Question about Dell Inspiron 1000 Notebook
Installiing memory in inspiron 1000
I need to know how to . install more memory in my computer. I cannot find the manual to find out where to install the memory chip. could you tell me where it goes or where I can find an instruction manual on how to find the correct place for it?
  • 457 Answers
Re: installiing memory in inspiron 1000
You compuer comes with this already installed.
  • 512MB PC2100 DDR Memory
  • You can only install another 512MB total 1G.
    To get into where the chip is should be underneath that laptop secured by two screws.  If you find there is no chip inthere already then all you need to do is place the other chip into the slot.  The first is already in there and to get that you have to go through the removing the keyboard.
    Posted on Oct 17, 2007
    0 characters
    3 Points
    Forgot my dell inspiron pass word
    Dell Inspiron 1000 PC Notebook proplem
    Now, if you forget your password, first prepare Windows Vista installation CD, then the computer will enter BIOS first startup Settings for cd-rom start. When the screen, click start presentation by any key cd-rom start system. Then when the interface language appears in the "next", click on the installation interface click "repair the computer ", the "system in the popup window list", click options repair" prompt ".
    Aug 13, 2010 | Dell Inspiron 1000 Notebook
    Do i have to change the jumper position when i install the new memory chip for dell inspirn 1000
    Thank you for your query
    If you are installing more memory RAM, then there is no need to change any jumper settings, simply take the old module out and replace with the new module
    If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
    Feb 22, 2010 | Dell Inspiron 1000 Notebook
    I reformat my dell inspiron 1000 but it says that the scsi should be terminated? how can i terminate the scsi? pls help!!!
    Small Computer System Interface, this is part of the computer that need driver to installed.
    All you need is to installed all the driver on your laptop and it won't ask for it again. SCSI devices usually connect to a controller card like wireless card, camera,PCI slot, e.t.c
    Dec 08, 2009 | Dell Inspiron 1000 Notebook
    Installed a rangeplus adapter on dell 1000 inspiron xp sp3 home
    See if you can go into safe mode by hitting the F8 key right after the dell splash screen and right before the XP splash screen comes up. If you can get into safe mode try to uninstall the rangeplus adapter and try reinstalling again after rebooting the system normally.
    Nov 15, 2009 | Dell Inspiron 1000 Notebook
    Vista onto dell inspiron 1000
    NO. You do not have a 64 bit processor. Also, Vista 64 is a memory hog and u need at least 1 GB.
    Apr 25, 2009 | Dell Inspiron 1000 Notebook
    No audio on dell inspiron 1000
    What was the last program you have installed on the computer or the last device you have plugged in? there is a possibility that it has altered the audio attributes of the computer.
    if you have other questions just lemme know
    Sep 19, 2008 | Dell Inspiron 1000 Notebook
    Installing Memory
    Yes, you can replace/upgrate the memory module under the keyboard.
    Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
    Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
    Read "Preparing to Work Inside the Computer" before committing to the above procedure.
    Let me know how you get on.
    May 24, 2008 | Dell Inspiron 2650 Notebook
    Installing ram
    You need to go into the bio and update the memory there and the Yellow ! will go away. Boot the PC, select the F8 key during post, go into the setting for Memory and accept the change and you should be good to go. Let me know //D
    Apr 25, 2008 | Dell Inspiron 1000 Notebook
    Dell Inspiron 1000 Notebook Logo
    146 people viewed this question
    Top Dell PC Laptops Experts
    Sudeep Chatterjee
    Sudeep Chatterjee
    Donna Sander
    Are you a Dell PC Laptop Expert? Answer questions, earn points and help others
