Question about Cambridge Audio Azur 650C
Cambridge 650C fuse blown
My Cambridge audio A5 amp has no power why?
The most common causes are in order a blown fuse, perhaps caused by a faulty output stage. Transformer faults. Other power supply faults. Have a look inside you might seen the part that has gone!
Aug 07, 2014 | Audio Players & Recorders
Cd not able to play last few tracks knocking sounds
CD Mechanism is possibly faulty. Sometimes won't track the outside of the disc properly. Try other CD's of about the same playing time, if more than 1 disc does it, the fault is usually the mechanism. (If the disc is a lot longer than the standard max CD length 0f 74 minutes, some players may have a problem with them. This was usually with older generation players, so may not be applicable here.)
Nov 26, 2013 | Cambridge Audio Azur 650C
My Cambridge SoundWorks 88CD is not working...no display, no sound, the CD doesn't spin. Any hints? Thank you.
A couple of possibilities- If there is no fuse holder on the rear of the box, it may not be user-replaceable but soldered onto an internal board. If it has blown, either there has been a component failure in the power supply that caused the fuse to fail or the supply is not starting up as it should, a problem caused by cheap capacitors in certain areas of the supply. Unless you have at least a multimeter, this is not a good choice as a DIY repair.
Jun 17, 2011 | Cambridge Soundworks 88CD Clock Radio
My 650c skips on some cd's.
Laser mechanism probably near the end of it's life & needs replacing.
Mar 20, 2011 | Cambridge Audio Azur 650C
Cambridge azur amp 640a working brill till yesterday !! now protection light !!!! turned it off numerous time etc plenty of venterlation carnt get it to work
Looks like the fuse blown.. or the classic symptom of electrical fault inside the amp. 640A uses a sensitive protection circuit often ends up in this irritating situation. Normally, there is nothing much you can do, but just check your wall plug connection for Open Ground or Left & Neutral reversed issues. If the wall plug is free of error, then you should better contact CA technical support.
Dec 08, 2010 | Cambridge Audio Azur 640A Amplifier
I encountered fuse blown
Chances are it will blow again. If it does suspect an overload in either the power supply or power output stage. The most common cause is a semi-conductor that's acting like it was a piece of wire. Easily found with Ohm meter as it will be like you have touched the test leads together.
Oct 28, 2010 | Cambridge Audio Azur 540A Amplifier
Internal fuse on cambridge a1 mk3 has blown and when replaced,blew instantly??
When the fuse blows suspect an overload in either the power supply or Main Amp section.
Check for burnt/damage parts first!
Power Supply faults that will blow the fuse are: Transformer, Rectifier, Voltage Regulator, Large Electrolytic Capictors, Diodes & any other semiconductor connected with it.
Main Power Amp faults are: any semiconductor device on the heatsink.
Jan 04, 2010 | Audio Players & Recorders
Cambridge 540A something blew up when connecting input to amp!
mmmm... i had a problem like this before, it seems that you have blown a IC or 2 or 3... if you have blown all your channels IC's then it would be better to buy a new amp, it also depends on what watts your amp is... if it isn't a very high watt amp then it wouldn't be that much to fix, if u only blown 1 or 2 Ic in a channel then let it get fixed, and NEVER switch ports if your amp is still running/playing... its like fixing your car when the motor is running...
Dec 17, 2007 | Cambridge Audio Azur 640A Amplifier
Cambridge Audio Azur 650C Logo
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
