887.2.the #on band is v144.g.2
An authorized Movado Retailer can order the links for you. you can locate a local retailer on www.movado.com
http://www.movado.com/FindARetailer.aspx?
Jan 21, 2009 | Watches
Broken Watch band
you probably just need a pin to secure the links back together. an authorized Movado retailer will have the tension or screw pins to put the band back together. They can also order additional links if needed. you can find a local retailer on www.movado.com
Jan 07, 2009 | Watches
Movado Watch, Mens Metio Stainless Steel Bracelet 0606203 Logo
50 people viewed this question
Top Movado Watches Experts
Jimmy Accardi
Are you a Movado Watch Expert? Answer questions, earn points and help others
