Question about Bell & Howell Sonic Breathe Ultrasonic Travel Humidifier
Steam not coming out of sonic breathe humidifier
HE440A Steam Power Humidifier
The most common cause of overflow is when hard water deposits build up and prevent the float from closing. You'll have to open up the unit, make sure there's no water in it, and clean out any mineral deposits.
The problem with these steam producing units is that there is no built in way to remove those deposits automatically. The water comes in, evaporates, and leaves anything else that was suspended in it behind.
Nov 14, 2007 | Honeywell HE440A1005 Humidifier
My bell and howell sonic breathe humidifier worked for the first bottle of water and thats it. now i put the bottle on and the steam only comes out if we squeeze the water bottle.
It sounds like a piece of ''something'' fell inside the hole where the bottle goes. Can you check for that?
Is it ''take-apart-able?'' I can pretty much assure you that if you can _see_ the components involved where that bottle makes contact, you will find an obvious problem.
Obviously water is not getting _past_ something, and it really sounds simple to me. (i.e. ''take it apart, find obvious problem and correct it, then reassemble'').
Feb 27, 2015 | WhateverWorks Bell And Howell Sonic...
Sonic breathe does not mist?
Find out where the mist is supposed to escape from inside the unit. Clear the airway.
Nov 30, 2014 | WhateverWorks Bell And Howell Sonic...
WHERE CAN I BUY VICKS WARM STEAM VAPORIZER
Problems in a Vicks Warm Steam Vaporizer comes when it is mis-handled or when we buy non-warranted products. It is the best solution to spend money on the branded and cheap vaporizers.
http://www.vaporizerchief.com
Cheap Vaporizers Herbal Vaporizers For Sale
Jan 21, 2014 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Steam vaporizer kaz, emites a black particules, in the tank like sort of blak ink when finish using it, is there any problem with that???
This is considered normal. It's the residue left from the water vaporizing into steam. Since it's left behind in the chamber, you do not breathe it in. Other users have said that it helps keeping these minerals in the chamber and just adding water to mineralize the water in lieu of adding salt.
Oct 05, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Venta Sonic VS205 Humidifier turns and has the green light, makes a buzzing sound, but no mist is coming out.
If you see mist in unit and not coming out fan motor in base of unit bad. Four screws in base and fan unplugs
Aug 20, 2011 | Venta Airwasher VS 207 3.7 Gallon...
No increase in humidity after installing whole house humidifier
have you checked the damper ? is the motor running the right direction ? have you increased the water supply to it ? you need to be sure that it is coming on only when you have a call for heat, normally your humidistat should be installed near the return, or on the return duct, for proper sensing, you could try holding a pan of steaming water, placing the stat above it, not to close, to see if the stat shuts off the hum, a little trick, that way you will know if the stat works ok, hope these helped, thanks for the question, mr.grzz
Jan 22, 2009 | Honeywell HE220A1019 Whole House...
No steam comes out
I just took mine apart and cleaned the scale off the heating elements. Filled to the level with hot water and it was steaming good in about 2 mins.
Mar 01, 2008 | Vicks V150SG 1 Gallon Humidifier
Bell & Howell Sonic Breathe Ultrasonic Travel Humidifier Logo
95 people viewed this question
Top Bell & Howell Humidifiers Experts
Paul Carew
Dennis
Are you a Bell & Howell Humidifier Expert? Answer questions, earn points and help others
