Question about Achiever CCS5000 Shredder
Achiever CCS5000 Shredder has power but will not shred paper
My Shredder has power to it but does not want to shred any paper.  Forward or review does not seem to do anything.
 I can not find my manual.
  • Loc T Jan 02, 2008
    I am getting power to the unit but the motor will not run nor will it shred paper.
  • Anonymous Feb 13, 2008
    Problem Solver:
  • 15 Answers
Check the main fuse to the motor unit.
Posted on Oct 17, 2007
Infoguard shredder SX-102 runs in reverse but not forward
Shredders have a manual switch for reverse..... if you have tried this, then there could be a possibility that the switch has dust of paper in it and the contacts not making contact for the reverse cycle... or the switch is faulty. If you have any electrical knowledge, you can do a test with an ohm meter for continuity in the reverse mode.... or remove the switch and blow it out with an air compressor. If you mess with electrical, ALWAYS REMEMBER TO UNPLUG THE SHREDDER!!!
Good luck.........
Jul 14, 2014 | Achiever CCS5000 Shredder
Ccs/5 shredder wont power on
Do a very thorough inspection of the cutting blades. I have found that just a shred of paper, that one would think would not be a problem, can in fact make your shredder act as you describe. How old is it? Depending on age & the heavy usage you say it has had.... it could very well be good old made in USA obsolescence. Wish I could tell you more. Without a multi-meter;(Ohm Meter). & manual to know what power is getting from point A to point B I cannot advise beyond this. Sorry.
Dec 25, 2013 | Achiever CCS5000 Shredder
Our Achiever CCS5000 worked well until it was
Hi Alan,'
it is not available, you could find the interlock switch and jump them...cut wires off of switch and twist together, then use electrical tape.
Mar 03, 2010 | Achiever CCS5000 Shredder
I have an achiever heavy-duty crosscut shredder that I purchased in 2002. Since that time I have actually used the shredder around 5 times. The shredder turns on, shred for about 2-3 mins., then it stops....
does it finish the sheet of paper then shut off , or does it stop halfway thru the paper?
unplug the unit , open it up and see if theres staples or junk jammed in the cutting wheels/gears
there supose to turn off once its finished with the paper and turn back on when the next paper is inserted , theres a lil sensor that turns it on and a limit switch that turns it off
Jul 11, 2009 | Achiever CCS5000 Shredder
Squealing Shredder
you need to spray lubricant down the paper shout. the cutter wheels are dry. They make a shredder oil but you don't need that just a light what oil. wd40 is to heave. If the noise is still there then it is in the gear train and will need to br serviced.
but to much oil will make a build up of dust also it's a catchy 22
Nov 03, 2008 | Achiever CCS5000 Shredder
I need a manual for my shredder
the overload beeper want cut off and there no paper in it
Aug 27, 2008 | Achiever CCS5000 Shredder
Achiever shredder
The fuse has blown and we need a new fuse for it. We need the fuse number that is on the tip of the fuse. Do you know where we are able to purchase them from?
Jun 10, 2008 | Achiever CCS5000 Shredder
Achiever Shredder CCS5000
Is it on a 20 amp circuit? Check to make sure that it doesn't have a grounding problem or even the plug could be reverse woired.
Oct 10, 2007 | Achiever CCS5000 Shredder
Noisey Shredder
Have you oiled the blades? When was the last time it was serviced? There is an awful lot of paper shredds inside the unit. Motor bearings need lubrication. Gears need grease, etc. Put about a dozen drops of light oil directly down into the cutter left to right every half inch. I have used vegetable oil in a pinch.
Feb 01, 2007 | Achiever CCS5000 Shredder
Achiever CCS5000 Shredder Logo
232 people viewed this question
Top Achiever Office Equipment & Supplies Experts
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
