Question about Garden
Homelite chainsaw ut10753 won't cut under load! Changed plug and gas and rebuilt carb
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: 33cc 14 inch homelite chainsaw, wont rev up to
Morning William:
Acceleration is the "L" needle, try 1/8 turn CCW. No better 3/16 CW.
Please install a new filter on the fuel line, you will be beat to death with carburetor overhauls if you do not.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 27, 2010
WHERE CAN I FIND A MANUAL FOR THIS CHAIN SAW MODEL UT10753
You did not say who the manufacturer is of your chain saw. Is it made by Homelite?
Go to this website: http://www.manualsonline.com/ and type in your chain saw manufacture and model
Feb 21, 2016 | Garden
Looking for owners manual
ebook libraries may be the place to look... most chainsaws are configured in a similar fashion so almost any might suit.. try here..
homelite xl chainsaw manual free pdf ebook downloads
Mar 31, 2014 | Homelite Garden
I have a old homelite that won't start new plug fresh gas no spark
Most of the time on older engines, the carb needs to be rebuilt or replaced. Dont panic rebuilding is cheap an easy. The ports get clogged up sitting an varnish up. Try to clean out all orifices with small pieces of wire from steel or brass brush. Use carb cleaner to clean replace all gaskets an parts with kit. Dont forget to check fuel hose in tank they go bad often an should be replaced when carb work is done. Fresh gas an it should work
Mar 11, 2014 | Homelite Garden
Zama carb pulls gas when not running
throw the carb out and buy a new one. there is an internal issue that can not be fixed
Mar 20, 2013 | Homelite Garden
Homelite xl chainsaw won't start. I took out spark plug, put in some fuel and if fired right up. But won't run.
You need to clean out the carb. possibly replace the Needle Valve and check the Diaphram for stiffness. Also check the fuel line for cracks and rott.
Feb 10, 2013 | Homelite Garden
My cutoff saw won't start, compression is good, has oil/gas mix, gets spark from wire but sparkplug was dirty so i cleaned it and she still won't turn over
If the saw briefly runs when you prime the carb and/or cylinder with gas then most likely fuel is not getting thru the carb. Try rebuilding the carb and replacing the fuel filter first. You can also search on youtube and google for troubleshooting tips.
Jun 03, 2012 | Homelite Xl-98a, Xl-98c, Xl98-d, Xl98-e...
I have a Homelite model 20 chain saw. It will
on your machine may be on the side of it that led into the carb should have H for high L low L is for the idle H is for all out ball to the wall you will need a small long screw flat head . put in the H ,turn out for more gas in for less good luck
May 12, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
HOMELITE 245 CHAINSAW. IT WILL START UP , BUT WHEN YOU START TO CUT WOOD IT DIES OUT. I HAVE CHANGED THE PLUG , CLEANED THE MUFFLER , AND CLEANED THE AIR FILTER. MEL
check gas tank vent and cap. Adjust carb a small amount ie. back out screw marked L 1/4 turn. If that does not work adjust screw marked "H" 1/4 turn out if no results adjust back to original position and go 1/4 turn farther in.
May 01, 2009 | Garden
Loses power when trying to cut wood
Check the muffler screens first. Then the spark plug. If not the case, then adjust the High setting on your carb. Prolly starving for fuel under engine load. If it is still a problem, Pull the carb and clean it.
Apr 27, 2009 | Homelite ZR10926 16" Chain Saw
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
