Question about Electrolux Washing Machines
Electrolux washing machine ob error - Electrolux Washing Machines
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
localwonder
  • 6784 Answers
SOURCE: pump makes noise and water runs out of bottom of machine error ob
HI. You may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case, replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
A broken impeller will wobble inside the pump housing, causing loud noises during operation. This is a strong indicator of pump failure. This will, also, cause leakage as well. the integrity of the pump housing will be compromised, leading to this leakage.
Posted on Sep 11, 2009
SOURCE: Electrolux ewf1087 washing machine error code?
what is a (e40)
Posted on Jan 02, 2010
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Posted on Jan 21, 2010
  • 132 Answers
SOURCE: my washing machine won't drain. It will either
You probably need a pump or to clear the pump or drain hose just past the pump.
To access this you need to peel back the front emblem on the top of the front panel, there is a screw in the center take it out pull forward on the top and raise it, then remove the front panel (will see three screws), tip back and take the bottom panel off, pump is on bottom back right
ld is long drain, to my knowledge the pump is only sold as a assembly with the motor, which makes it a fairly expensive part, would pull the pump and see if anything is stuck in it first(have some towels and a pan when you do this)And unplug it.
Posted on Feb 21, 2010
How to fix a errow ob on maytag washing machine
OB is an out of balance load error, try re-distributing the clothing and see if it helps, also make sure the machine is level, if this doesn't help there may be a fault with the out of balance switch or lever.
Mar 06, 2012 | Maytag Neptune FAV6800AW Top Load Washer
A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
Jul 24, 2010 | Electrolux Washing Machines
There is water leaking out of a piece of plastic in the back of the washing machine it will not go any further than 23 minutes we keep getting the message ld and ob
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#!!##
Jun 15, 2010 | Whirlpool Calypso GVM9959K Top Load Washer
Machine is about 7 years old and gets stuck in one cycle, will not drain. Recieved code CA, LD and OB. Machine is stuck and won't drain!
Jan 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I own a kenmore elite heavy duty plus washer. During operation it stops and a message apears saying ob when you open the lid and close it ob disapears and I restart it and minutes later the timer never...
The OB error code is short for out of balance. There are two fixes that you can try: One is to move the clothing around in the tub. or Two the machine isn't level and is causing it to falsely error as out of balance.
Oct 30, 2009 | Washing Machines
I have an error message that reads ob. I have an
OB MEANS OFF BALANCE if the motor controller detects an unrecoverable off-blance condition, the machine controller will shut down and display ob. the lid switch must be opened at least once before restarting the cycle if this condition occurs. opening the lid will allow you to view and redistribute the load. press stop/cancel to clear the display. hope this helps.
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite (Calypso) Top loader Will start and fill up w/ water, and wash for a while. During the washing process it makes a humming noise and then the display gives a "ob" reading. I have replaced the...
Jul 18, 2009 | Kenmore 23822 Top Load Washer
Machine stops during spin cycle and reads 'ob' on the display
Read this thread about your error. I am sure it relates to your (drain) problem.
Good luck and if you have any more questions, just come back here and leave a comment - I'm happy to help.
May 21, 2009 | Kenmore Washing Machines
Calypso kemore elite washer
May 01, 2008 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
