Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
Cannot engage motor - Pride Go-Go Ultra X 3-Wheel Travel Scooter
59.99 printer error
59.99.00 - (event log only)
An error occurred in the secondary transfer
engaging mechanism.
1. Faulty secondary transfer engagement
sensor. Replace the secondary transfer
engagement sensor.
2. Faulty secondary transfer engaging
solenoid. Replace the secondary transfer
engaging solenoid.
3. Faulty feed motor. Replace the feed
motor.
4. Faulty DC controller PCB
Action: Replace the DC controller PCB.
Dec 11, 2010 | HP Color LaserJet 3500 Printer
Hp laserjet 3550 keeps on giving me error message of code 59.99 what do i do to solve the problem please thank you.
ur developing motor gears worn out replace them ur problem will be resolved...............
and
This error also shows the faulty secondary transfer engaging mechanism.
1. Faulty secondary transfer engagement sensor.
Action: Replace the secondary transfer engagement sensor.
2. Faulty secondary transfer engaging solenoid.
Action: Replace the secondary transfer engaging solenoid.
Action: Replace the feed motor.
good luck, and do rate the solution if helps
Nov 30, 2010 | HP LaserJet 3550 Printer
TENGO EL ERROR 59.99 EN MI IMPRESORA LASERJET COLOR 3500 COMO LO SOLUCIONO
engaging mechanism.
engagement sensor.
engaging solenoid.
motor.
Oct 06, 2010 | HP Color LaserJet 3500 Printer
Solenoid clicks will not engage 4000KW Onan
4000 kW is a very big generator. I asume that your is 4000W = 4 kW.
If - with electrical start it should be MicroQuiet 4000.
Never mind by all types of electricaly started engines this will mean:
If by "not engage" you mean that solenoid only clicks, but neither the starter motor is turning, nor the bendix wheel is engaged to wlywheel. This may mean that battery voltage is low, in order to engage the bendix and make its power contact, or the bendix is mechanicaly blocked.
If by "not engage" you mean that solenoid clicks, the starter motor is not turning, but the bendix wheel is engaged to wlywheel. This may mean that the bendix relay power contacts are bad or starter motor collector or brushes are bad.
If by "not engage" you mean that solenoid clicks, the starter motor is turning with a scratching sound, the bendix wheel is partially or not engaged to wlywheel. This may mean that the bendix throw out lever is bent or broken, or the wheels on bendix and flywheel are worn out..
Aug 01, 2010 | Watts Onan Portable Generator - 4000 ,...
4wd will not engage all the time.sometimes it works great and then it will just quit.it is vaccum engaged and i have checked it and the fluids and they seem to be working.
Yes it is vacuum engaged. Check the vacuum motor and last but not least there is a shift fork that it engages to lock your front axle. Sometimes the shift fork gets bent and will not allow engagement. Also check the rubber vacuum line that runs to the engagement motor.
Dec 05, 2009 | 1991 Jeep Wrangler
Hp color laserjet 3550 59.99 printer error
This error shows
An error occurred in the secondary transfer engaging mechanism.
Nov 09, 2009 | HP Color LaserJet 3500 Printer
1990 jeep wrangler front driveline engages but tires dont.
check you vacuum motor and vacuum lines going to the vacuum motor from the top of the transfer case. when u engage your 4WD the valves on the transfer case are opened by a switch on the transfer case. the lines coming from the switch cross the top of the transmission and up the passenger side of the engine compartment. these lines will be red, blue, green and yellow, and often covered by a black sheeth, about 1inch in diameter. check these lines to make sure they are connected. if they are not, the vacuum motor will not engage your front axle. your front driveshaft will still spin, because the transfer case is engaged as normal, but the right front axleshaft is a 2 piece system engaged by this vacuum motor. if they lines are messed up, the motor will not engage the axle collar connecting the 2-piece axle. if your vacuum motor is working, then you might have a broken collar, or perhaps a broken axle shaft. but it's probably just the vacuum hoses or the motor :) i hope that helps!
Nov 15, 2008 | 1990 Jeep Wrangler
Fixed the coupling on my kenmore. Can't attach the motor back!
First make sure the coupler has engaged properly. Then lower the motor enough to engage the bottom clamp. Then with your thumb on the motor shaft and other fingers on the top of the motor, lift the motor and engage the top clamp.
Jun 12, 2008 | Washing Machines
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
13 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
