Question about Garmin Forerunner 405 Handheld GPS Receiver
How to turn off garmin forerunner 10 - Garmin Forerunner 405 Handheld GPS Receiver
5 Suggested Answers
JohnE5
  • 34 Answers
SOURCE: Garmin Forerunner 201
Try a reset. Hold the reset and power button for 30 seconds.
Posted on Jul 11, 2008
SOURCE: Change battery on Garmin Forerunner 301
Hi - look at this solution for a forerunner 201, which has the same case design. I was just looking myself! R_nz Rank: Apprentice Rating: 96%, 8 votes I've made some progress here, I discovered that there is a small notch beneath the flat black pastic insert that holds the rubber button cover in. By gently prising this out, I can at least expose the pcb with the buttons on. I still can't figure out how to open the case though ****! Comments: Jan 29, 2008 - Well, I got there in the end! As above, I managed to prise the plastic insert cover off the rubber button cover, the peeeled this off as well. Underneath is a mylar printed circuit with the silver domeos of the buttons moulded in. This is siliconed down, but you can peel it up with a fingernail. The top left end (above the on button) is aatached inside the case, so start at the other end. Jan 29, 2008 - .ctd.. Once you have lifted the mylar strip, you can get at the case seam underneath and prise it gently open with a flat blade. The case is glued together with a light silicon or something. My problem was unresponsive buttons and by detaching and then re-attaching the small connector by the big silver block where the mylar attaches to the main board and then re-attaching it, it seemed to fix it! :-) Oct 22, 2008 - As an end-note; I glued my 201 back together with a light Silicone sealer. It seems to be at least rain proof anyway. Forerunner 201 battery replacement (Expert level): Opening the 201 was not easy and could not be done 100% clean, but thanks to R_nz (above) I got it open. My problem was dead (almost) battery, after 6 years of superb operation. I found the battery to be glued (double sided tape) to the back cover. To remove, push it up slowely and pull out. Beware of the short wires. 1. It is a flat battery, wrapped in shrinkable tube. Made by MDTechnology, P/N 043048 3.7V, 500mAh see http://www.mydbattery.com/EN/products.asp?ID=12 2. On the cover, the battery is soldered to the underside of a small PCB, hard to get to (by expert!). If you find a battery, suggest to cut the wires and solder wire-to-wire. Hope that helps
Posted on Jul 08, 2009
  • 84 Answers
SOURCE: garmin 305 forerunner
you can't. If it is getting softer and softer the speaker may be on it's way out.
See this link for a possible reason (bottom of the page).
http://ctorunner.googlepages.com/dismantleforerunner205
Posted on Nov 13, 2009
  • 84 Answers
SOURCE: Garmin Forerunner 305 sound
check out this link...
Garmin 295 forerunner will not turn on
Did you mean the Forerunner 205?
It is most likely that the battery has died in the unit or there may be a problem with the battery charger.
The internal battery in the Forerunner 205 is not user replaceable and the unit would need to go back to a Garmin repair for replacement.
Please call Garmin Tech Support for assistance.
1-800-800-1020
Feb 29, 2012 | Garmin Forerunner 205
My garmin forerunner 305 turns off automaticly after a couple of minutes, and the battery is fully charge.
Try SW reset. Hold Mode and lap/reset for 10 seconds, then release and long press start until device restarts.
Should clean up default.
If not try hard reset, but you'll loose all data in device.
hold mode and start for ten second, device needs to off before.
Then keeping these, pulse press lap/reset.
You'll get a confirmation screen
Oct 04, 2010 | Garmin Forerunner 305 GPS Receiver
My garmin 305 don´t turn on
I got the same issue. There is a trick to reset it (hold mode & reset buttons for 10sec, wait 10 sec, turn on with pressing power for 10 sec).
Mine is starting then once, then same problem when switching it off.
Aug 12, 2010 | Garmin Forerunner 305 GPS Receiver
My gramin forrunner 305 sudenly doesn´t turn on what should I do
Use reset procedure as indicated in Garmin book or support center (hold reset plus mode buttons for 10 sec on charger, then wait 10 other secs, then start again, all this connected to PC.
Garmin Forerunner 305 won't turn on and won't charge. Is there a fix or is this it for the device?
Look at
"http://www.activesplit.com/my-garmin-forerunner-305-doesnt-power-on-its-just-dead-solutions/"
You can soft reset or hard reset the device. Hard reset deletes all data.
Apr 01, 2010 | Garmin Forerunner 305 GPS Receiver
I just got a new garmin forerunner watch. How do
Follow this link, give all the details of your device and download it:
http://www8.garmin.com/support/userManual.jsp
If this doesn't work - give us next question.
Rate me, please.
Aug 15, 2009 | Garmin Forerunner 405 Fitness Watch/GPS...
My garmin 305
Press and hold the mode and lap buttons for 10 seconds, then release. Most of the time, that will fix it. Garmin has a sort of sleep mode programmed in for certain situations. If that doesn't work, I have had wonderful success with Garmin tech support.
May 16, 2009 | Heartbeat Garmin Forerunner 305 Gps...
My Garmin forerunner 305 will not turn on.
I have had the same problem. To fix it, I simultaneously hold down the "mode" and "reset" buttons for about 10 seconds. After releasing the buttons I power it up as normal. This has worked both times it has happened, and I got this fix from the Garmin website. My mileage totals are still in the history.
Dec 14, 2008 | Garmin Forerunner 305 GPS Receiver
Mar 11, 2008 | Garmin Forerunner 201 GPS Receiver
Garmin Forerunner 405 Handheld GPS Receiver Logo
94 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
