Question about iHome Technology iD83 App-Enhanced Dual Alarm Clock Radio for
No display on ihome id83
No display
How do i set the alarm on my ihome alarm dock?
Once the time is correct, users can move on to setting the alarm itself. Many iHome systems come with dual alarms allowing couples to set different times for each person or individuals to designate a weekday and weekend alarm. Each alarm has its own time, wake-to source, and frequency. The process of setting the alarm is the same for both options, the only difference is what button, either 1 or 2, users depress when setting it.
Once ready to set an alarm, users need to push and hold the button down, waiting for the alarm time to appear on the clock's display. From there, the up and down arrows or plus and minus buttons adjust the time backwards or forwards accordingly. Once that is complete, users select the frequency of the alarm by pressing the alarm button again and then opting for 7, 5, or 2, which correlates with all week, weekdays, and weekends respectively.
The final part to set is the wake source of the alarm. Users press alarm buttons one more time, and then use the same directional buttons to choose from iPhone and iPad on some models, radio, buzzer, or playlist. If users choose playlist, they must also setup a playlist within their Apple device titled iHome.
Because frequency is part of the alarm setting process, there is no need to turn on the iHome alarm manually as one would do with a normal alarm clock. However, users can check to see if the alarm is active by looking at the screen of the clock for the earliest alarm time, displayed on its lower part.
In the mornings, when the alarm sounds, users have two options: Snooze and disarm. The disarm process turns off the alarm until the next day in its frequency chain. Users disarm the alarm by pressing the power button. On the other hand, users must manually program the snooze button. Users do this by pressing and holding the snooze button and then toggling to the desired snooze time, generally between one and 29 minutes. Once this is set, users simply press the snooze button in the mornings to delay the replay of the alarm for that amount of time.
Jul 18, 2014 | iHome Audio Players & Recorders
Tip
How to connect an my iPod Nano 3rd Generation to an iHome
<p>Your iPod nano to a device like the iHome to boost output audio or video to a TV in your memory. The iHome also charge your phone as it is docked. You need to take steps to ensure that your iPod will be able to successfully dock the iHome. Once your iPod is well prepared, so you get the most out of your drive for iHome. <br /> <p><br /> <p>1. Connect your iPod to your computer and launch iTunes. <br /> <p><br /> <p>2. Click "Help" from within iTunes, click "Check for Updates". <br /> <p><br /> <p>3. Select "Yes" when asked if you want to download and install updates. If no updates are available, disconnect the iPod. <br /> <p><br /> <p>4. IHome Connect your unit to an AC outlet. <br /> <p><br /> <p>5. Remove the protective layer of your iPod Nano, if applicable. <br /> <p><br /> <p>6. Let the iPod Nano in the dock with the front facing you. You will feel it snap into place. <br />
on Jul 21, 2011 | Computers & Internet
My ihome want charge my iphone 4
Your iHome may be an older model with an the wrong charge type. Different iPhone / iPod generations use different charge voltage with iPhone requiring a higher voltage than your iHome gives. My suggestion would be to get an adapter that should fix the problem.
Jun 02, 2011 | iHome iP90SK Dual Alarm Clock Radio for...
I want to play a Zen V on an ihome (portable speakers)
there is a double jack wire that should have come with your ihome plug one end ito your zen head phone hole and the other end in the back of your i home thats how mine works idk about yours but it should work the same for all ihomes
Nov 01, 2009 | Creative Labs Zen V MP3 Player
Stopped workign
Did you try removing the batteries and connecting only the adapter ? If the time is still displayed, then your adapter is still good.
Jul 10, 2009 | Dual Electronics ihome iH9BR iH9 Alarm...
iHome Technology iD83 App-Enhanced Dual Alarm Clock Radio for Logo
32 people viewed this question
Top iHome Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
