Question about Cambridge Audio Azur 650C
Cambridge 650C Repeatedly blown the fuse inside the power supply unit
My Cambridge audio A5 amp has no power why?
The most common causes are in order a blown fuse, perhaps caused by a faulty output stage. Transformer faults. Other power supply faults. Have a look inside you might seen the part that has gone!
Aug 07, 2014 | Audio Players & Recorders
My Cambridge SoundWorks 88CD is not working...no display, no sound, the CD doesn't spin. Any hints? Thank you.
A couple of possibilities- If there is no fuse holder on the rear of the box, it may not be user-replaceable but soldered onto an internal board. If it has blown, either there has been a component failure in the power supply that caused the fuse to fail or the supply is not starting up as it should, a problem caused by cheap capacitors in certain areas of the supply. Unless you have at least a multimeter, this is not a good choice as a DIY repair.
Jun 17, 2011 | Cambridge Soundworks 88CD Clock Radio
My 650c skips on some cd's.
Laser mechanism probably near the end of it's life & needs replacing.
Mar 20, 2011 | Cambridge Audio Azur 650C
MY Wii Console wont power up and everything is connected?
HI. this is a power supply issue. Your unit is equipped with an external power supply unit. This box incorporates all the necessary AC current regulators, and transfer agents to run the Wii. There are ,also, some protection circuits as well. These are in place to protect the unit from surges are unstable AC spikes as well. There is a fuse that is located inside the power supply box. Simple unplug the power supply, and gain access to the fuse, by removing the outer cover of the power supply unit. there are a few screws,(on the bottom), that hold the top cover. remove the screws, and open the power supply unit. this will expose the fuse. Kindly, inspect the fuse. if it shows signs of trauma, and it is blown, simply replace the fuse.
Now, if the fuse shows no signs of trauma, or burn marks, this will confirm power supply circuit failure. This will require that you replace this damaged power supply unit asap...
Jan 28, 2011 | Nintendo Wii Console
Wii wont power on
Now, if the fuse shows no signs of trauma, or burn marks, this will confirm power supply circuit failure. This will require that you replace this damaged power supply unit asap.>>
Dec 27, 2010 | Nintendo Wii Console
I encountered fuse blown
Chances are it will blow again. If it does suspect an overload in either the power supply or power output stage. The most common cause is a semi-conductor that's acting like it was a piece of wire. Easily found with Ohm meter as it will be like you have touched the test leads together.
Oct 28, 2010 | Cambridge Audio Azur 540A Amplifier
Internal fuse on cambridge a1 mk3 has blown and when replaced,blew instantly??
When the fuse blows suspect an overload in either the power supply or Main Amp section.
Check for burnt/damage parts first!
Power Supply faults that will blow the fuse are: Transformer, Rectifier, Voltage Regulator, Large Electrolytic Capictors, Diodes & any other semiconductor connected with it.
Main Power Amp faults are: any semiconductor device on the heatsink.
Jan 04, 2010 | Audio Players & Recorders
My wii console will not power on. have checked all plugs and everything is connected and outlet has power
HI. the power supply board has failed. There is a fuse(3amps) inside the power supply unit. you will need to remove the cover from the power supply to access this fuse. once inside the power supply, inspect the fuse. if it is truly blown, replace it. if the fuse is not blown, this will confirm a failed power supply unit. it should be replaced in this case...
Aug 04, 2009 | Nintendo Wii Console
Changed video games and then it would not turn back on. No power to the wii box.
((Contact Nintendo for a repair ticket if the unit has failed))
Cambridge megaworks 250D won't power up.
Yes, Hi there, as junk996 say, check for the FUSE , and carefully see if burn, or something is bad waired, other than this, if you can RMS the unit is better, or with warranty.
If not, check with s tech guru , for open the panel and check cables, or broken wires. (board inside the sub)
good luck!
Open Sky+
Jun 20, 2009 | Creative Labs MegaWorks THX 250D Computer...
Cambridge Audio Azur 650C Logo
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
