Question about Samsung Dryers
Samsung dv448ag will not start when you push the start button.
Dryer power is on bu it will not start
barkencoa
  • 3463 Answers
SOURCE: The dryer will not start when the start button is pushed.
Try this link;
In your browser bar type in youtube.com
then in the search box type in kenmore dryer repair.
Then click on appropiate video(s)
This should help with the prob.
Plz rate this solution.
Thanks.
Posted on Dec 31, 2008
SOURCE: when I push the start button it will not turn on got power to dryer
The start button goes directly to the motor to energize the start winding until the centrifugal switch in the motor energizes the run winding.
If the motor is not trying to start, I would next test the start switch & related connections.
Posted on May 31, 2009
  • 60 Answers
SOURCE: when I push the start button the dryer will not start
May need to replace the starter swithch behind the control panel. MAKE SURE ALL POWER IS DISCONNECTED. If you still hear a humming sound when you hit the start button then it is not the switch, but the motor and if that is the case you may want to look into your warranty.
Posted on Aug 16, 2009
ftw1952
  • 10319 Answers
SOURCE: Dryer won't start if pushing start button. Power
Check the continuity of the door switch. If it does not work like it should the dryer will not start
Posted on Jun 22, 2010
  • 1796 Answers
SOURCE: Push start button dryer runs 1 second. Hold start
HI! The Push To Start Switch is defective. Click on the following link to order a replacement switch. !http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/3977456/0026/110/Model-11063952102/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11063952102&subCompDesc=Top%20and%20console&brandDesc=KENMORE&modelDesc=ELECTRIC-DRYER&pathTaken=partSearch&blt=11 for only $9.96. If you have a SEARS store closed by, you can get it from them.
To install, check the diag. on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11063952102/0582/0151200/P0211134/00001?blt=06&prst=&shdMod=
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Dec 08, 2010
Samsung dryer. It starts, but it doesn't get hot?
Samsung Dryer Diagnostic Repair & Diagnostic - Not ...
? 19:33
https://www.youtube.com/watch?v=a-8UFyRXBDg
Feb 7, 2014 - Uploaded by ApplianceVideo.com
Troubleshoot your own Samsung Electric Dryer that has some of the ... It powers on but when I get start nothing happens... drum spins but not ...
How To Fix A Clothes Dryer That Is Not Heating Or Drying ...
removeandreplace.com/2013/.../fix-clothes-dryer-heating-drying-clothin...
Sep 21, 2013 - At times your dryer can overheat and this can cause the motor that turns the ... Clothes Dryer Will Not Stay On After Pushing Start Button My dryer will run if I ... I have tried the trouble shooting tips for a dryer that doesn't dry but to no avail. ..... I have a 3 year old electric Samsung dryer and it stopped heating.
[FIXED] Samsung dryer runs, no lint clogs, good airflow, but no ...
forum.partsdr.com > Forum > Appliance Repair Help > Dryer Repair
Mar 12, 2013 - 16 posts - ‎4 authors
I want to check the third harness it but it doesn't look to slide out too easy once I remove the one phillips screw. ... Dryer gets nice and hot now!
Jan 19, 2016 | Samsung Dryers
Samsung Dryer DV665JW has no Power. I already checked the plugs and Breaker system, they are okay but nothing happens when I press the power button. It is 4 years old. Is it worth repairing ?
First, when you say "no power", is the front panel display totally dead? If so, and you're sure 240v is getting to the back of the dryer where the power cord connects, then its most likely the main board has been blown--did you have a power outtage recently? They are notorious for damaging circuit boards. If the dryer lights up but won't do anything when you push the start button, check the door switch--it's a safety feature that won't allow the dryer to run with the door open. There are also thermal fuses inside which, if open, will kill the power. BTW, yes, the dryer is worth fixing--the cost of a repair won't be near what a new dryer will be.
Aug 14, 2015 | Samsung Dryers
Just plugged in this dryer which I was told it was working when I picked it up. Everything lights up, but when I push the start button nothing happens.
Dear Interpreter1 ,
Try Holding the Start button for 3 Seconds or longer to see if it will start.
Here is a link to the Operating Instructions for your dryer
Good Luck!
JP
Samsung DV209AE User Manual
Jul 14, 2015 | Samsung DV218AEW Electric Dryer
My samsung gas clothes dryer will not start when start button is pushed?
check door switch, thermal fuse, the push start button all with multi meter. and of course the house outlet to see full voltage is coming out to machine
Jul 17, 2014 | Samsung Clothes Dryer Gas Valve -...
The drum on my dyrer quit turning
Possible problem may be broken belt or misaligned door switch. Try carefully holding the door switch closed to see if the dryer starts. If the dryer turns while manually pressing the door switch, but not when the door is closed, then the switch is misaligned. Make switch alignment to fix.
Jan 04, 2014 | Samsung DV448AG 27" 7.4 cu. ft. 11 Cycle...
105I have a samsung dryer dv409AER/XAA. Currently, I turn the power on and select a cycle and push the start button. When I push the start button - nothing happens. This occurs for any cycle. There is...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Dryers
I have a power but dryer wont start after i push start button. i can hear the click sound after i push the start botton but doesnt start.
heatman101
Aug 20, 2011 | Samsung DV419AGW Dryer
Power is on, push start button, light blinks on front but will not run?
may be a reset button on motor:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 24, 2010 | Samsung 7.3 Cu. Ft. Super Capacity...
I have a 5 year old Whirlpool Electric Dryer, Model #LER7648KT2. The Dryer won't start. I have checked the door switch, start button switch and visible thermo switches or thermostats with an ohm meter...
There are usually 2 thermal fuses in dryer circuits. One is on the heater housing and will blow in an overtemp condition around 310-350F.
The other is on the blower or exhaust housing and will blow around 200F
Make absolutely sure the 2nd one is continuous and not intermittently functional. This will definitely stop the motor from functioning
Below is a diagram for an older model (LER4634). Your dryer has some additional terminals probably because it has additional drying cycle options.
The diagram may be more readable when copied and pasted into a plain text editor such as Notepad or another editor with non-proportional fonts
Switch Terminals
|TM |TM |BK |BK |BK |
|WB |OR |BU |BU |R |
|-- |-- |V |-- |-- |
|O |X |O |X |X |Auto - High Heat
|O |X |X |X |X |Auto - Low Heat
|<> |<> |~ |X |O |Cool Down / Fluff
|O |X |O |O |O |End of Cycle
|X |O |O |X |X |Timed - High Heat
|X |O |X |X |X |Timed - Low Heat
Legend:
O = Open (Infinite Resistance)
X = Closed (Continuous)
<> = Either (But not Both)
~ = Doesn't Matter
NA = Not Applicable
Switch Terminals:
TM - Timer Motor (Different Models may use different colors)
WB - Black/White
OR - Orange
BK - Black
BU - Blue
V - Violet/Purple
R - Red
Example: For the Auto - High Heat Dry cycle, the following terminals are continuous:
Terminals
<TM - OR>
<BK - BU>
<BK - R>
(of course since BK-BU is continuous and BK-R is continuous, then BU-R is also continuous.
This should allow you to test at least some of the cycles your timer switch has
I have a general schematic in PDF for whirlpool for gas and electric, but did not see an option to add an attachment to this message.
Hope this helps or point you in the right direction.
Apr 21, 2009 | Dryers
Dryers Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
