Question about Emerson 22" Class LED-LCD 720p 60Hz HDTV, 2.1" ultra-slim LE220EM3
HDMI not working with Playstation3
I tried 2 different cables, none of which have solved the problem. HDMI is detected on the game system, but the screen remains blank on the HDMI channel for the tv set.
2 Suggested Answers
  • 11 Answers
SOURCE: This set stopped detecting channels when I run a scan. I ran the coaxial from the cable direct to the tv instead of the cable box and it read about 16 channels but the channel numbers were odd like 10
Red and white are audio lines and all yellow is video. You sound like you are missing the video line.
Posted on Nov 11, 2011
Playstation3 has sound but no video
Okay, do you have it through a HDMI or AV cable?
Whoever used it before you have the settings on either HDMI or AV, which means if you are using the other one, the video will not come up
Its a bit hard to explain but you should hook up both HDMI and AV and find out which one it is coming through, then change the setting to whichever one you want
Feb 28, 2013 | Sony PlayStation Video Game Consoles &...
Cant get output ps3 on hdmi cable
  • Make sure the system is off.
  • Hold down the Power Button for 5-6 seconds - until you hear the second beep.
    This resets the video settings to defaults (standard video output).
    Power up the PS3 again and it should auto-detect the hdmi at this point.
    If that does not work use the original audio/video cable that came with the system, power it on, then adjust the video settings and try the hdmi cable again.
  • May 18, 2012 | Video Game Consoles & Games
    Hi, I have hooked up by PS3 to my flat screen tv and now have no sound for the game everything else has sound what can i do to solve this
    Are you using hdmi cable? I would try different hdmi input or try different cable if you have one. If still using a/v cable make sure the white and red audio cable are plugged to the same input as your video. If that doesn't work you can try resetting the video on your ps3 by holding the power button until you get the 2 beeps.
    Dec 24, 2010 | Sony Playstation 3 (PS3) Console
    I have a new Sony HDMI LCD tv and a PS3 game system. I am having trouble playing Dead Rising 2 in 1080i mode. It will only play in 720 p mode, even though I changed the setting to 1080i on the...
    Some hd tvs do that,,its not u,,try in ps3 settings turn only 1080i setting on,,only,,same on tv also,,if not try with evryone of them selected,,let hdmi cable do it automatic
    Nov 04, 2010 | Video Game Consoles & Games
    My playstation 3 keeps chagning the colours
    Hi
    i'm guessing you have a HDTV
    first try different hdmi cables and see if there is any change
    if not The actual component plug-in in the TV can be the main problem
    if thats not the problem try to Hook up the HDMI.
    Then when you turn on your PS3 hold the power button down for 5 - 10 seconds and you will here a beep.
    The console should then go into AV auto detect and find your HDMI connection.
    if none of them is working try to contact with your manufacturer
    Nov 28, 2009 | Sony Playstation 3 (PS3) Console
    None of the outputs on my ps3 three work...tried hdmi cables and the regular cables ...other systems work using the same connections on my tv any advice?
    try using the hdmi cable then turn hold down the power button until 2 beeps and then a screen should pop up and follow what the screen says if this does not work try it with the rca cables.
    Jun 30, 2009 | Sony Playstation 3 (PS3) Console
    Change HD settings on lg plasma tv without remote
    u need tv remote, with that u can go to the options for ur tv and enable the hdmi allowing ur ps3 to come onto ur tv.
    Dec 31, 2008 | LG 50PX1D 50 in. Plasma Television
    The starup screen is not going to the main menu
    Try this:
    Hard Reset procedure for the PS3 (as instructed by Sony CS).
    Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
    1. Power Off the PS3 via the power switch in back and power back on w/switch.
    2. Hold Power Button on the Front until you hear 3 beeps.
    3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
    4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
    Hopefully this will solve your freezing problems.
    May 11, 2008 | Sony Playstation 3 (PS3) Console
    PS3 trouble shooting
    i hooked up my ps3 with hdmi cord and it looks good, but the no sound so what might be the problem
    Dec 27, 2007 | Sony Playstation 3 (PS3) Console
    Emerson 22" Class LED-LCD 720p 60Hz HDTV, 2.1" ultra-slim LE220EM3 Logo
    29 people viewed this question
    Top Emerson Televison & Video Experts
    matt martin
    matt martin
     Grubhead
    Grubhead
    Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
