Question about Hasbro Fur Real Friends Smores Pony
Head won't turn on baby butterscotch
The head is stuck to the right and when I touch the spots on her that are supposed to make her respond and move her head, nothing happens. She opens her mouth and makes noises but doesn't respond with moving her head.
toddq4
SOURCE: Smores pony head stuck toward the left
Also check the screw that had the nylon cord attached to it. It could be stuck causing the head not to turn.
Posted on Dec 27, 2008
toddq4
SOURCE: Furreal pony, Butterscotch, Head floppy/leans left
There is a smaller "u" shaped spring in the middle of the neck mechanism that I found one side was snapped off. Looks normal, but it's broken. I made one out of a coat hanger for temporary purposes and it works like new! I will order one from Hasbro. Hope this helps!
SOURCE: Furreal Pony neighs like a broken record
I had the exact same problem, and all I did was replace the batteries. It worked right again! I just knew the kids had broken the neck of it. It sort of slings to the left and neighs over and over again. BATTERY ISSUE :) The instruction manual should tell the consumer this. Hope this helps!
Posted on Dec 29, 2008
  • 8 Answers
SOURCE: Hasbro S'mores tail broken off, makes clicking
Not sure about the clicking but her is how to repair the tail. Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of CLEAR plastic tubing with 3/16" inner diameter and 5/16" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the holes. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. You will probably need to twist the tube gently while applying firm pressure on it to make it slide over the stub. The end of the tube with the holes should be about even with the outside top of the white plastic hole and the tube holes should be level, looking at it from side to side. This makes the alignment of the screw hole to the tail correct. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully twist and remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right if you cut it too short! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Posted on Jul 23, 2010
SOURCE: My butterscotch pony's head doesn't look to its
We have the same problem only we were able to remove the zipper (with screwdriver and cursing). Still cannot get it to turn its head other way and consistently go into ride mode. Did you find anything to help?
Posted on Dec 25, 2010
Epson Workforce 3640 print head with ink cartridges stuck on right hand side. Error message appears. How do I unjam it?
There is a small lock in the chasis of the head. Move the head to right you can see a plastic on the head moving path. push it to backwards. Now you can move the head to left.
Jun 02, 2017 | Epson Office Equipment & Supplies
Butterscotch pony head not working
First, calling poor Grace at Hasbro will provide fruitless. Hasbro does not make any parts for the full size FurReal Ponies, they have nothing in stock and cannot help you. I, however, can. I am going to post a link to a distressing site that turns the normal FurReal Pony into a fire breathing demon. However, in the process, you can see the diagram of the skeleton of the pony and head. You can search for other links but this is pretty comprehensive. Just don't open when kids are around.
Lisa
http://www.instructables.com/id/Make-a-Fire-Breathing-Animetronic-Pony-from-FurRea/
Dec 08, 2013 | Hasbro Furreal Friends Butterscotch Pony
Won't start
yes your moving in the right direction if over head valve remove the valve cover and check the rocker arms and for bent push rods if a flat head remove the head and check the valves
Aug 19, 2012 | Briggs & Stratton Garden
How do I reassemble the head of the FurReal Pony?
The Pony Care Guide refers to an "Assembly Video" on the FurRealFriends.com site. I couldn't find it and even went through a gazillion videos on YouTube. Contact Hasbro directly through this link to see if they can send you a link to the Assembly Video:
http://www.hasbro.com/customer-service/phone-directory.cfm
Nov 18, 2011 | Hasbro Furreal Friends Butterscotch Pony
My daughter's Butterscotch Pony is in great shape, except for a loud gear-grinding noise that we have traced (and watched with a flashlight) that appears to come from a large white plastic gear that is...
Yes, that is the fault in question: that plastic cog was supposed to move the head and it's making that noise because it's slipping, because the gear shaft is not properly aligned with the motor - it's how the head mechanism was designed: badly and with low quality parts.
No, this is not automatically fixed by Hasbro with a head replacement - this happens only when the cog breaks due to the abnormal stress that's put on it, not your case. All you can do is to slightly grease the mechanism and refit the head as best as you can.
Jul 01, 2011 | Hasbro Furreal Friends Butterscotch Pony
My butterscotch pony's head doesn't look to its right, only left, won't go into ride mode, and I pressed the button on the zipper to release it so I could take off the head cover but it won't release.
Dec 18, 2010 | Hasbro Furreal Friends Butterscotch Pony
Touch screen would not respond
HI,
Here is a link to get you to the Palm support page. You can do a phone call to the but it will cost you $25. There is also a chat feature and that looks like it is free so hopefully that will help.
Best wishes.
http://kb.palm.com/wps/portal/kb/na/zire/z22/unlocked/supportservices/page_en.html
Aug 16, 2009 | Palm Z22 Handheld
Red warning lights remain on.....
Ink and paper light on : head carriage error/general error. Head can't move extremely to right : head carriage blocked or CR motor error. Turn of printer, unlock head carriage lock. Move head left and back to right (to parking position). Is it move freely?
Jun 16, 2009 | Epson Stylus Photo R200 InkJet Printer
Dec 09, 2008 | Hasbro Fur Real Friends Smores Pony
Hasbro Fur Real Friends Smores Pony Logo
37 people viewed this question
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
