Question about Nikon D90 Digital Camera with 18-105mm lens
HOw do you unlock memory card on D70 NIKON - Nikon D90 Digital Camera with 18-105mm lens
    Novelist:
    Scholar:
  • Nikon Expert
  • 197 Answers
All SD cards I have ever seen can be locked with a little slide on the left side as you face the label. if the slide is up, the card is unlocked and can be used for taking pictures. If the slide is down, it is in the locked position, which prevents it from overwriting anything that is currently on the card. Before you unlock it you may want to verify that all pictures on the card (if any) have been saved because once you start using the card and overwriting its contents, the pictures are gone forever. If the card is empty, just unlock it, format it and start taking pictures
Posted on Jul 14, 2014
SOURCE: Nikon D70
MEMORY CARD
Posted on Sep 16, 2008
  • 26 Answers
SOURCE: Nikon D70 won't recognize the 2 GB, type II memory card
Try to clean the contacts of the memory cards and, mostly, of the memory card bay of the camera. Use a dry anti-static fabric (e.g. what we use to clean eye-glasses). DON'T use any liquid cleaner of anything like that!
Posted on Dec 11, 2007
Gryfox
  • 216 Answers
SOURCE: Nikon D70 (Control Panel.)
This is a known problem that is being repaired FREE of charge by Nikon. Go here for a form to fill out: http://www.nikonusa.com/email_images/nikonusa/service_advisory/d70.html
Posted on Nov 19, 2006
  • 18 Answers
SOURCE: I have a Nikon D70 and am unable to insert memory
STOP! You have just bent a few pins. Your camera has a male connection. Meaning it has pins sticking out. If you are unable to insert a memory card, that means a pin is bent and is not going into the holes in your memory card. This is a common problem with cameras that accept a compact flash card. This can be an easy fix or it can be a very hard fix.
Ive fixed a couple of cameras like this with a pair of tweezers. flash light (or some big source of light) and a magnifying glass. You need to look into the slot on the camera under light and look at all the pins sticking out. Look for the bent pins and use the tweezers to bend them back. Be careful not to keep bending the pin back and forth, as this will break the pin off. Ive seen cameras work without certain pins, but this is not something you want to do.
To have an SLR fixed is a minimum $160 dollars depending on where you take it too. The D70 is a good camera.
Please do not stick the memory card back in. Check the memory card to make sure all the holes are clear and have nothing blocking the holes or make sure a hole has gotten bigger and merged into one. I would use a different card once the pins are are sticking straight.
Hope this helps you.
Posted on Mar 30, 2009
Steve5
  • 423 Answers
SOURCE: Nikon D70 memory card won't insert all the way
It certainly could be. Without a card in the way, take a look into the card chamber to see if you have a bent pin. They should all be straight up, and a bent one will be obvious. If it's just slightly bent, it can often be straightened with a small jeweller's screwdriver. They are delicate, so bending them repeatedly will break them off.
Posted on Apr 04, 2009
Lexar memory card 4gb premium 60x
If it is an SD or SDHC memory card the answer is yes.
May 25, 2013 | Nikon D70 Digital Camera with 18-50mm Lens
Everytime i connect my nikon d70 to my laptop, there is always a problem with the installation of the hardware.. i can i solve this? is there other way aside from removing the memory card and connecting it...
You can try downloading the camera drivers directly from Nikon's website then see if the computer recognizes the camera, if not you will need to use a different computer to avoid a card reader.
Jul 30, 2011 | Nikon D70 Digital Camera with 18-70mm Lens
I have a Nikon d70 SLR. I had this camera completely cleaned and tuned up 3 months ago. Recently I can not take pictures. The battery powers the camera, but the shutter wont engage. An "error" message...
Read the manual on how to do a two-button reset. Also: from the nNikon Support Page on the D70::
It has come to our attention that select electrical components in a limited number of D70 cameras may, in some instances, fail affecting camera performance and/or operability.
While only a limited number of D70 cameras are affected by this advisory, if (1) when a memory card is inserted, your D70's memory card access lamp blinks, locking camera operations and preventing operation, or (2) with no memory card inserted, the camera will not turn on despite the battery indicator showing a fully charged battery, Nikon Inc. will service it free of charge.
To obtain complimentary service for cameras affected by this advisory, please click the link below to download and print the Service Return Form. The Service Return Form provides return instructions.
The Frequently Asked Questions button at the bottom of this page offers more information about this advisory and, should you have more questions, also provides information about how to contact Nikon.
We apologize for any inconvenience you may experience.
Sep 03, 2010 | Nikon D70s Digital Camera
What does HR in a Nikon D70 mean?
Hi. HR is an error code which is related to the memory card. It doesn't have exact meaning (as far as I know, its not in the manual and website).
There are several possibilities why you are getting this error. It could be corrupted memory card, damaged pin, loose connection between the memory card and camera, dirty contacts, camera is not giving enough power to memory card, etc...
Some fixes that may work:
- Make sure your battery is fully charged.
- Remove memory card and put it back making sure the connection is not loose.
or
- Clean the gold contacts using pencil eraser. Remove eraser dust with cotton buds.
or
- Format the memory card on the camera.
- If all fails, use a different memory card.
Good luck.
Aug 25, 2010 | Nikon D70 Body Only Digital Camera
My nikon d70 says that file does not contain image data
If the memory card came from a different camera and inserted into the Nikon D70, the error message will appear. Just format the memory card with the D70 and the error should disappear.
Hope this helps.
Andrew
Feb 05, 2010 | Nikon D70s Digital Camera
Have a Nikon D70, tried to load the memory card into the slot, and the grey button doesn't pop out when the card is put in the slot....the card wont go the whole way in
If there is nothing obstructing the slot, and you are inserting the card correctly, check the sides of the memory card to see if they are not damaged.
Jan 29, 2010 | Nikon D70 Body Only Digital Camera
My NIKON D70 has trouble with flash cards larger than 2 G.
The D70 has known issues with certain cards / capacities. Nikon has identified the cards and capacities that are guaranteed to work with the D70 specifically, on their page dedicated to this info linked below:
http://support.nikontech.com/app/answers/detail/a_id/9601
It seems that only Lexar and Microdrive cards that are 4Gb are supported (some with significant limitations) and no card greater than 4Gb is supported at all, regardless of manufacturer.
Oct 10, 2009 | Nikon D70s Digital Camera
Nikon D70 digital camera memory card cannot be used
First read:
http://www.vandyll.net/?p=499
Then read how, with pics:
http://www.stephanmantler.com/wordpress/d70s-camera-repair/en/
Careful now....
Dec 09, 2008 | Nikon D70s Digital Camera
D70 stuck
Make sure your memory card is OK. Take it out, put it back in or try another card. Be sure battery is charged. Should not see low battery sign in viewfinder or in top panel. Try a reset. There is a problem sort of related to what you describe where a firmware update may cure it. D70 Firmware Update 1.0.1 / 1.0.2 - Windows. One of the problems this firmware fixes is :"When images were captured in Continuous mode at an Image size setting of M and an Image quality setting of FINE, the memory card access lamp sometimes glowed continuously and the camera could not be turned off with the power switch. This problem has been corrected." This bit of advice comes from another Web forum, not my own discovery. Maybe this happened and ran down your battery, unbeknownst to you. Turn the camera off and power it from an electrical outlet. Update the firmware per instructions on the Nikon site. If this does not work or if your firmware is updated, call Nikon for further advice. You may need to have it serviced. This blinking light problem has been mentioned on PN and another forum. Nikon may be familiar with it already.
Sep 14, 2005 | Nikon D70 Digital Camera
Nikon D90 Digital Camera with 18-105mm lens Logo
35 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
