Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
PCI IEEE 1394 Card IT-605 - Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
I have a acer aspire, ,what kind of pci card do i need so i can have a firewire port ieee 1394
Hi John,
The Acer Aspire 3502WLCi does not has the ability to use any PCI which can be compatible with Firewire IEEE 1394.
The model was designed not to support such type.
Regards,
Suhail
May 22, 2012 | Acer Aspire 3502WLCi Notebook
IEEE 1394 card will not install in windows XP SP3. There are no drivers available from the company.
Tough One... But I did manage to find where they went; it seems you need to be a member, for additional information. As a registered user of PPA International, you should be able to request a link for the driver. Give it a try, register for the newsgroup e-mail and then use the 'contact us' feature to request the location and or link to the archived driver, it never hurts to ask..
ppa Int'l or cut/paste the link into your Browser: http://ppa-usa.com/
Thank You For Choosing FixYa~!
Mar 25, 2011 | PPA International 1202 4 Port IEEE 1394...
Manual doesnt show Ieee 1394
You can buy an add-on Firewire (IEEE 1394) card in one of the two PCI expansion slots. That would add the firewire port on the back of the computer.
Feb 24, 2009 | PC Chips M863G V3.0C W 3400+ (ATHLON 2600...
Dell Optiplex GX620 will not recognize firewire controller card
1394 drivers should be native to XP, you may be able to correct this by running an SFC scan
Take out the IEEE1394 card
Insert your Windows CD (if you do not have it order a backup from dell)
Exit out of 'install screen'
click Start
click Run
type 'sfc /scannow'
press enter
you should see a progress bar, when finished restart the computer
this compared critical windows files on harddrive vs CD, and replaces missing and corrupt files
Feb 03, 2009 | Dell 2-Port IEEE 1394 FireWire CardBus PC...
My GR-D77OU jvc camera
IEEE 1394 doesn't work like USB so it probably won't show up in devices. What you would do is go to a video editing/burning program and click on a capture video option. The program accesses the video camera and you can choose what video you wish to record onto your computer.
Apr 08, 2008 | JVC GR-D370 Mini DV Digital Camcorder
Inserted pci IEEE 1394 card
You should have get a CD with your firewire card containing the drivers for it. Just insert it and run setup, or when it asks for the drivers when it boots up, point to the cd. An other option is to download the drivers from the manufacturer's website.You do not need to connect the port that is inside, it it there only in case you want a front panel port.
Alex
www.CustomAutomaticSystems.com
Jan 23, 2008 | Dell Dimension 3000 PC Desktop
Evergreen IEEE 1394/USB fireLINE PCI Combo Card
You might need to update the NVRAM that stores the PCI configuration that is read at POST. This is done by pressing and holding the so-called CUDA switch on the MOBO for for at least 30 seconds or so. The  eraser end of a wooden pencil makes a useful tool for this ;-) It sometimes requires unplugging the computer and removing the small battery that maintains the memory so that it is completely cleared. Please check that no connections, especially memory cards, haven't been disturbed during installation as well. HTH.
Dec 09, 2007 | Evergreen (90-FLCC-AA0) Serial Adapter
Can I use Firewire to transfer video?
Your computer must be equipped with an IEEE 1394 (Firewire) interface and video capture software. Provided you have both of these, follow the directions below. To connect your digital camcorder to your computer using IEEE1394, follow these steps: 1. Connect the IEEE 1394 interface on your camcorder to the IEEE 1394 interface on your computer. 2. Turn on your computer. 3. Turn on your camcorder. 4. Start the video capture software on the computer. Image capture should begin provided the computer hardware and software are configured correctly. If image capture does not begin, you must consult the computer or capture card manufacturer for assistance. Note: If you don't have an IEEE 1394 interface on your computer, you can buy an IEEE 1394 pci card at your local computer store that will work with most current computers.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
71 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
