Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Head bolt torque jd 310D diesel backhoe 1998
Installing head gasket and need torque lbs and sequence
2 Suggested Answers
SOURCE: I NEED INJECTOR PUMP SCHEMATIC FOR JD 400 PUMP
I'm getting hydralic fluid in my engine oil. I was told that it's coming from my power steering unit. It's a JD 400 tractor/backhoe. Would this be correct?
Posted on Mar 21, 2011
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
additional 90 degrees.
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
Sep 19, 2013 | 1996 Saturn SL
Cylinder head bolt tightening sequence for isuzu rodeo 1998
1998 Isuzu Truck Rodeo 2WD 2.2L MFI DOHC 4cyl
The Head Bolt Torque
Torque sequence ----------------- front ' 7 3 1 5 9 ' of ' ' engine ' 8 4 2 6 10 ' ----------------- Step 1: torque bolts in sequence to 18 Ft/Lbs Step 2: turn bolts in sequence an additional 90-degrees Step 3: turn bolts in sequence an additional 90-degrees Step 4: turn bolts in sequence an additional 90-degrees recheck final torque in sequence
1998 Isuzu Truck Rodeo 2WD 3.2L MFI DOHC 6cyl
Torque sequence -------------- front ' 6 1 3 7 ' of ' ' engine ' 5 2 4 8 ' -------------- Step 1: torque to 20 Ft/Lbs Step 2: torque to 47 Ft/Lbs recheck final torque in sequence
Jan 15, 2013 | 1990 Isuzu Spacecab
Correct pressure for torque the head of mazda pickup 1998
Since you didn't say which engine you have, I've pulled torque specs for 3 different engines. Also, since I can't include a diagram showing the relative locations of the numbered head-bolt locations, it would be a good idea for you to purchase a vehicle specific repair guide that will show this info.
Take particular note about the TTY (Torque to Yield) bolts used on 2 of the 3 engines shown. It is said that new head bolts MUST BE USED when head is replaced or re-installed to obtain the proper torque.
B2500 4 Cylinder
Torque sequence: --------- ' 10 6 2 4 8 ' front ' ' ' 7 3 1 5 9 ' -----------Step 1: torque in sequence to 51 Ft/Lbs Step 2: torque again in sequence to 51 Ft/Lbs Step 3: final tighten all bolts an additional 90 to 100 degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) that permanently stretch during the initial installation. New head bolts must be used when cylinder head is replaced or re-installed to obtain proper torque.
B3000 3.0 6 Cylinder
Torque sequence ---------- ' 6 4 2 8 ' ' ' ' 5 1 3 7 ' ---------- Step 1: torque to 59 Ft/Lbs Step 2: loosen in sequence (1) full turn Step 3: torque to 41 Ft/Lbs Step 4: torque to 73 Ft/Lbs
B4000 4.0 6 Cylinder
Torque sequence --------- ' 5 1 3 7 ' ' ' ' 6 4 2 8 ' --------- Step 1: torque cylinder head bolts in sequence to 26 Ft/Lbs Step 2: torque cylinder head bolts to 56 Ft/Lbs Step 3: turn cylinder head bolts in sequence an additional 90-degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) that permanently stretch during the initial installation. New head bolts must be used when cylinder head is replaced or re-installed to obtain proper torque.
Good luck with this job!
Feb 06, 2011 | 1998 Mazda Pickup
Want to know the amount of torque pressure do i use when tightening the head bolts, and whats the sequence?
To install:
Fig. Cylinder head bolt torque sequence-3.8L engine
  1. Install the new cylinder head gasket with the arrow pointing to the front of the engine.
  2. Install the cylinder head.
  3. Install NEW cylinder head bolts. Torque the bolts in sequence, as follows:
    1. Step 1: 37 ft. lbs. (50 Nm).
    2. Step 2: Plus 120 degree turn.
To install:
Fig. Tighten the cylinder head bolts using the following sequence-31L and 3.4L engines
  1. Install the cylinder head with a new gasket.
  2. Apply thread sealer to the head bolts.
  3. Tighten the cylinder head bolts to 37 ft. lbs. (50 Nm) plus an additional 90 degree turn.
Dec 16, 2010 | 2002 Pontiac Grand Prix
Looking for head bolt troque spec for 3.4l impala sfi04
Please don't forget to rate. Thank you:
Left side front cylinder head
Cylinder head bolt torque sequence-3.4L engine
  • Cylinder head by aligning it with the dowel pins
  • New cylinder head bolts coated with a sealant (such as GM 1052080). Torque the bolts in the proper sequence (1-8) to 37 ft. lbs. (50 Nm). Using a torque angle meter turn the bolts 90 degrees in the proper sequence.
  • Left side exhaust manifold. Torque the bolts to 12 ft. lbs. (16 Nm).
  • Spark plugs. Torque the plugs 11 ft. lbs. (15 Nm).
  • Right side rear cylinder head:
  • New cylinder head gasket
  • Cylinder head on top of the gasket and make certain it is lined up properly with the dowel pins
  • Right side exhaust manifold. Torque the bolts to 12 ft. lbs. (16 Nm).
  • Spark plug wires
  • Exhaust crossover pipe. Torque the fastener to 18 ft. lbs. (25 Nm).
  • Valve rocker arms and pushrods. Torque the fastener to 89 inch lbs. (10 Nm). Using a torque angle meter torque the fastener an additional 30 degrees.
  • Lower intake manifold. Torque the bolts to 115 inch lbs. (13 Nm).
  • Upper intake manifold. Torque the bolts to 18 ft. lbs. (25 Nm).
  • Nov 26, 2010 | 2004 Chevrolet Impala
    Can i change a leaking top gasket at home? I want to remove the head and have it skimmed.I am reasonally mechanical minded. What is the torque for fastening the top nuts? Manie vd Merwe. Jeffreys Bay
    VOLKSWAGONS YOU NEED CYLINDER HEAD REMOVE SEQUENCE AND CYLINDER HEAD TORQUE SEQUENCE.YOU NEED A REPAIR MANUAL FOR TORQUE SEQUENCE OR YOU WILL HAVE HEAD GASKET LEAKS. TORQUE HEAD BOLTS TO * STEP 1 * TORQUE BOLTS 30 FT LBS * STEP TWO * TIGHTEN BOLTS 44 FT LBS STEP 3 TIGHTEN BOLTS PLUS 90 DEGREES.* STEP FOUR* TIGHTEN BOLTS PLUS 90 DEGREES AGAIN.
    Oct 02, 2010 | 1999 Volkswagen Jetta
    Need to know the head bolts torch specs on 98 toyota v6
    heres the torque specs and the way to tighten the head bolts for your 1998 toyota sienna, hope this helps,
    12 point bolts step 1- 40 ft lbs
    step 2- additional 90 degrees
    May 12, 2010 | 1998 Toyota Sienna
    Head gasket torque specifications and sequense
    Cylinder head bolt torque sequence—3.4L engine
  • Spark plug wires
  • Mar 06, 2010 | 2001 Chevrolet Venture
    I nee the head bolt torque specs for a 95 sable
      • Tighten retaining bolts in sequence to 80 Nm (59 ft. lbs.).
      • Then back off bolts 360°.
    CAUTION: Always use new cylinder head bolts when installing cylinder head or damage to engine may occur.
    1. Tighten the cylinder head retaining bolts in two final tightening steps in sequence shown in the following illustration:
      • 50 Nm (37 ft. lbs.)
      • 92 Nm (68 ft. lbs.)
    Nov 03, 2009 | 1998 Ford Taurus
    Need to know cylinder head bolt torque specs
    Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
    Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
    John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
    23 people viewed this question
    Top John Deere Garden Experts
    Phil Walker
    Phil Walker
    Tim Whalen
    Matt Olenzek
    Matt Olenzek
    Are you a John Deere Garden Expert? Answer questions, earn points and help others
