Question about Transcend T.sonic 610 MP3 Player
I cant able to switch on/off my ipod .....! when i put it in charge it will switched on and i can access my files and folders but it is for few minutes only after tat my ipod display is off but sngs are playing countinously i cant able to switch off other buttons also not working plz help me....!
  • 33 Answers
Read your manual....
Posted on May 18, 2009
Ipod not enough access privileges
your ipod may not have enough memory left for that size of a file..
Jan 20, 2014 | V, Inc. 2x Apple iPod Classic 80GB 120GB...
HOW TO UNLOK THE A1136 IPOD
click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
right click select rename to open or delete the folder your Ipod should now be open
or you might do a factory reset
The iPod A1136 is the fifth generation iPod from Apple that uses a click wheel to scroll through your device's media library, and may occasionally lock up when you attempt to play a song or display a photo.
This error error occurs when the hard disk is unable to access the information and stalls while opening a file.
A reset of the device usually corrects the problem, as it clears the device's memory and any errors.
Check your iPod's buttons to determine if the cause is due to a hardware error before resetting the device, as the problem may be due to the iPod's hold switch.
Slide the hold switch at the top of the iPod to the right, and slide it back to the left to ensure the switch is in the off position.
Hold down the center button in the click wheel, and at the same time hold down "Menu" on the click wheel.
Continue to hold the iPod's buttons until the device's screen shuts off, turns back on and shows the Apple logo.
Plug the iPod's connector cable into the dock connector on the bottom of the iPod.
Plug the other end of the cable into your computer's USB or FireWire port to charge the iPod.
Wait at least two hours for the iPod to charge. Launch iTunes on the computer, and click "Controls" of the iTunes menu.
Click "Eject iPod" in the sub-menu to disconnect the device.
The iPod takes four hours to completely charge its battery.
hope this helps
Oct 18, 2012 | Apple Ipod Video 5.5 Gen Black 30gb Mp3...
hope this helps
Oct 18, 2012 | Apple iPod MA446LL/A MP3 Player
I put a passcode on my ipod nano and i cant remember it
Good day,
I came across a few situations where someone has forgotten their iPod's passcode and now can't use it.
I will give some instructions on how to possibly repair this problem.
The first thing you can try is to connect your Ipod to it's HOME Computer. This will normally override the lock. Only thing is that you need the lock code to be able to assign a new code.
Another method I came across is to connect your Ipod to a computer. Make sure you are able to see all hidden folders. Browse to your Ipod on My Computer and double click on your Ipod folder/location. Open the folder named "iPod_Control" inside the folder open the folder "Device". Inside the device folder rename the file "_locked" to "_unlocked".
These two methods has worked for me in the past, so please feel free to let me know if this help you!
Regards
Feb 22, 2011 | Apple iPod nano
I PUT LOCK CODE ON MY I POD AND FORGOT THE NUMBER HOW CAN I DELETE SO I CAN GET INTO MY I POD
n Windows
On the Windows side, you can also easily access your iPod's hidden files. First, right-click your iPod. Then, select Tools ® Folder Options. This takes you to Control Panel ® Folder Options. Select the View tab, as shown in Figure 3-17.
Figure 3-17. Showing your hidden files
Under "Hidden files and folders," change "Do not show hidden files and folders" to "Show hidden files and folders." Click Apply to All Folders, and now all the invisible files on your iPod will be visible
Now open my computer. open your ipod and then open the file labled ipod control. Find the file that says "LOCK" or something like that. DELETE IT. If you do not see the file, you can run a search for it. Just make sure that you are deleteing the file lock thats in your iPod and not anywhere else on your computer!
Dec 21, 2009 | Apple iPod nano
Fprgot password to my Ipod 8gb.
Click "Start"
Click "My computer"
Switch to the classic view (if you're using Windows XP.)
Click "Folder Options"
Click the tab called "View"
Check "Show hidden files or folders"
If you also wish to view system files, Uncheck "Hide protected operating system files"
Plug in your iPod.
Wait for it to load completely.
Open My Computer (or computer if on Vista). Make sure you can view hidden files.
Go to iPod_control.
Go to the folder named Device.
If your iPod is locked, there will be a file _locked . Rename the file to _unlocked.
Safely remove your iPod and it will be cleared.
If you need more help, let me know !!
Sep 10, 2009 | Apple iPod touch
When I plug my iPhone into the USB it doesn't
ANSWER: The headphone jack will not charge your iPod. Only the USB will charge your iPod. However, the headphone jack will play music, but the USB will not play music from your iPod.
REASON: The headphone jack does not provide any power to charge your iPod. It isnly has enough power to recieve a music signal.
REASON WHY YOU CANNOT PLAY IPOD THROUGH THE USB: The USB is only intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files. The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
TO PLAY MUSIC FROM USB (NOT IPOD): You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
SOLUTION: To charge your iPod, you need to plug it into USB. However, to play music, you need to plug your iPod into the headphone jack.
Good Luck! - Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Aug 13, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
Notes folder
go to You tube:type in ipod help notes folder, look for HOW TO PUT NOTES ON YOUR IPOD from CrimsonBlood94
Sep 30, 2008 | Apple iPod MA446LL/A MP3 Player
Elow!
Connect the iPod and go to 'my computer';
-open the iPod by right clicking on the iPod icon;
-on the toolbar menu click on 'Tools'
-select folder options>view>& check the box that says "show hidden files & folders"
-then click 'ok'
You will see a ghost folder called 'iPod control'. Open this folder to access the other folders & files contained within it.
Delete the file called "Itunes_lock"
Come back and tell us if this worked for you. Thanks.
Sep 30, 2008 | Apple iPod nano
8gb mp3/mp4 player
If your iPod is frozen or won't turn on, your iPod may be paused or on "hold." Slide the Hold switch and check the screen.
If your iPod is frozen or won't turn on, connect your iPod to your computer, then press and hold the "Menu" and "Select" buttons simultaneously for 10 seconds to reset the iPod. Resetting an iPod will not affect your files or preferences.
If your iPod fails to hold a charge and it's more than a year old, you may need a new battery.
If all else fails, file a complaint with ebay stating you were sold something that was not properly described - unless the seller made it clear there were issues with the unit.
Hope this helps some!
TWEAK A/V LAB
Oct 26, 2007 | Apple iPod nano
Transcend T.sonic 610 MP3 Player Logo
102 people viewed this question
Top Transcend Audio Players & Recorders Experts
Gyula Lacz
IT Solution
IT Solution
k24674
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
