Question about HP PhotoSmart Office Equipment & Supplies
HP photosmart 6510 will not print
Printed fine, ran out of black ink. Replaced black cartridge. Other color low, but didn't replace.
SOURCE: HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Posted on Oct 22, 2008
Joed911
  • 4338 Answers
SOURCE: my photosmart hp C6180 keeps saying printer
C6180 reset:
Perform a semi-full reset to set all user menu settings, telephony parameter settings, country/region and language UI, fax memory settings, fax journal information, speed dial and broadcast lists, personal header information, and junk fax settings to the default settings. Performing a semi-full reset of the All-in-One
  1. Use the On button to turn on the product.
  2. Remove the power cord from the product.
  3. Press and hold the # and 6 buttons.
  4. While holding the buttons down, connect the power cord to the product.
  5. Continue to hold the buttons down until the color graphics display becomes blank, then release the buttons.
  6. Use the On button to turn on the product. The reset information appears on the color graphics display.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01457329&cc=us&lc=en&dlc=en&product=1153494
Or a Full reset:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00720248&cc=us&lc=en&dlc=en&product=1153494
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jun 12, 2009
SOURCE: My HP photosmart 7660 won't print black.
clean the connector between the cartridge and the brownish part in the printer where the cartridge touches. it might be dirty and thus not enabling the connection with the black
Posted on Aug 19, 2009
nirikip
  • 56 Answers
SOURCE: HP Photosmart C7280 color ink running out despite not using it?
  1. Unplug power cable while the printer is ON.
  2. Press and hold the '#' and '3' buttons, and plug the cable back into the printer.
  3. Continue holding the buttons down for 20 seconds, and then release it.
if doesn't initialize successfully repeat
on step 2 press and hold the '#' and '6' button and plug in the power cable.
Posted on May 13, 2010
  • 1751 Answers
SOURCE: I have two cartridges in
Hi
You can bypass the alignment on 5610 by pressing ok to start alignment
and then cancel
after that check by printing a document if your cartridges work fine if not
you can refill them with this easy and cheaper method
Posted on Jan 19, 2011
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
My photosmart 6510 wont print black ink
Welcome to the club mate :) Throw it out and stop buying new cartridges before you pay double the price of the printer in cartridges... This is a known problem, without any fix. Should I congratulate you on buying a nice disposable printer?
Aug 03, 2012 | HP Photosmart 6510 e-All-in-One -...
I have two cartridges in my 5610 a #22 color and a #27 black. I received a low ink message, but didnt know which one was low. I noticed that the most recent Word document looked fuzzy so I replaced the...
Hi
and then cancel
Jan 19, 2011 | HP Officejet 5610 All-In-One InkJet...
Can the hp4180 run with just the black ink cartridge filled with ink and not the color cartridge
no, I don't think that it is recommended to run with just the black ink cartridge filled and no color cartridge.
But, you can try it, as some hp printers do work that way.
The instructions say that low ink cartridges should be replaced to get the best print quality.
Jan 01, 2011 | HP Photosmart 4180 All-in-One Printer
Have a hp photosmart premium c309 and have changed the ink cartridge and the black ink is not printing well. All the other colors prink well
HP Photosmart Premium C309 not printing black
Got that problem also, Black would not print but dark grey would be printed ???
What i did and it worked was reset to factory settings, unpluging the printer for ± 25 seconds
holding 3 and # for and other 25 seconds went and after pitting power back on
then re-enterring your setting, all went fine
http://h30434.www3.hp.com/t5/Other-printing-questions/Photosmart-C309-suddenly-stopped-printing-black-ink-any-solution/m-p/495549#M30719
Hopping this will help others
Nov 10, 2010 | Office Equipment & Supplies
Failure of Printer to Print Color
Try using a new HP ink cartridge. I had the same problem with a printer I purchased off of CraigsList even though the ink level was good. I installed a new color HP ink cartridge and it printed without a problem.
Jul 29, 2010 | HP Photosmart C3180 All-In-One InkJet...
Just replaced my black ink but printed page comes out blank
Change your print preferences to black and white as a work-around until you get color.
Aug 10, 2009 | HP PhotoSmart 7660 InkJet Printer
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
22 people viewed this question
Seeker5211
Seeker5211
