Volume from some stations very low. Have a Cignal box
THE VOLUME FROM SOME PROGRAMS ARE VERY LOW. But when I play a DVD the sound is good and loud.I have a cignal program box. the sound in HD is good the problem seems to be with Philippine TV stations
techman
  • 3130 Answers
SOURCE: emerson vcr #vcr755
have you tryed to clean the ace head??? The ace head means audio-control-erase. and is on the right side of the mechanism. this head looks like a big cassette type head and is statioary. This head can be cleaned just like an 8-track{remember those??}or cassette head by applying rubbing alcohol to a q-tip and clean the head from top to bottom. this head also may need cleaning if your tapes seem to speed up and slow down for no reason and at random. Thats because the lower part of the head is the control head and that gives the machine pulses to tell the machine what speed the tape is recorded in then the capstain motor has an fg sensor(freqency generator} and they all go thru a comparitor and the sum of both pulses gives the machine the proper speed setting. Hope this was laid out in understandable english. Good Luck
Posted on Apr 26, 2006
SOURCE: Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Posted on Oct 05, 2007
SOURCE: low volume when volume control turned all the way up
I just had the same problem. Unplug the both the TV and the cable box for 5 minutes.
Posted on Mar 01, 2009
  • 14 Answers
SOURCE: Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Posted on Apr 10, 2009
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
Tv volume too low
Sometimes there is a volume on older cable boxes. Unfortuanately adjusting the volume can be a chore because most cable remotes are volume locked to the TV input. You can try and press the cable button on your cable box remote and see if the volume will adjust, if not I would call your cable company and see if they can help, and possibly replace the box. Usually you can take the box to a store for your provider in the area and they can swap it out.
Apr 06, 2014 | Toshiba 32LV67U 32 in. HDTV LCD TV/DVD...
Low volume on radio, I replaced the amplifier with an used one, but the problem still present. All channels are Ok.
When you tried play a cd and you got low volume with amp, 1. Try find a original cd and plays it see if the sound loud or low if it's still low you need lenses disc cleaner, to clean your decks lense.
Oct 15, 2013 | 2004 Acura TL
No volume sound very low at maximum
Look both at the set and the Box if used (cable or sat) to make sure volume is not turned down---also a receiver if used can do the same thing.
A quick low tech test is do you have the same problem when playing a DVD etc.
Apr 24, 2012 | LG 42LC2D 42 in. LCD HDTV
Very low audio sound from recorded dvd
Could be the way it's connected, scart leads are good at causing problems! Does the box have a volume control? If so turn it up and leave it alone then. If you need to adjust the sound when watching use only the TV volume control.
Apr 05, 2010 | Televison & Video
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
Low volume on some channels
Well, some TV stations do broadcast at different volume levels. This is very noticeable when watching a TV show and the volume seems normal and then when a commercial comes on, the volume is very loud. They do this to get you to pay attention to the commercial. Another problem might be that you are adjusting volume from both your TV and your cable box. What you should do is make sure your cable box is set to "FIXED VOLUME" and then just adjust your TV volume. Fixed volume will have the cable box output only one volume level, letting the TV do the adjustment. Just go through your cable box setting and look in the audio settings. Hope This helps...
Mar 14, 2009 | Element Electronics FLX3711B 37 in. LCD TV
K750i low volume in the playback ,please give me a solution
Well... The speaker is ok and if you're using the headset it should be loud enough for you. If you want it to be louder just use earphones/headphones that are sound isolating to block out ambiant noise. The hpm-70 can kinda do that because they go in in your as opposed to sitting on the outside of your ear. The earpiece volume is really loud. I found it hard to hear to people in some places.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Jan 15, 2008 | Sony Ericsson K750i Cellular Phone
Aug 18, 2007 | Bose 3 2 1 GSX System
Low volume
Hi federmagico If you have not clean the lens do so now if that does not work call a tech the problem could be the lens.good luck.
Apr 25, 2007 | Sony HT-DDW670 System
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Electro Med Services...
