Question about Brookstone Cloud DSS Long-Range Copter
Not able to sync
Manual calls for eight batteries, but I can only find room for four?
Pride Elite Traveler Plus occasionally stops and flashes eight times. Turning off and on corrects for a short time.
Hi, right it normally one of two things:
1. the connection to the rear axle, remove rear axle and clean the four connectors, gently, make sure there is a good contact.
2. The connection of the battery pack to the frame, again clean and make sure there is a good connection.
Regards
Jan 20, 2013 | Pride Health & Beauty
Wii remote four lights solid
Sounds like it needs to be re synced with the system, Easy place batteries in Wiimote and turn on console press the red sync button in the back of the Wiimote and press the red sync button on the console it is now synced. If this fails it could be that the Wiimote has failed, if Wiimote had failed within warranty period of 90days from date of purchase return for repair or replacement if it is after warranty period discard and replace with a new Wiimote.
Jan 12, 2013 | Nintendo Wii Console
What type of Batteries does it use
Your camera can use two types of power either four AA's or two of the Olympus type CR-V3 batteries. If you don't have batteries for it now I'd suggest purchasing a four battery set with charger and an extra set of four rechargeable so you have a total of eight rechargeable batteries. That way you can be using a set of batteries while another set is on the charger.
Hers is a diagram of the battery set up for your camera.
Diagram
Jan 09, 2011 | Olympus Camedia C-740 Ultra Zoom Digital...
Motorola phone MD7081 has eight phones with one base. All phones say "Out of reach" - new batteries installed, etc.
When you install a new battery, you need to place the phone (each one) in the base so it can sync up to the base stations radio signal.
Have you tried placing a phone in the base so it can sync up?
Jan 12, 2010 | Motorola Mobility MD7081 Cordless Phone
Cable TV splitter
Get one splitter if it is six rooms a six way splitter, they make them in three, four six, eight way splitters if it's cable make sure u cable splitter reg splitter uses lower freq the more connections u have the more signal loss. Get rid of as many or all those other splitters. Any question get back to me.
Jun 11, 2009 | Black Box Coaxial Coax splitter
Lost manual h700c...how can i get a password to sync?
Depending on the phone... try and remove the current bluetooth device. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Jun 10, 2009 | Motorola Mobility H700 Wireless Headset
Help me solve
1. Four Hundred Seventy-Eight Ten Thousandths
2. One Thousand Four Hundred Thirty Five Ten Thousandths.
3. Three Thousand Two Hundred Five Ten Thousandths.
4. Four thousand Seven Hundred Eighty Four Ten Thousandths.
5. Four Hundred Ninety Seven Ten Thousandths.
OR
1. Zero point zero four seven eight.
2. Zero point one four three five
3. Zero point three two zero five
4. Zero point four seven eight four
5. Zero point zero four nine seven
Thanks and please take a moment to rate as fixya.
Jul 06, 2008 | Audio Players & Recorders
Casio SI-460 phonemate executive series corded phone
I have 4 Casio SI-460 and I am having problems turning my auto attendant off. When I put someone on hold, then physically walk to the person to inform them of the call, the person in the other room can't answere the phone. When he picks up the phone the phone just beeps as if the battery is low, but it's not. The person has to come to my room and get the caller off hold in order for him to speak to them. Why is this happening? I have a manual and it saids to do steps 1-3. When I get to step 3, it doesn't allow me to use the soft key on/off button.
Jul 21, 2007 | Casio SI-460 Corded Phone
Brookstone Cloud DSS Long-Range Copter Logo
19 people viewed this question
Top Brookstone Televison & Video Experts
ray gallant
danoyachtcap
danoyachtcap
Are you a Brookstone Televison and Video Expert? Answer questions, earn points and help others
