Question about Pioneer AVIC-N1 Car DVD Player
Touchscreen Any button, number or letter in the far left edge of touchscreen does not respond when pressed!
  • 3 more comments
  • gadish123 Dec 14, 2007
    avic n-1 screen calibration
  • OneLittleBoy May 25, 2008
    so i have the same situation. now i do a reset so i can calibrate my screen. i can't calibrate my screen. it will not work correctly. why? error message "invalid by the outside of a permissible value" can anyone help me? i can't trace the white line or at least i did but there's an error!
  • Anonymous Nov 07, 2008
    Same problem; same error message. Pioneer tells me to bring it to a dealer. elp!
  • geminijr23 Dec 30, 2008
    I tried the steps and it seem to work but the only way to exit that mode is to press the reset button.  Therefore everything goes back to default  is there a way to save changes.
  • geminijr23 May 11, 2010
    I did all of the steps but the changes do not seem to save and i can't exit the main screen unless i press reset, which brings everything back to default.
U have to:
eject any cd from unit
press and hold eject button then press resey key (small pin above the right nob)
Hold down eject until screen goes in and back out.
then it will ask you to press reset do not
on right nob pres up up down down center
it will take you to the cal screens
caution do not do anything else other than
enter the touchscreen calibration and perform steps 1-4
this units touchscreen does have tricky set points gl
Posted on Oct 16, 2008
How do you "calibrate the unit" ???
Posted on Oct 14, 2008
Try calibrating the unit
Posted on Oct 22, 2007
Garmin 2720 touch the (s) and the (T) responds
You need to recalibrate the touchscreen. Try this: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Go through the entire procedure of pressing each dot as it appears on the screen.
Once completed the Nuvi will display Calibration Complete This will recalibrate your touchscreen to the LCD display.
If this doesn't resolves your problem. then your touchscreen may be defective.
Please see this page for additional information:
http://www.sharc.net/gps_LCD_repair.htm
Feb 11, 2014 | Garmin nuvi 205 GPS Receiver
LG Incite touchscreen not responding
try to reset the phone by picking the reset hole on the side of the phone (i use a staple) the touchscreen should be a bit better to press the unlock button. hope this helps!
Nov 16, 2009 | LG Incite Cell Phone
Garmin nuvi 205, sometimes it won't respond to my touch. Sometimes when I go to give it a name or address it just keeps repeating a letter, "aaaa, or jjjj. then when I touch the botton to go back or clear...
Your touch display is shorting out....BAD
Replace Unit
BUT try this first:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
Does this help? Let me know. Thank you...
Nov 03, 2009 | Garmin nuvi 205 GPS Receiver
I'm getting inaccurate letter entry on the letters I type. For example, when I type a B an M appears - I'm noticing it on the bottom row of letters at this time. Solution?
Are you sure you pressed the correct location on your screen???
If so, you may need to calibrate the screen.
Do this:
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Palm TX power button and touchscreen
We have three TX's in our family with non-working power buttons. I downloaded the program Au Dodo http://www.freewarepalm.com/utilities/audodo.shtml and simply now use the far left button (button 1) as my 'power' button. It works wonderfully.
I haven't found out how to fix the calibration problem, but power on/off has been totally fixed. Good luck for you.
Jul 06, 2008 | Palm TX Handheld
Treo600 Touchscreen doesn't respond.....
Try running a piece of paper around the edge of the screen. There may be was something stuck in there, pressing the screen slightly and causing it to not respond to the stylus
Jan 14, 2008 | Palm Treo 600 Handheld
Nintendo DS touchscreen problem
try calibrating the touchscreen....
Jan 08, 2008 | Nintendo DS Console
Touch screen
You may have dust accumulation around the edges of your touchscreen, between the screen and the case. Try using a can of compressed air. Gently press down on the edges of the touchscreen to expose the gap between the screen and the case, and shoot the air in there. This worked for me when my Treo 600 touchscreen stopped responding.
May 23, 2007 | Palm Treo 600 Handheld
Pioneer AVIC-N1 Car DVD Player Logo
532 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
