Computers & Internet Logo
Posted on May 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E: Access Denied when I connected a Flas Drive on a HP DC 5000
Hi, I have an HP DC 5000. When i connect a Flash drive and try to access or open the folders i get an Error Message saying e: Access Denied I have reinstalled Windows Xp. Please assit
Anonymous
Level 2:
Scholar:
  • Expert 65 Answers
  • Posted on May 22, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
65
Questions
0
Helped
19886
Points
114
If you contact the manufacturer of the flash drive they may have a reset program for it.. I had a similar problem with a flash drive that I had configred as a key to lock my pc.. but I forgot the password and the flashdrive was then worthless even the reset prog couildn't help it :( hate to be the devils advocate but you may have to replace the flassh drive
Pen drive access denied
USB ports and devices make connecting to another computing device convenient.
USB technology has been around since 1996, and is a feature found on most modern computing devices.
If your device is denied access to one of its USB features, do some troubleshooting to isolate and resolve the problem.
Viruses
Some computers come with a security feature that automatically denies access to a USB device, such as a flash drive, if harmful content is detected.
Installing an anti-virus software application and regularly scanning the computer and any connected USB devices can help you avoid experiencing denied access to a USB device.
Avoid opening USB flash drive files that you cannot identify or do not recognize, as these types of files are how viruses find their way onto unprotected computers.
Incompatibility
Inserting an incompatible device into your computer's USB port can also cause you to be denied access to your device's USB features.
For instance, if your computer supports USB 1.0 technology and you insert a USB 2.0 or USB 3.0 connector, the computer can experience interfacing problems that may cause a "USB access denied" prompt or situation.
If other USB devices begin to malfunction after inserting an incompatible USB cable into your computer, turning the computer off and back on again may resolve the situation.
Formatting
USB flash drives, also known as pen or thumb drives, are among the most common types of USB devices used in conjunction with computers.
Most USB flash drives are formatted using one of three types of formatting methods: FAT16, FAT32 or NTFS.
If you've formatted a USB flash drive using one method, used it on the computer and then reformatted the drive using another method, you can be denied access to the flash drive through the computer's USB port.
Wiping the flash drive clean and reformatting it again can resolve this type of problem.
Considerations
Many computer accessories, including printers and pointing devices, connect through the machine's USB ports and can interface interchangeably with multiple computing devices.
This feature increases the risks of picking up viruses and experiencing unauthorized reformatting. Limiting the amount of computers your USB devices accesses can help you avoid these situations.
Damaged USB cables can also make it impossible to access USB devices when they are connected to your computer.
USB cable damage usually occurs at the points where the cable and its connectors meet. Replace any damaged USB cables.
You have to be the computers administrator to change any values on any hard drive on your computer.
Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control.
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
http://www.webopedia.com/TERM/U/USB.html
Installed secondary sata hard drive. systems recognizes drive but cannot gain access. tried adv sharing settings as administrator but keep getting access denied. tried to reformat but permission denied....
Is the drive at the correct level i.e. FAT32, NTFS in the case of windows, ext2, ext3, ext4 and others for linux. depends on what OS was used previously on this drive. Try to use an OS that supports the drives file system, but since you mention formatting try accessing the drive in the bios and perform a low level format. If it is connected to a raid controller settings in the raid controller will need to be made (normally on servers).
My flas disk capacity not show in pc. It can't open
i think it is due to your fash drive hardware failure. try to right click on your drive and select format. if format compelete successfully then drive is ok but your system is infected with viruse which denied accessing your pen drive. better thing is use windows explorer and click your flash drive check whether it open or not.
WDBAAF0010HBK-01 DRIVE ACCESS IS DENIED BY LAPTOP
you have to save the files using a computer with the same os that u origanlly and then format the drive on the windows seven computer then move the files back on to the drive
another thing to try is to try and update the drivers on your win. 7 computer
the last thing is you have lost all ur data and you should just reformat it
I repaired the viruses found but when I tried to open my flash drive it doesn't work, the computer says, ''Access is Denied''. What should I do? please help me, got many important files in it.
Were the viruses you found on your local hard drive or on your flash drive? Do a virus scan of your flash drive to be sure. Not sure what program you're using, but make sure you tell it specifically to scan that drive, otherwise it will just scan your C: drive, and that won't help.
I would also try accessing the flash drive from a command line. Click Start --> Run... and type cmd
In the black window that pops up, type the letter name of the flash drive, like e: and hit enter. If your prompt changes to E:\ your files are intact. If you get an error like "access is denied" again, then you'll have to get more creative. Truthfully it sounds like there's just more virus cleanup to be done.
If you're in a pinch, you could download something like Ubuntu, create a boot CD (it comes with instructions), and boot your computer into Ubuntu (without installing it). Once you've loaded Ubuntu, you should be able to see all the files on your flash drive and copy them to another device.
Hope this helps you! If so, please leave a rating!
Access issue to my flash drive
The drive is probably password protected by Securlock software.
Hope it helps.
1helpful
2answers
I cant access the d partition on my hard drive
Hi...
Do you want to access the drive d and get your files. You can not access it when you double click the drive. The drive will says access denied. To access the drive d open My Computer you can see there a address, there is and arrow there just click. Chose the drive d to open i am sure that you can open it.
Regards
PCmania
Access denied psp-nootbook
i had the same problem, right click the drive and select "open as a portable media device".
Flas drive
it is attacked by a virus or a trojan,,,try to scan it with a good antivirus program
95helpful
12answers
PEN DRIVE ERROR
My 2gb hp pen drive showing please insert drive error. Also property showing free space 0 bytes. Please send me hp recovery tool or any equivalent tool to solve the same problem
Grand Canyon Tech
Grand Canyon Tech
