Question about Irons
GREEN LIGHT INDICATOR DOESN'T LIT WHEN PRESSING
PRODUCT : BOSCH STEAM IRON TDS2510
GREEN LIGHT INDICATOR DOESN'T LIT WHEN PRESSING RED BUTTON FOR STEAM.
SOMETIMES, WHEN PRESSING SEVERAL TIMES, WE GET A GREEN LIGHT BUT VERY SHORTLY (ABOUT 1/10 SEC).
THANKS IN ADVANCE
  • 68 Answers
Lost contact maybe you dropped it ,that's why the wiring inside are loosen.By the way before u make troubleshoot of your appliance try to cheeck if there is a warranty.Then if there's not that's the time you make your own troubleshoot.
Posted on May 18, 2009
Hi Ihave a Bosch B25L steam generator iron and it has stopped steaming completely. Any ideas?
Yousaf/Tony, Either the switch is defective or the heat element has gone bad, probably not cost effective to repair.
May 25, 2014 | Bosch sensixx TDA 8333 Iron
Bosch TDS 1445/05 Sensixx station doesn't making steam
HI!
I HAVE AN Bosch TDS 1445/05 Sensixx AND THE IRON PLADE NOT WORM AT ALL. I CHECK THE POWER.I CHANGE THE THERMOSTAT/THE CONDENSER WITH THE LAMP/.BUT STILL NOT WORK. THE BOILER WORK GOOD.PLEASE HELP ME.WHAT CAN I DO MORE. THANK YOU
Oct 06, 2012 | Irons
Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Jul 31, 2012 | Bosch Irons
I have a bosch TDS25 steam generator iron and when I plug in and switch the iron on the green light light does not come on
if the iron is still getting hot and generating steam i would say the light has failed, however if nothing is happening you could change the fuse in the plug if you now how if not get some one who dose and if this dose not help then i think your iron has had it
Oct 01, 2011 | Bosch Irons
I have an bosch sensixx b5 iron and the calc clean sign keeps flashing what can i do .i have lost theinstuctions
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
Jan 25, 2011 | Bosch Irons
Steam Station FCL-SS167 Purchased today followed instructions for first time use when plugged in green indicator light does not light up and it does not steam unless surge button is pressed then it makes a...
NO IT NORMAL , THE WTAER HAS TO REACH 100,dec IE , BOILING POINT BEFORE IT CAN STEAM , NEXT TIME WAIT A BIT LONGER AND YOU SHOULD GET THE GREEN LIGHT .
Nov 05, 2009 | Irons
Steam generator iron beebs when button pressed but no steam green flashing light on aswel
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Sep 21, 2008 | Euro-Pro Steam Generator EP8001 Iron
Irons Logo
380 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
