Question about 2000P Radar Detector
No sound from left pod k40 2000p - 2000P Radar Detector
How can i connect i phone or i pod to nakamichi sound space 5 or8?
use an audio cable with 3.5 jack inserted in the iPod headphone jack and the two RCA jacks Red and White) into the AUX IN located on the bottom Right/Left side of your Sound Space 5 and turn up the volume while playing
Oct 30, 2014 | Audio Players & Recorders
Hi, I had some speakers and the 3.5mm audio jack wire that connects them into inputs had gone funny. You had to bend it into a sweet spot to get both speakers working otherwise only the left one would...
sounds like you bent the wire so that the wiring could actually make a contact, thus your speakers would work. Sounds like the contact is now broken which is probably a solder joint. You can remove the sleeve and you will see the issue. All you should have to do is resolder the connection and you will be done.
Apr 12, 2011 | Audio Players & Recorders
I run a pod HD 500 into the amp and It breaks up, like there is a blown speaker sometimes.
The Marshall is a super clean acoustic amp.
The POD is overloading the amp.
Try the electric guitar input and keep the gain on the amp down, keep the EQ level and use the POD and the end volume to adjust the final volume.
The normal inputs is for a low output acoustic pickup - the POD is a high output electronic source.
Start with the Marshall gains low and get the clean sound good, then work on the gritty sound.
The amp is voiced for a sweet clean sound - if you want grit'n'ball change to a 50w Marshall valve head and a 4 X 12 cabinet.
Horses for courses
Mar 07, 2011 | Marshall Amplification Marshall AS100D 2x8...
I tunes and I pod syncing problem
you have to get into the I-Tune and check mark everything you want to send over to I-Pod, then it should. When you are in I-Tunes you have to click on the left where your I-Pod is and click on the different tabs and add all the thing you want it to sync
Sep 08, 2009 | Apple iPod MA446LL/A MP3 Player
Hayward Navigator Moves very slow
check the bearings on the turbine and "a" frames.
also make sure the left and right pods are tightened properly and the pod shoes are in good shape.
Sep 05, 2009 | Hayward Navigator Pool Cleaner
Strange problems with Z-2300's
I'm having this same problem and have sort of solved it with a really wierd technique I found at Logitech. Evidently this problem is related to the control pod rather then the RCA jack. Try this:
Unplug the control pod from the subwoofer Turn off the main switch Turn the volume knob one full turn, tap the knob Repeat again (2 times) Replug the control pod Turn on the main switch and the control pod See what happens
I found that this got the speaker working finicky after it was almost totally useless. It seems to be cutting out randomly, but fidgeting with the control pod or it's connector jack fixes it. No clue what the deal is here, but your problem is identical to mine so take some time to screw around with these components with music running so you can hear if it suddenly works.
Nov 12, 2008 | Logitech Z-2300 Computer Speakers
I pod nano
open I tunes, plug the i pod into the computer, when the i pod shows up on the left hand side of the screen, right click it and you should get an option to rename it
Sep 19, 2008 | Apple Mini IPod
Looking for a control pod.
I recently had a similar problem. In my case the left speaker had no sound. Finally traced the problem to a broken wire inside the control pod plug, which I destroyed by dissecting it. For those who have the experience, or know someone who does, purchase a new plug, which a Mini DIN 8 pin (RS-422 standard). It should be available at any good electronic parts store. Solder new plug on to cable, which requires a fine electronic soldering iron and a fair bit of skill (the wires are very fine).
Look at the plug (from the rear); you will see it comprises a top row of 3 pins equaly spaced; a middle row of 3 pins (there is room for 4 pins but one pin is missing just left of centre); a bottom row of 2 pins. I numbered these as follows:
8 o 7 o 6 o
5 o 4 o 3 o
2 o 1 o
The wire from the controller comprises 8 coloured cores and a bare core. The wiring of the eight cores are as follows:
DIN CORE PCB
pin 8 - brown 8
pin 7 - red 7
pin 6 - orange 6
pin 5 - yellow 5
pin 4 - green 4
pin 3 - blue 3
pin 2 - white 2
pin 1 - black 9
body clamp - bare wire - G
In case your coloured cores vary from mine I have also listed the pin each one goes to on the printed circuit board plug, which will let you identify the colours.
Oct 11, 2007 | Level 9 Sound Designs Monsoon Planar Media...
2000P Radar Detector Logo
Top K40 Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a K40 Vehicle Part and Accessory Expert? Answer questions, earn points and help others
