Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
Where is the serial number located on the Hoover Windtunnel T series vacuum
The manual states it is on the bottom of the vacuum, but I can't find it
SOURCE: Hoover Steam-Vac Cleaner F5861-900 Series 17.9 Can't Find User Manual
http://www.hoover.com/pdfs/manuals/F5914900.pdf
this one works well as a replacement for the manuel.. everything is the same.
Posted on Dec 02, 2007
  • 4 Answers
SOURCE: Belt replacement
No belt- it is motor driven. what happens to these if the rollers get stuck(by- say, a Lego® or something)  is the roller itself has an insert which will break, requiring roller replacement.
simple fix, but costs a little more than a belt. remove two screws holding the roller cover, accessible by flipping the vac over. then figure out which roller is broken, and remove the 2 outer screws on that side. pull the outer bearing cup assembly straight out to remove the rollers.
I have found the rollers as cheap as $3.50 ea/ for generic replacements. Also I reckon any Vac shop would have them on hand.
Posted on Apr 28, 2009
VacuumRepair
  • 438 Answers
SOURCE: I have hoover WindTunnel Self Propelled Vacuum
Greetings from GoVacuum,
Here's a great video repair tutorial that we've put together to try and help you with the repair on your Hoover WindTunnel. I hope that this helps you with your repair. If you found this solution helpful, please rate this repair video by clicking on the 4 Thumbs Up Icons in the top right hand corner of my repair solution. Feel free to email me at chris.jones@govacuum.com if you have any questions about the repair!
Video Repair of Hoover Windtunnel Belt Change
Thank you very much!
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
VacuumRepair
  • 438 Answers
SOURCE: Replace belt for Hoover Windtunnel Turbo Power
Great Video Repair on the Replacement of the Hoover Windtunnel Self-Propelled Upright vacuum cleaners below. If you find the video helpful please be sure to rate it by clicking on the thumbs up icon below.
Thanks for watching my video, if you have any questions about this repair is done, please feel free to request clarification below.
Chris
Posted on Mar 21, 2010
SOURCE: How to replace power cord on Hoover WindTunnel upright vacuum
The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!) http://www.elkypro.com/hoops2005/vacuum_parts/hoover/U5461-900.html
Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
Posted on Apr 29, 2010
Hoover has no power. Is there a reset button?
Important Notice Regarding Hoover WindTunnel Series REWIND Bagless Upright... I found some interesting reading here that could pertain to you. Thank you and leave feedback for I am new at this. James please have a great day!
Jul 14, 2016 | Hoover U6437-900 / U6439-900 Windtunnel...
My Hoover Bagless Windtunnel vacuum has no suction on the bottom, although the hose works. Everything else seems to be working properly.
Check the belt, look like we have the same problem, I just unscrew the bottom part where he brush roller is located and found a broken belt
Easy to replace just follow this instrctions
Jan 31, 2011 | Hoover U5753-900 WindTunnel Bagless...
I have a Hoover WindTunnel with a bag that makes a burning smell. I cleaned the brush and the belt looks intact. It still smells really bad. Could it be as simple as needing a new belt?
yes it could be that simple. sometimes the belt will wear and stretch. Generally I advise my customers to replace the belt once per year, or as soon as something gets caught to stop the brush from turning.
Your belt number should be on the model/serial plate on the bottom of the unit there. 38528-###. I am guessing its a 38528-033 but could be 38528-040. Your model/serial plate will be more accurate.
Nov 05, 2010 | Hoover Ultra U6430-900 WindTunnel Bagged...
Switch does not turn on or off on hoover windtunnel u458-910
Hoover windtunnel switches can be easily replaced by your local Hoover/Dirt Devil dealer. Have them check the model and serial number to see if yours is under a recall for this issue. You may also have a mechanical plastic rod problem (this operates the switch).
May 02, 2010 | Vacuums
Change belts on a Hoover Power Drive Wind Tunnel Series 900 vacuum
Try calling Hoover directly toll free at
1-800-944-9200 M-F 8 AM - 7 PM EST.
Sep 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover windtunnel vaccum U6445-900 motor not turning on. I removed the screws and located the contacts inside. There is an on-off switch which seems to be stuck Is there a way to replace this switch
There are a number of Hoover vacuums that are subject to a recall due to an overheating on/off switch. Check out this web site to see if your is included. You'll need the model number and serial number from the back of the unit. The manufacturer will direct you to an authorized repair center for a free replacement of the defective switch.
http://www.cpsc.gov/cpscpub/prerel/prhtml05/05156.html
May 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel Bagless bolt fell off
With this self propell series, the entire bottom needs to come apart to re-install the nut. if it is one month old I would highly recommend taking it in for warranty service. What plastic is melted?
Nov 02, 2008 | Hoover U6630-900 WindTunnel Bagless...
I can not find a filter # 43613-026 for a Hoover Windtunnel model # U5361-950 Series #M 12.0
That filter number may also come up as a "package number."
Try looking for package number 40110008.
This is a commonly stocked item at most vacuum stores.
-R
Aug 01, 2008 | Hoover Vacuums
Hoover S3630 WindTunnel
Broken wire reconnected and power was restored.
Jul 13, 2008 | Hoover S3630 WindTunnel Bagged Canister...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
143 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
