Question about iRiver H320 MP3 Player
Problem copying songs to iRiver H320 music player
I have an iRiver H320 digital music player. When I connect it via the USB cable, it appears as a disk drive. When I first got this player, it was easy to copy songs by dragging folders over to the drive. It worked fine. Now every time I try to do that I get a "cyclic redundancy check" error. I can't copy ANYTHING to the player. I even upgraded the firmware and reformatted the drive. Now it has nothing on it, and in my attempts to copy the music back to the drive (the same music that was already on it, plus some additional) I get the error message. I have tried also syncing with Windows Media Player. That worked for awhile, and I got some files onto the player, but then it also stopped working. iRiver has no support whatsoever, so I am left stuck with a useless player and no one to help me. I don't understand what that "cyclic redundancy check" error means.
  • Reedem Oct 17, 2007
    The solution offered by Sparkgap didn't work. The same problems persist.
    New Friend:
  • 5 Answers
Check the pins inside the usb "on the player" could be damaged .
Posted on Oct 07, 2013
  • 1,006 Answers
First format with cmd
Go start run then write cmd and chkdsk f:or d: or e:...
then try to install those updatet driver :
http://drivers.softpedia.com/progDownload/Iriver-H-firmware-Download-10026.html
http://drivers.softpedia.com/get/FIRMWARE/Iriver/Iriver-H320-firmware-127.shtml
Posted on Oct 18, 2007
  • 363 Answers
This sounds like a drive error.
Try right clicking the drive in windows explorer  then properties>tools>error checking>check now and tick both boxes and then start.
Posted on Oct 17, 2007
  • Martin B
    Martin B Oct 18, 2007
    Bit confused, I got an e-mail saying I solved this problem.
    Anyway since I'm here I'll help a bit more.
    CRC errors are generated when the written data is not the same as the data read back.
    I think your iRiver has a disk drive with bad sectors (useless areas on the disk)
    This could be a sign of impending disk failure due to mechanical problems or simply the result of dropping or shock, making the head crash onto the disk and scraping it.
    Once a disk checker has completed it should mark the areas as bad and the disk will then avoid using the damaged areas.
    Another possibility- there could be a problem with the data stream to or from your PC via the USB where an intermittent error could be occuring during copying.
My H320 does not appear to work with windows vista. It will not accept new music now i have upgraded my PC to windows vista.There is still plenty of space left on the harddrive of the Iriver. Any new music...
Windows Vista is a new program with tons of errors on it because, in order to reach the due date,they didn't fix the problem and just gloated how the finished it on time. So there's a good chance that Vista is the problem. Could you use the H320 when the PC did not have Vista on it?
Dec 02, 2008 | iRiver H320 MP3 Player
Iriver h320 over heating
well since you copied your files..........now copy the iriver software (hidden too) and paste to a temp file (folder) on pc...fortmat the 320 now place the software back onto it from the temp file........and put 2 or 3 songs unto it also (to make sure it was done correct)..press play if all is well...include all your files back on to it.......a little bit late but feel free to rate the help
Aug 19, 2008 | iRiver H320 MP3 Player
IRiver H320
http://www.misticriver.net/forums/h3xx-series-320-340/11314-fixed-h320-always-connected-prob.html
solved
Jul 17, 2008 | iRiver H320 MP3 Player
Movie conversion
The H300 series (H320, H340) does not support movies.
Jun 07, 2008 | iRiver H320 MP3 Player
Iriver H320
there is a setting somewhere that stops it charging when you connect it to a usb port on the computer.
May 08, 2008 | iRiver H320 MP3 Player
CLUELESS IN NY, IRIVER H320
You have to hit the on button twice to show as connected,then you can manually move files to the root directory by going to the computer ICON on your desktop, finding your MP3 player,then clickto open the file - the find thefile you want to copy or move onto the MP3 and drag it into the MP3's main file NOT the file that says RECORD
Nov 07, 2007 | iRiver H320 MP3 Player
Cannot Load Songs onto iRiver H320 Player
1. if your player is not working properly just reset it by using paper clip on the hole and press down the player will turn off then try again
Oct 17, 2007 | iRiver H320 MP3 Player
IRiver H320 fails to power up
I too have that problem, or it insists I remove external battery, I went onto the official site and they were no help. I've not really tried this link, but somebody told me to try it maybe it's a battery fault http://www.hyperbattery.com/indexmain.htm Hope this helps, if so let me know The_Ultimate_Power@hotmail.com Ste
Oct 01, 2007 | iRiver H320 MP3 Player
iRiver H320 MP3 Player Logo
110 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
