Question about Watches
Columbia watch treeline ct008 change battery - Watches
escapement
  • 2334 Answers
SOURCE: Chime not working on a Columbia CL-5017
This is because you lost the coil spring when battery change took place. Coil spring works as a conductor to the membrane inside caseback and transmits the signal. If you can not find it, you will need to find your nearest watchmaker and ask for new coilspring.
I am pretty sure that you think you did not lost anything, but I can assure you that you did. Coilspring is very tiny and hard to see when dropped and you can not hear it as well.
In case if you find that spring, you have to open the watch and put it back in. There is a small hole in the watch movement and it is designed for coilspring.
Rate me, please.
Posted on Mar 23, 2009
landsend
  • 1066 Answers
SOURCE: Is a columbia watch still waterproof after you
not being inside your watch to see if water leaks in...it's hard to tell.  However, if you carefully replaced the battery and didn't damage the case or the gasket o ring, things should be fine.  Test it under the kitchen faucet first.
Posted on Mar 31, 2009
SOURCE: how do you change a battery on a columbia cl-7269
Use the notches on the back and unscrew the cover.
Posted on Feb 01, 2010
  • 2501 Answers
SOURCE: I have a Columbia analog/digital watch. I just
I assume you do not have any instructions.
To get some go to "www.columbia.com/Equipment-+-Accessories/Licensee_Landing,default,pg.html"
Under "Timing" you will see a link "PDF.............", click on this and a list of diagrams will appear. Choose the one that looks like yours
and follow the adjacent instructions.
Posted on Mar 04, 2010
Testimonial: "Exactly right. Thanks."
jyackle5
  • 8197 Answers
SOURCE: I cant seem to get the back of the watch off. How
Remove the back cover.
On some watches, the cover will pry off using a very small flat-bladed screwdriver or will have screws holding the cover on. On other brands the entire cover will unscrew. Examine the edge of the back cover. If there is one small depression along the edge of the cover then the cover will pry off. If there are screws present, the cover will lift off after the screws are removed. If the cover has a raised edge with flat edges opposite one another then the cover will unscrew.
Posted on Mar 25, 2010
What battery does the Cl3207 mens watch from Columbia Sportswear take?
best to take it to a watch maker and let them change it
Mar 03, 2015 | Columbia Watches
I can't find a cl 5017 battery for my Columbia watch.
cl 5017 is not a battery code or size, try bring your actual battery or your watch on watch service centers. they probably have your battery.
Sep 08, 2011 | Columbia All Sport Digital watch
I can't open the back of my columbia sportsware CL-7017330 feet water resistance watch. I need to change the battery.
To be honest, I would send back to Columbia. Water resistant watches are not only tricky, but you risk losing the warranty on your watch as well.
I would go to link and follow instructions:
http://www.columbia.com/FAQ-Details/CustomerService_FAQ_QuestionDetail,default,pg.html?rnurl=/app/answers/detail/a_id/417/session/L3NpZC9JRmxoZVk3aw==
Aug 20, 2010 | Columbia Sportswear Watches
How do you get the back of the Columbia Sportswear CL7017 off to change the battery?
You can remove it with a pocket knife and it will pop out but the problem will be putting it back and that is only done with pressure that is put under a machine.If you go to a flea mkt they will do it for $5-7.00 for the battery and the cover pressure is free once the battery is changed.So make sure you get a good long time warranty battery so you dont have to change the battery frequently.
Nov 30, 2009 | Columbia Sportswear Analog Straps CL7017...
How do i change battery on columbia 5017
Open watch caseback. Undo the contact covering the battery. Read the writings on battery and buy exactly the same one. Get the old battery out and replace with the new one exactly the same way as it was. Redo the contact. Put caseback back on. Reset the watch.
Rate, please.
Jul 09, 2009 | Columbia All Sport Digital watch
Is a columbia watch still waterproof after you change the battery?
Mar 31, 2009 | Columbia All Sport Digital watch
How to change battery on Columbia CL-5037
Are you able to slide the metal casing sideways? I think it should just slide sideways. Good Luck!
Dec 30, 2008 | Columbia All Sport Digi Watch l
Adjusting a digital watch
Yes you can adjust digital quartz watches,there be a trimmer inside to adjust the fast and slow.,but that is last option to do if nothing happens.I think when changing the battery you did not clean the battery terminals,so that film residue will gone out.Film residue comes from the liquid comes out from the old battery.this is the most common problem of the battery.After all you clean,next is short ,the terminals.If you forgot this step this is very problem at all,the not working so you better watch out.
Jun 16, 2008 | Columbia Elkhorn Countour Watch
Watches Logo
307 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
