Question about APC Back-UPS CS 500VA UPS System
UPS does not stand for 30 min
I have Champion UPS.Though it is the older version bought in 2005 but it is not giving backup even for 30 min. What may be the probable causes and the solutions.Please help me to solve the problem.
  • 70 Answers
Old and outdated get a new one used ones always have bad batteries but if you must get model number and search online may take a while but peruse through all the site thatsound promising and usually whalla
Posted on May 18, 2009
MY UPS DOESNT GIVE SUFFICIENT BACKUP
The amount of time your UPS gives you power decrease over time ( the battery is getting "old" ). If the UPS is new, check the characteristics and see the table with times and powers. Example : 5 minutes for a full 450 W and 10 minutes for 150W. So the more consumers you have the less time your UPS will stand.
Mar 17, 2011 | Computers & Internet
I'm planning to upgrade the firmware in my HPR5500 XR to version 2.06. The problem is I need to know the rev number of the current firmware in it. How can I determine that?
There's really only 2 possibilities here, older than or newer than 2.02. The upgrades are as follows:
For version 2.02 and above run the following batch file:
Flash_5125_6K_from_v0202_or_v0204_to_v0206.bat For version 2.00 or older run the following batch file
Flash_5125_6K_from_v0200_or_older_to_v0206.bat
I would try the newer one first and if it fails, then use the older one. (logic being, the newer one will check the revision, and if it's too old, won't do the upgrade)
Once you have successfully upgraded to 2.06 I highly recommend upgrading to 2.08 (you must do the 2.06 upgrade first though!)
Feb 24, 2011 | HP R5500XR (353806D71) UPS System
Ups is not getting charged
The UPS battery could be dead. If the UPS is older, that is probably the case. You can get replacement batteries but they can be expensive.
Jan 01, 2011 | Computers & Internet
My emerge UPS 500 is not at all giving backup.. its stays only for 1min after power goes.. before it had given more than 10 min but now it not even stands for 1 min.. pls help me.. wat i have to do??
you need new batteries,
then i think all will be back to normal.
WARNING
ups batteries are very dangerous, always seek the advice of a good tech or electronics shop.
Hope this helps
Thanks for using FixYa
Oh! please vote if useful
Aug 09, 2010 | Compaq R1500 ( 295459-001 ) UPS...
Battery backup time is 1 min when capacity is 100%(4 months older
The Batteries are the most likely course of your UPS backup problem. The batteries cell may have been weaken with Age or loose contacts. Check to confirm the battery contacts are not loose, replace the batteries with good one.You can also check the strenght of the batteries by using a Multimeter and load to read the voltage of the batteries outside the UPS. If the battery voltage drops below 10V Dc on load the the batteries should be replace. Otherwise check the battery contacts.
Jun 04, 2010 | APC Computers & Internet
House power fluctuates, UPS and computer die.
Sounds like the internal battery of the UPS needs replacement. Contact APC and ask for a qoute for a replacement battery/service. It'll probably work out a cheaper to buy new.
Make sure you dispose of the old unit properly if you do replace
Jul 07, 2009 | APC Back-UPS CS 500VA UPS System
UPS power goes off instantly as soon the external supply stops.
In our office, I have had to replace UPS batteries AGAIN two years after I replaced the original batteries in the units. I had purchased the replacement batteries locally, so I don't know if the brand of replacement batteries was not as good as the original batteries or what. But your weak battery light is not flashing ... I would try a replacement battery (if it isn't too expensive) but I know that some of the older batteries are no longer used in the newer UPS units so if the problem wasn't the battery you are stuck with a new battery and nothing to use it for.
Mar 04, 2009 | Opti -UPS PowerES 1400 UPS System
After spark apc ups stopped working
just check the fuse and mosfets(the one with 3 pin ic's) and replace if necessary
recommended to handle if u r a technician with soldering and component testing knowledge.
remove the battery and re connect after 2 mins
Sep 13, 2008 | APC (BE500U-WEB) (BE500UWEB) UPS System
APC Back-UPS CS 500VA UPS System Logo
71 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
