Question about Water Heaters
I have a Sime Super 90 Combi Boiler. How do I start the pilot light? Thanks
  • Anonymous May 18, 2009
    I have the same problem. Have you managed to find out how to light it?
    Cheers
    Rob
  • 332 Answers
Does it have a little red button on the right hand side of the gas valve? if so you must put the gas valve button in the pilot positon and push it down and hold it, then click the red button {push it down} it will click and look at it keep clicking while holding down the button on the gas valve eventually when the gas gets thru it will light could take several clicks of the ignitor
Posted on Jun 21, 2009
Sime boiler pilot light
Sounds like an old boiler. It is not on timer and has to be lit manually. Push in the gas button and hold and push the sprung ingnition button to greate spark. Continue to hold in gas button 1-2 mins and release. The pilot light should then stay on. The flame will have heated the sensor in the combustion chamber and the boiler thinks that there is a flame and will allow the main gas jets to light when demanded . If the flame does not stay on clean the sensor prongs with emery cloth but do wait until they are cooled. You have open up the combustion chamber for access
The 1-2 mins above varies
Apr 07, 2014 | Water Heaters
Combi boiler (vailant), pilot light not igniting; boiler firing etc o.k
hi there
does the fan start up?
sounds like a faulty gas valve. has there been an interuption in your gas supplie?
hope this steers you in the right direction
Dec 19, 2010 | Water Heaters
New sime e comfort 25HE boiler problems
It not wired in right that why its coming on when it is off The boiler is over riding the programmer when it is off .
The boiler should call for heat if programme is on it sounds like boiler is wired into the 24hr mode or over ride mode that why it is coming on . google wiring for y plan heating system. this will help you fault find on this . changing vales and thermostats will not help you . Hope this helps .
Mar 05, 2017 | Water Heaters
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
I can only get hot water when i turn the heating on! the boiler is a sime super 90 plus (so it says on the front). i have turned all the radiators in the house off, am i causing damage doing this?
It sounds like you have a bad aquastat, if you have steam heat, and you have closed off the radiators, it will not cause a problem, it will just shut off when you build a couple psi of pressure. I would not recommend the same on a hot water boiler, because it could cause problems if you start making steam. Hope this helps.
Jun 17, 2009 | Water Heaters
Heating not working properly on my sime super 90 combi boiler
you need 15 lbs water press,bleed air from system, primary must be bad
Mar 29, 2009 | Water Heaters
Sime Domestic Boiler
could it mean circulation alert!!!
Mar 22, 2009 | Water Heaters
Pilot light on boiler
The plumbers repair should be guaranteed, give him a call back.
It sounds to me that the pilot flame needs to be adjusted or the thermocouple is not aligned properly or there is a draft that is blowing out the pilot.
Good luck...
Feb 22, 2009 | Water Heaters
Water Heaters Logo
2,013 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
