Question about Singing Machine STVG-519 CDG Karaoke System with 5.5" Monitor
Monitor goes out - Singing Machine STVG-519 CDG Karaoke System with 5.5" Monitor
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Hi guys. i hav an acer ac713 crt monitor. the cable that connects the monitor to the tower/hardrive has been cut by burglars. where can i find a wiring diagram to fix it? thanx.
in 15pin connector of the monitor,
red wire goes to pin No:1
green wire goes to pin no:2
blue wire goes to pin no:3
yellow wire goes to pin no:13
white wire goes to pin no:14
and black wire goes to 5&15. Now display will come!
Sep 08, 2010 | Acer AC713 17" CRT Monitor
Monitor goes blank but is still connected
Do bios update on Computer.Select the product number and search on Website for bios and than try the monitor
Oct 13, 2009 | Computers & Internet
MONITOR GOES ON FOR A SECOND AND THEN GOES BLACK
try running the monitor self test ie unplug the video cable of the monitor & then see if u r getting the mukticoloured bars on the screen or not?
if yes then its working fine otherwise the monitor has gone bad.
Apr 23, 2009 | Computers & Internet
Monitor goes black
dry soldring problem in your monitor
Mar 31, 2009 | Acer AL1751WM (Silver) 17" LCD Monitor
My monitor goes blank repeatedly
1. First u can check any dry points in power supply board and controlling circuit.
2. check all connectors (connected properly)
3.To replace front pannle Micro switches.
Oct 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor problem
You need to figure out if the monitor is faulty or if it is due to the power in your house (not likely) or the fault of the computer.
  1. Try the monitor on other power jacks.
  2. Try the computer on other monitors and see if you get the same response.
If it seems to just be the monitor then you will most likely have to have it serviced or replaced. Is it still under warranty?
May 13, 2008 | Gateway FPD2275W LCD Monitor
Can not diaplay when connected to external TV tuner Box(fontech)
'The Monitor goes blank when the box is powered' what does that mean exactly? what box? What was the monitor doing before the said box was pwered?
Jun 04, 2007 | BenQ FP91G+ (Black)
Singing Machine STVG-519 CDG Karaoke System with 5.5" Monitor Logo
27 people viewed this question
Top Singing Machine Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Singing Machine Audio Player and Recorder Expert? Answer questions, earn points and help others
