Question about Legacy Audio LA1020 Car Audio Amplifier
I need a manual for a legacy series 2 la1020 1000 watt amp
  • 113 Answers
SOURCE: Amp not working at all...need schematics
source for what? schem? is it powering up or no sound?
Posted on Aug 08, 2007
  • 883 Answers
SOURCE: what size fuse do i need for amp
start with a 50, may need to increase it if you are not using a large capacitor.
600 watts = 12x
x= 600 watts / 12 volts
x = 50 amps
Posted on Dec 13, 2007
  • 631 Answers
SOURCE: Legacy LA690 1000 watt amp
support@legacycaraudio.com
Posted on Aug 16, 2008
  • 77 Answers
SOURCE: 600w legacy amp
9 times out of 10 if your amplifire is in protect mode and evrything externaly, like speakers, fuse, voltage, etc. checks out fine then
either you have shorted out output transistors or power mosfet transistors. Basicly that just about what happens with car amps.
It's easy enough to fix IF, IF you know what your doing. First you
need to check the output transistors with a digital volt meter on diode check, If they check out then check your power supply mosfet transistors. I can almost guarantee this is your problem. Very common. I buy non working amps all the time and repair them. Listen to pbabin also he has helped me out. Good luck
Posted on Feb 12, 2009
SOURCE: i have an american legacy series 2 1000watt apm
If the fuses were the problem then you would be replacing them all the time. Fuses are only good once - and are only in place to protect the circuitry from damaging overcurrent situations.
More likey, the problem is a thermal protection resulting from over-driving the amplifier. What impedance are the speakers you are running? Does the amplifier support that impedance? Typically, car audio runs 4-8 ohm impedance. Many amps have a switch to place the unit in the proper impedance mode.
Check your wiring. Do you have it wired correctly?
Posted on Apr 03, 2009
Can my la590 American legacy 2 series 800 watt handle Boss CX122 Chaos Exxtreme 12-Inch Subwoofer 4-Ohm Voice Coils??
It is only stable to 4 ohm mono(which is 400 watts RMS or a bit less not the max rating of 800 watts which is a PMPO rating).
Your Sub would have to be wired in series(8 ohm final load, if you wire it in parallel 2 ohm-you will fry that amp).
Jan 07, 2014 | Car Audio & Video
I need to know the size of external fuses for a american legacy amp 2000 watt 2 channel 1990
25 to 30 amp fuses will work great, anything lower could possibly blow a fuse when a good bass note hits even if there is nothing wrong with the amp. Hope this helps.
Jul 09, 2010 | Legacy - American II: 2 Channel 2000W...
Capacitor
You usually don't need a capacitor because your car can keep up with the power requirements, especially since your system isnt too big (no offense). But if you wanted to get one, i would only get a 1/2 or 1 farad cap.
Jul 26, 2009 | Legacy LA588 Car Amp
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Jun 22, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
I have an american legacy series 2 1000watt apm
Check and see what size fuses it uses. Your watt power means nothing without good fuses. My suggestion would be to go buy 40a fuses and replace the ones you already have.
Feb 27, 2009 | Legacy Audio American Legacy II LA290 Car...
Problem with LEGACY BLUE DIAMOND AMPLIFIERS LA1080
never attemp to bridge your amps specially this type of amps. this are too very complicated. you may blow your amp if you will attempt it again.
Jan 22, 2008 | Legacy BLUE 4 X 250W CAR AMP Car Audio...
What size fuse do i need for amp
600 watts = 12x
x = 50 amps
Dec 13, 2007 | Legacy Audio American Legacy II LA490 Car...
Legacy Audio LA1020 Car Audio Amplifier Logo
47 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Mark Skinner
SXTechHead
SXTechHead
Professor_V
Professor_V
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
