Question about GE Refrigerators
TFG28PF replace water spout on front of fridge
4 Suggested Answers
  • 25 Answers
SOURCE: Water keeps dripping from spout .....................
usually bc water valve not completely closing . i wud replace it
Posted on Jul 03, 2008
  • 126 Answers
SOURCE: refridgerated water spout suddenly stopped producing water
Have you changed the water filter. It should be located in the front loer grille of the refrigerator.
Posted on Jan 10, 2009
oldTech2332
  • 2341 Answers
SOURCE: I have a Kenmore side
sounds to me that the line inside of the door is cracked. Their is no easy way to repair that, either the entire door must be disassambled to replace that line,or replace the outerdoor panel with the line embedded into it,to replace the door panel it requires transfering all the compentents fmor old to new door panel, a partial list of things that must be transfered parts from old to new outer door include but not limited to
inner door panel
door gasket
dispenser asm (which cant come out as one piece and must to disassabbled into appx. 20 parts)
wiring
hinges
door handles
Posted on Jul 26, 2011
I have a Kenmore side by side fridge with ice/ water dispenser in the front door. When I push the water dispenser the water comes out the spout but also some comes out behind the spout making a mess. Is...
inner door panel
door gasket
wiring
hinges
door handles
Jul 26, 2011 | Kenmore Side by Side Refrigerator
The water supply line to the ice maker on my Whirlpool side by side refrigerator is visibly frozen, and will not supply water to the ice maker. How do I fix this?
With the information given , I would say to pull fridge out from wall , and remove the 2 screws holding the spout . Pull the spout out and defrost with warm water . Reinstall the spout and replace the water inlet valve . Valve had to have a slow leak for the tube to freeze . A model number would have helped to give a more precise answer .
Aug 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser spout broken
we had the same problem. My husband cut a flexible straw to the length he wanted, and crammed in in the hole. works great !! saved between $ 35.00 and $55.00 (labor was free)
Aug 06, 2009 | Whirlpool GS6NBEXR Side by Side...
Frezzer leaks into fridge
This is usual. In some refrigerators it is designed that way. It will keep the vegetables etc. in the fridge from drying out. Usually this spout is close to the back wall of the fridge. It is designed such that water drips directly to a small hall on the bottom of the fridge. It is important that you don't push the dishes or food in the fridge too far back. Otherwise water will be on you food. This spout should be far back as I mentioned. If, for some reason the water is dripping not close to the back, the spout may have beent damaged or bent. Check to see whether it is OK.
Jul 31, 2009 | Refrigerators
Refridgerated water spout suddenly stopped producing water
Jan 10, 2009 | Refrigerators
No chilled water
REPLACE THE DUEL WATER INLET VALVE ON THE BOTTOM BACK OF FRIG.-,SEARS .COM- PARTS,MIKE
Dec 06, 2008 | Samsung RS2630SH Side by Side Refrigerator
Water leaking from refrigerator
hi thanks for the question you can, remove the spout use a flat screw driver and pry off . now clean it pull fridge away from the wall remove the drain tube from the back clean reinstall thanks the appliance doc
Sep 28, 2008 | Refrigerators
Jul 02, 2008 | Whirlpool GD2SHGX Refrigerator
Water won't dispense
check water container in fridge is not frozen up
Jun 19, 2008 | GE Refrigerators
Water comes to the fridge but spills out rather than through the water spout
you may have a bad connection that may have to be tightened or a bad gasket that is leaking or possibly a bad switch that is not shutting off and lets the water through – please check you owners manual for the trouble shooting section for this problem as well or cal the service professional to serv ice the unit and replace the part
Apr 14, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
