Question about HP OfficeJet 6210 All-In-One InkJet Printer
HP OfficeJet can't send faxes, keep getting the speed dial empty message
I load a page to be faxed and when I start to dial the fax number, the message speed dial empty error message appears.
  • Anonymous Mar 29, 2014
    how to set up speed dial function on fax
    Genius:
  • 1,601 Answers
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
I want to fax a document
Hi
To send a fax from your hp officejet
Follow these steps to send a fax from your HP OfficeJet.
1 Load your original.
Note: You must use the automatic document feeder (ADF) for multi-page
faxes.
2 Enter the fax number using the keypad.
3 Press Start Fax, Black or Start Fax, Color.
Oct 26, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Is there a Fax modem available to be connected with scanner, copier and printer (three in one already with us.)
your unit has a fax installed in the unit.
Look at page 29 in your manual it will show how to send and receive a fax.
send a fax page 29
receive a fax page 32
print reports page 33
feature purpose
1 Phone Hook: the green LED in the shape of a phone indicates that the fax
line is in use when lit.
2 One-Touch Speed-Dial Buttons: use to access the first 6 speed-dial entries.
3 Auto Answer: when the green light is on, fax transmissions will
automatically be accepted.
4 Speed Dial: use to access speed-dial numbers that have been set up from
the front panel or with the HP Director software.
5 Redial/Pause: redials the most recently dialed number when in the ready
state. Inserts a pause (hyphen) when in the dialing state.
6 Keypad: use to dial fax numbers, and enter numbers such as the quantity
of copies or percentages when reducing or enlarging. You can also enter
text using the keypad for fax header, use speed dial entries, and specify
menu items.
7 Fax Resolution: use to set the fax resolution to Fine, Standard, 300 dpi,
or Photo. It will remain at the most recent setting until changed.
8 Start Fax - Black: starts a black and white fax.
9 Start Fax - Color: starts a color fax
Apr 27, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Cant install fax software for lexmark x5495 aio printer.
1. Unplug the printer from the PC
2. Uninstall all the software related to the All-in -One ( that is on the PC)
3. Connect the All-in-One again then follow the software instructions for reinstalling the printer.
From the instruction manual:
Sending a fax
Entering a fax number
1 From the control panel, press Fax Mode.
2 Enter a fax number using:
The text box Enter a fax number using the keypad.
Notes:
• You can include a calling card number as part of the fax number.
• Enter a maximum of 64 digits in a fax number.
• Press Pause / Redial to insert a three-second pause in a number you
are entering to wait for an outside line or get through an automated
answering system.
Speed Dial or Group Dial a Press Phone Book.
b Enter Speed Dial and/or Group Dial numbers.
• Press or repeatedly until the Speed Dial or Group Dial
number you want appears.
• Use the keypad to enter the number of the Speed Dial entry (1–
89) or Group Dial entry (90–99).
Notes:
• For instructions on how to add Speed Dial or Group Dial numbers
using the computer, see “Setting up Speed Dial” on page 118.
using the control panel, see “Using the Phone Book” on
page 108.
3 If you want to send a fax to a group of numbers (broadcast fax):
a Press .
b Repeat step 2, using any combination of the previous methods, until a maximum of 30 fax numbers have
been entered.
Sending a fax using the software
You can scan a document to the computer and then fax it to someone using the software.
1 Load an original document facedown in the Automatic Document Feeder (ADF).
2 From the desktop, double-click the Productivity Studio icon.
3 From the right pane of the Welcome Screen, click Fax.
4 Select the Document option.
5 Click Start.
6 Enter the recipient information, and then click Next.
Note: A fax number can include up to 64 numbers, commas, periods, spaces, and/or these symbols: * # + - ( ).
Faxing
103
7 Enter the cover page information, and then click Next.
8 If there are any additional documents that you want to send with your fax, add these now, and then click Next.
9 To send your fax:
• Immediately—Select the Send now option.
• At a scheduled time:
a Select the Delay sending until option.
b Set a time and date.
10 If you want a paper copy of your fax, select Print a copy of your fax.
11 Click Send.
Sending a fax using the control panel
1 Make sure the printer is on.
2 Load an original document facedown into the ADF or on the scanner glass.
Note: Do not load postcards, photos, small items, transparencies, photo paper, or thin media (such as magazine
clippings) into the ADF. Place these items on the scanner glass.
3 From the control panel, press Fax Mode.
4 Enter a fax number or press Phone Book to select a number from the Speed Dial or Group Dial list. For more
information, see “Entering a fax number” on page 103.
Note: To set up Speed Dial, see “Setting up Speed Dial” on page 118.
5 If you want to send a fax to a group of numbers (broadcast fax):
a Press .
b Repeat step 4 and press until a maximum of 30 fax numbers have been entered.
6 Press Start Color or Start Black.
Sending a fax while listening to a call (On Hook Dial)
The manual dialing feature lets you dial a telephone number while listening to the call through a speaker on the
printer. It is useful when you must navigate an automated answering system or enter a calling card number before
sending your fax.
2 Press .
3 Press or repeatedly until On Hook Dial appears, and then press . You can now hear the dial tone of
the telephone line.
4 Enter a fax number. For more information, see the related topic, “Entering a fax number.”
Note: Press the keypad numbers to use an automated answering system.
5 Press Start Color or Start Black.
Faxing
104
Sending a broadcast fax at a scheduled time
You can send a fax to a combination of up to 30 people or groups at a time you choose.
1 Load an original document facedown into the ADF or on the scanner glass.
2 From the control panel, press Fax Mode.
3 Press .
4 Press or repeatedly until Delay Fax appears.
5 Press .
6 Press or repeatedly until Delay Until appears.
7 Press .
8 Enter the time you want to send the fax.
9 Press .
10 If the printer is not set to the 24 hour mode, press or repeatedly to select AM or PM.
11 Press to save your settings.
12 Enter a fax number, or press Phone Book to select a number from the Speed Dial or Group Dial list. For more
13 If needed, repeat step 12 and press until a maximum of 30 fax numbers have been entered.
14 Press Start Color or Start Black.
Note: At the designated time, the fax numbers are dialed and the fax is sent to all of the designated fax numbers. If
the fax transmission is unsuccessful to any of the numbers on the broadcast list, the unsuccessful numbers will be
dialed again.
Receiving a fax
Receiving a fax manually
1 Make sure the Auto Answer light is off.
2 To receive the fax if you have not set up a manual answer code:
• Press Start Color or Start Black.
or
• Press * 9 * on the telephone after you answer it and hear fax tones.
3 To receive a fax if you have set up a manual answer code, enter the code on the telephone after you answer it
and hear fax tones.
Note: For information on how to set up a manual answer code, see the related topic, “Setting a fax manual answer
code.”
4 Hang up the telephone. The printer receives the fax.
Faxing
105
Apr 15, 2010 | Lexmark X5495 All-in-One &USB...
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
dialed.
3. Press START FAX Black.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
Faxing more than one page from glass.
You should be able to load the pages into the top "feeder" on the printer / scanner / fax. I think the needed to be loaded face up if I remember correctly. From there, you can dial the number, and hit fax, it should start to **** in the pages one at a time until they are all faxed.
Hope this helps!
Tim
Jul 12, 2009 | HP Officejet Pro L7380 Laser Printer
Cannot send or receive faxes
How to dial *xx codes when faxing When sending a fax, it may be necessary to enter in a *xx code as the first part of the number. Follow the steps below to dial *99 when using a VoIP service. NOTE: Since the *xx code is an instruction to the phone system, this must be dialed live.
  1. To pick up the line on the HP All-in-One, press Start Black Fax or Start Color Fax without entering a phone number first.
  2. When you hear the dial tone, enter in the *99 code.
  3. Wait a few seconds and then enter in the rest of the number.
  4. The HP All-in-One will complete the fax as normal.
What can be done to help the fax transmission? The communication speed is a major factor in fax transmission over VoIP. Currently there are three speed standards.
  • Fast - v.34 which communicates at 33.6 Kbps.
  • Medium - v.17 which communicates at 14.4 Kbps
  • Slow - v.29 which communicates at 9.6 Kbps
Changing the Fax Speed Adjustment setting to Medium may improve your ability to send a fax over a VoIP network. On most HP fax products the connection speed can be set to a lower speed. Those that do not have a Fax Speed setting generally communicate at medium speed or lower as this was the past standard. Consult your user's manual for information specific to your model. Changing the Fax Speed Adjustment to a lower speed Follow the steps below.
  1. Press Setup .
  2. Select Advanced Fax Setup .
  3. Press OK .
  4. Select Fax Speed .
  5. Press OK .
  6. Select Medium .
  7. Press OK .
  8. Try the fax again. If you continue to have problems faxing, contact your VoIP provider as they may have options to improve the ability to send and receive faxes over VoIP telephone service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 17, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Please help me send a fax on my HP 5610
Send a fax
You can send a fax in a variety of ways. Using the control panel, you can send a blackand-
white or color fax from your HP All-in-One. You can also send a fax manually
the fax.
If you frequently send faxes to the same numbers, you can set up speed dial entries.
For more information on setting up speed dial entries, see Set up speed dialing.
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
from the glass.
2. Press Fax.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 07, 2008 | HP Officejet 4215v All-in-One Printer
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
87 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
