Question about Crafts & Hobbies
Front 4 wheels won't stay on track on Lionel wizard of oz engine
Front 4wheels will not stay on track
3 Suggested Answers
  • 135 Answers
SOURCE: bachmann overland locomotive has trouble staying on tracks
hit it with a bigger hammer!
Posted on Feb 19, 2009
  • 38 Answers
SOURCE: Ι've just joined 2 ovals
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Posted on Jul 23, 2011
Led blinks when train put on track
I am assuming you are using the Lionel CW80 power source. If so, the blinking light might indicate a partial short or a problem with the motor. The reason I believe that is that the CW80 has an internal fuse, which will blow for near shorts/shorts. A stalled motor i.e stuck drive gear, can cause excessive power drain although not enough to blow the internal fuse and also cause the engine not to move. Also, If the engine has the neoprene belt on one of the drive wheels it might have come off and is jamming the running gear or wheel. I believe the Polar Express only has one neoprene belt.
Feb 10, 2015 | Lionel The Polar Express Train Set
Lionel g gauge wont run on track
I think you have solved the problem. Check all the wheels to be sure that they all turn. The locomotive isn't powerful enough to drag a car with a stuck wheel.
Dec 25, 2013 | Lionel Trains Holiday Express G Gauge...
The layout fits totally within a 4x8 board. No accessories and only the engine on the track. The engine stops like it is getting little or no power.
First check your track with a multimeter for track power voltage & continuity.
Second, clean your wheels & pick up roller on your locomotive.
Third, clean your track.
Oct 20, 2013 | Lionel Cw 80 Transformer
Lionel train wheels are locking
1: clean & lubricate your engine2: if that does not work, the wheels may be out of quarter,check with Lionel Parts & Services.
http://www.lionel.com/ContactUs/
Dec 22, 2012 | Toys
The gate stays down when the power to the train is on
The breaks should be on one of the outside tracks along with a wire to the gate and the ground wire from the transformer is attached to the other outside track. Power wire is attached to the center track and the power terminal on the crossing gate. When the train passes the break the metal wheels connect the ground rail to the rail with the break that is wired to the gate. This completes the circuit and the gate goes down. Once the train passes the other break the connection is lost and the gate goes up.
Dec 04, 2011 | Lionel Auto Crossing Gate
I HAVE A LIONEL 2-4-2 POSTWAR WITH SLOW SPEEDS. ANYONEHABE ANY IDEA OF WHY?
Possibly in need of wheel/pickup cleaning or lubrication.
Also possible that your track need cleaning.
Oct 19, 2011 | Lionel Trains Classic Freight Train Set
Is lionel 40 watt transformer from toy train enough power to run a dual motor larger train engine it just lites up and sputters
It would depend on what engine you're trying to run. The 40 watt transformer's circuit breaker will trip off if you put too large of an electrical load on it. If the engine light stays on while it sputters, the track or the engine's motor and electrical pick-ups may need cleaning. Older engines that haven't been run for a while can get stiff. Your engine may need some lubrication.
Jan 18, 2011 | Lionel 40 Watt Transformer Train Set Track...
I have a Lionel 2055 post war train that I have not used in many years. I am setting it up around the Xmas tree. It ran well on the carpet when I tested it out but not around the tree on the hardwood...
Check to see if you picked up any fibers on the wheels or axles from your carpet running. Also check to be sure the pilot truck can swing freely from side to side and is not bent. There is also a light coil spring on the front truck pivot pin. Be sure that the spring is there and is not damaged. Another thing to check is the drawbar between the locomotive and tender. Your front wheels may be getting lifted off the track because the rear of the locomotive is getting pressed down. This a soft carpet may compensate for this but not a hard surface. Run your train at a speed where it derails and look closely at the locomotive to see if the rear is being pressed down.
May 23, 2017 | Lionel Toys
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Dec 14, 2008 | Lionel Cw 80 Transformer
Crafts & Hobbies Logo
Top Crafts & Hobbies Experts
Debbie
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
