Question about Diamond Multimedia GC500 - Diamond Gc500 Video Capture Card Hd Game
Gc500 recording in black and white - Diamond Multimedia GC500 - Diamond Gc500 Video Capture Card Hd Game
Have a panasonic dvd recorder model number Dmr-Ex77. which worked fine now it records and only lets us watch in black and white.
programs recorded from tuner are now in black and white
Frank, try new cables and inputs if you can, cables or inputs could be faulty.
Apr 01, 2016 | Panasonic Televison & Video
Jvc gr-ax35 only plays black and white on 3 different sources i.e. tv, dvd recorder player and usb capture. could this be tape detrition or dirty video head
i would take it and get it serviced
i think the tape isnt running at quite the right speed perhaps a dirty bearing
usually if you get black and white from a colour video
then its either recorded in black and white or playing back black and white
so if you record then test it using a a vcr and a converter vhs tape box then you can see if its recording in black and white
then youll know its something too do with either the colour carrier etc component of the video its outputing
dont think its a dirty head
but you can clean it easy enough
i use a plain manila envilope and use the inside of its paper
the outside is smooth the inside is rough
its just right to clean the head drum
and some small lint free cloth to carefully clean the mecha
i use IPA isopropile alchohol {get from the chemist}
Jan 10, 2015 | JVC Video Cameras
Why is my Tv flash black and white and the quality goes bad while using my ps3 while its hooked up to my Capture device?
That is usually caused from the capture device putting out a cross channel that you set is picking up. If the device has a modulator and plays through a CHANNEL as opposed to a connection, check the channel to be sure that it is the right one.
Jun 09, 2014 | Diamond Multimedia Diamond USB 2.0 GC500...
Image being Captured/Recorded is in Gray Scale (Black and White)
What game recording are u doing because some games have their own recording systems
Jan 12, 2014 | Pinnacle Computers & Internet
Have a panasonic dvd recorder model number Dmr-Ex77. which worked fine now it records and only lets us watch in black and white. cant work out what to do change it back to colour.
Good day!!!!
I can help you for your problem in dvd players cause i am audio video technician for 5 years and manage my own repair shop..
If you wish to solve that problem please try to click this link
I can fix all brand of your DVD
and get my service..
Oct 20, 2011 | Televison & Video
How i can watch the videos in the TV in colour is only black and white
If the videos are recorded in black and white your out of luck. If your trying to watch videos recorded in color on a black and white tv, get a color tv.
Comment if you need additional assistance or to provide more info.
Aug 05, 2011 | Iomega ScreenPlay Director 1TB HD Media...
CENTRIOS DVD recorder switched to black and white output
Hi
As the black and white pic got a snall cross dot patten all over it. If this so the input on your tv that connects to the dvd player as been set to s-video you can change this with remote on tv . regards windyhouse
Apr 03, 2010 | Centrios EDW8020 DVD Recorder
My camcorder has stopped recording in colour and will only record in black and white? Play back is black and white too.
set your cameras settings to COLOR, someone has changed your settings in video display and recording settings
Sep 17, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
No colour when I record using the Dazzle DVD Recorder.
Get a program called amcap and you also need pinnacle studio first open pinnacle studio then go to capture then if your using 12 dv then open amcap an error will come up then go to options then video filter settings or something then where it says pal or ntsc change it to secam b then go to pinnacle studio and look at the preview, it is in color then when you start recording it goes black and white again so open amcap go to options then video capture filter then change secam to ntsc then apply then go to secam b again then it will be recording in color then you have to cut out the black and white in pinnacle studio or any other video editing program I use sony vegas pro 9 then search tutorials on the program but it is easy in any program really.
Mar 11, 2009 | Pinnacle Dazzle DVD Recorder
Panasonic dvd recorder dmr-ex75
Change the AV settings on the DVD or TV to be the same format. Feeding AV into an AV-S gives B&W
Sep 16, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Open Questions:
Diamond Multimedia GC500 - Diamond Gc500 Video Capture Card Hd Game Logo
Top Diamond Multimedia Televison & Video Experts
venugopal durairajan
David Gust
Lawrence Oravetz
Are you a Diamond Multimedia Televison and Video Expert? Answer questions, earn points and help others
