Question about Yamaha RX-497 2 Channels Receiver
Yamaha receiver RX-497 sometimes is not switching on.
Yamaha receiver RX-497 is not switching on after a longer standby time.It behaves better, if I remove the power cable and connect it again after a minute. I heard a relais clicking some times and then the receiver switched on.
After that , immediate switching off and on is working properly.
The tuner channel settings are lost.
SOURCE: yamaha rx v1800 receiever will only play tuner on zone 2 speakers
Solution on page 111 of the owner's manual:
"Connect the source component to the analog audio input jacks of this unit to play back the source in Zone 2 or Zone 3.
This unit does not output the audio signals input at the DIGITAL INPUT and HDMI jacks to the ZONE OUT jacks."
Basically you cannot use an HDMI input if you want to play in Zone 2 or 3. A simple solution is to add an extra audio cable from your PS3 audio output jack to an analog audio input jack on the receiver.
Posted on Apr 03, 2009
satavlad
  • 405 Answers
SOURCE: My Yamaha RX V365 will not turn on anymore. It
Most likely, one of the channels is blown, or you having power supply issue. It is hard to determine exact cause of the problem with out looking at the unit.
Posted on Nov 28, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha receiver RX-V663
Make sure you have an analog RCA audio cable from the source to the receiver. Digital coaxial or optical will not work for zone 2 or zone 3. By adding an analog cable it will not affect your main zone, it will always go to digital first. Hope this helps
Posted on Dec 29, 2009
Testimonial: "great feedback. "
TOLhamRadio
  • 509 Answers
SOURCE: Yamaha RX-V757: Tuner not working
Is it set for XM / Sirius? If so, you need their special antennae unit; or are you talking AM & FM?
Posted on Jan 12, 2010
Grubhead
  • 5126 Answers
SOURCE: How much is a FM/AM tuner replacement part for a
If you mean the where the aerial goes in, it will be much cheaper to replace that, then buy any board, even if they are still made.
Have a look in Maplins (uk) or Radio Shack (USA) to see if you spot something like it. It will just need soldering on!
Posted on Jun 16, 2010
My Yamaha RX-673 not powering on. On standby mode
Have you tried switching the unit on with no cables or speakers connected and yes the unit can be repaired not problem.
Jun 15, 2016 | Yamaha Audio Players & Recorders
How to power up av receiver
Connect the AC power chord provided with the Receiver and switch-on power - the standby indicator glows now press the standby switch to power on your receiver
Jun 20, 2015 | Yamaha RX-A1020
How do i wire 1 cd player to two yamaha rx 497 stereo receivers
The answer depends more on our knowing what the CD player is than what the receivers are.
Does it have both digital and analog outputs? That would be one way? Coaxial digital outputs can sometimes be shared with two end units by placing an RCA splitter on the cable.
A single analog output can also be split with RCA splitters.
Couldn't you just slave the second receiver to the first one (via Tape 2 Rec/Out to the other one's Aux In or Tape PB/In) so ANYTHING the first receiver processes could be accessed by the second one?
Mar 02, 2010 | Audio Players & Recorders
I own a Yamaha RX-V461 and since making a few changes, new Bravia TV and BLu-Ray DVD player, I no longer jhave sub woofer output. I bought a new sub woofer cable and even bought a new Polk 8" 300watt sub....
You can reset the settings to factory defaults via the Advanced menu - it should be in your manual (I have RX-V465).
Do it from the standby mode.
Press the STANDBY button on front panel (not remote) together with STRAIGHT button on the front panel. Now you are in the Advanced Setup. Scroll to the INIT menu and select ALL.
Now you will have all settings in the default.
Jan 24, 2010 | Yamaha RX-V461 AV Receiver
How can I reset all settings on my yamaha rx-v730 to factory default?
Use Advanced Setup mode - see the manual. From standby press both STANDBY + STRAIGHT buttons, then choose INIT / ALL.
Oct 05, 2009 | Yamaha RX-V730 Receiver
Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Jan 02, 2009 | Yamaha RX-V995 Receiver
Config Problems After Repair
Sounds like they centre has configured your speakers to "none". You need to hook it up to a tV or monitor and go through the menu to "speaker settings" and make sure you select either "sml" or "lrg" for the speaker type. Also ensure on the LFE settings that you select either "swoofr" or "both."
Nov 02, 2008 | Yamaha RX-V800 Receiver
How do I turn On/Off my RX 596 reciever with my Yamaha remote ?
Press the Standby/On button on the remote or on the receiver (right below the Yamaha logo) to stop the audio output and display. The RX-596 goes into a low power standby mode when not in use; this allows it to respond to the remote when you press the buttons. If you want the receiver's power use to go to zero, you need to unplug it from the outlet. (You could also use a switched surge protector and push the switch to off.)
See page 9 (page 11 in the PDF) in the manual for the details on the On/Standby switch. The manual is available here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000057561.pdf . The page is also available here: https://www.manualslib.com/manual/197512/Yamaha-Rx-596.html?page=11#manual .
I hope this helps.
Jun 28, 2017 | Yamaha Audio Players & Recorders
Yamaha RX-497 2 Channels Receiver Logo
118 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
