Question about MTX Audio Tna251
Tna 251 amp has blinking red lights and subwoofers stopped working, remote for amp also dead
Just installed and all worked fine for about 10 minutes then subwoofers stopped working, remote for amp also dead
4 Suggested Answers
SOURCE: Apx stopped working, MTX 702x
maybe the audio amplifiers Ic´s damaged or the power fet
Posted on Mar 06, 2009
jrw4u
  • 62 Answers
SOURCE: Everything works fine but my amp light is red.
if its not coming on it usually means you have a bad ground if it works for a little while then does it then its over heating and you will need to get a fan
Posted on May 01, 2009
timbadger21
  • 64 Answers
SOURCE: one day amp stopped working
it sounds like rca wires or the holder where the rca wires go in to the amp itself . geek squad can fix it for ya
Posted on Jun 22, 2011
Stopped working. Power light is on. Could it be a fuse? Can I change it myself? Is there a lifetime warranty?
Amp has power, but no sound! - ecoustics.com
www.ecoustics.com > ... > Archive through November 13, 2007 Forum
Nov 5, 2007 - The other night my fiance's amp stopped pushing the subwoofers. ....also, it was working fine for however long- and then just stopped working. if that were the case, it wouldn't have worked in the first place. .... lastly before u go saying but the amps power lights on i'm sure the amps ..... Car Speakers Forum WHY DOES MY AMP POWER LIGHT TURNE RED ON PROTECT ...
Sep 11, 2011
Please someone help me! I am dying without my music!!!
Aug 4, 2011
Subwoofer stopped working all the sudden
May 26, 2010
More results from www.ecoustics.com
Jan 18, 2016 | Audio Players & Recorders
My Toshiba 50H81 screen black, no sound & power light blinking
sounds as if your power supply needs to be repaired. the capacitors over heat and crown or leak.
Jan 01, 2010 | Toshiba 50H81 50" Rear Projection...
Amp works for a few minutes
too much power. turn your amp down a bit and let er rip.
Oct 01, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Amp is shutting off after 10 min of driving!! please help!!
Does it happen at all volume levels?
What is the gain setting on the sub amp?
Have you checked for 12V @ remote turn on after problem occurs?
Sounds as if the remote turn on relay inside the amplifier is losing signal, or has become damaged. If the protection light does not light up, the problem is not thermal, shorting, or high/low voltage.
The amplifier is in need of repair. This is not an end-user fix. Looking at about $50 to repair.
Thanks for using FixYa- a FixYa rating is appreciated!!
Feb 18, 2009 | Profile BAJA HA700M Car Audio Amplifier
Subwoofer stops working after awhile, but only one
it sounds like u blew them or the voice coils could be messed up here is one way to check take the woofer out of the box and look at the coils it should be ornge and then smell it if it smells like fire it might be going bad thats the reson it is frezzing like that let me no what happens and please rate me
Apr 07, 2008 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Amp Power LED Display blinks red and no sound
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. Does the voltage on either the B+ or remote pulse below ~11 volts when the LED flashes?
Jan 26, 2008 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Pt- red light on
mine done that the other day and i took the fuse out of the side of the amp for about a minute put it back in and came on dont know why it worked but it did hope that helps you l
Aug 25, 2007 | Performance Teknique ICBM-9560 Car Audio...
Hifonics 1605d stopped working
the red light blinking because your amplifaier its dead look for the alimentation cabel end replace the calibration protector
Apr 16, 2007 | Hifonics BX1500D Car Audio Amplifier
MTX Audio Tna251 Logo
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
